May 26, 2020, 01:42:23 pm
Author Topic: How-to optimize drag results  (Read 730098 times)
Offline Airbornemaikai
  • Forum Supporter!
  • Sr. Member
  • Idaho
  • Thank You
  • -Given: 22
  • -Received: 21
  • Ecobooster
Re: How-to optimize drag results
« Reply #15 on: October 24, 2014, 09:22:33 pm »
I've been running a 16% blend with 91 non ethanol and e85. No matter how many times I explain to the attendant exactly to the penny the amount of gas I want they always ask me why. I calculate it to the penny so that way I don't have to worry about accidentally squeezing over at the pump
2014 Explorer Sport
LMS 91 Tune with 3 Bar Map
160º Evenflo T-stat, 0.30 Motorcraft plugs
LMS DP W/HI-Flow Cats, LMS Corsa Cat-Back
Airaid 401-260
Offline Josephm
  • Elite Member
  • Moxee WA
  • Thank You
  • -Given: 153
  • -Received: 46
  • 12' Flex EB
« Reply #16 on: October 24, 2014, 11:24:00 pm »
Why don't you use 92/93 with E?
12' Flex EB
Unleashed X4
3rd Cat delete
  • Forum Supporter!
  • Sr. Member
  • Idaho
  • Thank You
  • -Given: 22
  • -Received: 21
  • Ecobooster
« Reply #17 on: October 25, 2014, 12:45:58 am »
None available in my state
2014 Explorer Sport
Airaid 401-260
Offline SHOnUup
  • Forum Supporter!
  • Elite Member
  • Washington Twp. MI
  • Thank You
  • -Given: 41
  • -Received: 414
  • SHO Love
« Reply #18 on: October 25, 2014, 09:16:03 am »
They look at me weird too when I say I'll take $3.58 on pump whatever...don't know if it's a man this guy's broke look or is he insane look. Lol
Now that I'm sure to top off each time to keep the mix right, my other weird look getter is gone. As I'd come in purchase a few things and ask for total, then quickly do the math in my head to equal an even amount. The puzzled look when doing this turns to a wow look when they add the odd gas request and it's say $50 even...long lost art of math.
Rich
Offline pejohnson
  • Sr. Member
  • Columbus, OH
  • Thank You
  • -Given: 39
  • -Received: 44
  • Ecobooster
« Reply #19 on: October 25, 2014, 12:30:20 pm »
Should I take the under belly shield off?  I know at high speeds people have experienced hood vibration. Not sure if would happen or not at the strip. Thought by removing it might help with engine temps.
13 Platinum White, PP, 402A, Moonroof, Multi-contour seats, and Navigation.  MODS - LMS 93 octane 3bar tune, 160 LMS thermostat, Airaid CAI, 15% tint, interior LED upgrade, LED puddle lights, Nurburgring 20" Gloss Black Powercoated Rims, H&R springs, Corsa catback exhaust, LMS catted downpipes
Best time 1/4 mile 12.588 sec @ 109.44 mph
Offline SHOnUup
  • Forum Supporter!
  • Elite Member
  • Thank You
  • -Given: 41
  • -Received: 414
  • SHO Love
« Reply #20 on: October 25, 2014, 12:34:44 pm »
Good question. Maybe extra drag would be created by removing this. Some have removed the plastic strip along the back of the hood where it meets the windshield. Might be a better option to avoid extra drag and the possible hood shake.
Rich
Offline SHOdded
  • Forum Supporters
  • Elite Member
  • Beltsville, MD
  • Thank You
  • -Given: 12953
  • -Received: 4203
« Reply #21 on: October 25, 2014, 01:13:03 pm »
I would back Rich's comment about the plastic strip.  Getting rid of heat effectively will probably be a better approach for the drag strip.
Offline Larrylu
  • Elite Member
  • Albany, NY
  • Thank You
  • -Given: 11
  • -Received: 110
« Reply #22 on: October 25, 2014, 01:54:02 pm »
Rich
Removal of the rubber seal at the back of the hood/firewall has been a good experience for me. No noticeable water intrusion at all and coupled with the engine cover removal, I have achieved a real measurable IAT2 temp drop.
Offline pejohnson
  • Sr. Member
  • Columbus, OH
  • Thank You
  • -Given: 39
  • -Received: 44
  • Ecobooster
« Reply #23 on: October 25, 2014, 04:30:19 pm »
Interesting. I may give that a try. Thanks.
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • Elite Member
  • New York SHO
  • Thank You
  • -Given: 1932
  • -Received: 4056
« Reply #24 on: October 26, 2014, 10:32:29 am »
http://www.amazon.com/gp/product/B00029KC2U/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1 ordered some heat shield tape and installed it around the intake and with the combination of removing the cowl cover that Rich pointed out and engine cover will see a drop in IAT temp's cause our car's are so sealed top to bottom and limiting the engine to breathe,will check with torque if any drop in IAT'S.
« Last Edit: October 26, 2014, 10:37:45 am by ZSHO »
Offline SHOnUup
  • Forum Supporter!
  • Elite Member
  • Thank You
  • -Given: 41
  • -Received: 414
  • SHO Love
« Reply #25 on: October 26, 2014, 11:06:55 am »
Would like to defer the above mentioned credit to Larry, (thx though) as I'm pretty sure he was the one with this clever idea.
Rich
Offline dappie99
  • Jr. Member
  • Thank You
  • -Given: 0
  • -Received: 1
  • Ecobooster
« Reply #26 on: August 25, 2016, 12:56:28 pm »
Taking my to local 1/8 mile track again this weekend. Great tips!
Offline lamrith
  • Elite Member
  • PNW
  • Thank You
  • -Given: 106
  • -Received: 386
  • Ecobooster
« Reply #27 on: April 17, 2017, 01:19:08 pm »
So newby to the SHO and AWD launching here, hoping to get a little clarification on the boost brake launch.
As soon as you go green and let off brake do you plant the throttle or roll into it at same time you let off brake?
I know when I have been trying to datalog if I just mat it, it tends to spin allot more than rolling into it.  That is usually colder road vs prepped track though.
'13 Sho PP, SCT x4, AJP 92-Octane rev6 (14psi&20spark) NGK 6510, 3Bar, K&N CAI, PPE Catted DP, Dynomax Axleback, 20*9.5 Voxx Lago.
Offline derfdog15
  • Elite Member
  • Thank You
  • -Given: 138
  • -Received: 441
  • Ecobooster
« Reply #28 on: April 17, 2017, 01:44:32 pm »
I got better results by putting it to the floor when launching, I would brake boost between 2000-2200 RPM, and on the 3rd yellow, let out of the brake and simultaneously floor it. This got pretty good reaction times, and nice 60' times with all season tires (1.7-1.9).
Online TopherSho
  • Elite Member
  • Eugene Oregon
  • Thank You
  • -Given: 483
  • -Received: 366
  • 1st boosted rig!
« Reply #29 on: April 17, 2017, 02:27:22 pm »
--avoid gravel, dirt, water at all costs.
--slowly drive into the box, and super creep to get the second stage light lit without rolling any further into it.
--brake hard
--push the gas so the rpm is 1900-2000 (for me).  keep it STEADY at that rpm.  The SOONER you can start this the better as you are low speed spooling the compressor.  With the compressor already spinning you have taken some of the inertia penalty away from the launch.
--wait for light number 3 on the full tree to light up.. this is 500ms between each light.  so,  yellow, yellow, yellow and go! BEFORE green.  100% stab\murder the gas pedal while releasing the brake.  do this simultaneously and as lightning fast as you can.
--hang on
** LANE ETIQUETTE!  *remember*
-Know where the exit is... this is critical to not getting thrown off the track.  If the exit is on your LEFT,  and you are in the RIGHT lane. DO NOT CROSS THE LANES until the left car has exited FULLY.  And if the exit is on the RIGHT, and you are in the left lane do not cross the right lane until the right lane has fully exited.
-make eye contact with the lightman when lining up. its polite. and you will be able to communicate more.
-bring pants.
-bring shoes, no sandles
-bring a HELMET,  SNELL SA2010 or better (and yes there expensive-ish), Not a SNEL M2010 helmet although some tracks do not inspect that close, but if they do a M rated helmet is not the same as a SA rated helmet.
« Last Edit: April 17, 2017, 02:32:37 pm by TopherSho »
2010 non-pp, 50k miles, 3-bar,  .30 plugs, 170-T-stat, SNOW-KIT STG1, AJP TURBO METH TUNE-REV3
Best of 12.61 no DA correction
* Featured Topics
* Recent Topics
Updated Gallery Capabilities
by StealBlueSho | Today at 11:49:44 am
Added the Ecoboosted Gallery and updated the Gallery software to 6.0d....
Ecoboosted Gallery!!
by StealBlueSho | Today at 11:27:31 am
by sm105k | Today at 11:19:29 am
Hptuners most likely supports this. Email and ask them. If not they ca...
by StealBlueSho | Today at 10:20:54 am
by 802SHO | Today at 05:15:44 am
Re: MRT blues
by FearlessAZ | Today at 04:55:34 am
I agree. The difference from my 2010 SHO to my 2015 MKS feels almost l...
Re: EBPF Under New Ownership!
Re: EPP CAI
Re: Let’s talk weight reduction?!
by 802SHO | May 25, 2020, 05:27:29 am
Man that flywheel ssssure issss perrrtyyy Sent from my LM-G710VM using...
Re: 802SHO 2010 Build
by 802SHO | May 25, 2020, 05:19:39 am
I would be super intrigued on the 13+ manifolds and how they work out....
Re: Ford Recalls
Re: Brake Cooling Kit
Re: Performance Oil Pan
by bpd1151 | May 24, 2020, 06:08:01 pm
Hey Everybody. Thanks so much for all of the comments and ideas. After...
by StealBlueSho | May 24, 2020, 05:44:23 pm
Just a quick clean with my favorite detailing product!https://uploads....
Back to top
