Author
Topic: P0016 code, But cam positions in range. (Read 789 times)
Recent Topics
nice ride, nice wheels. welcome and congrats!...
Greetings from Nebraska.Also Go Bengals!Greg...
idk if this is the case here but apparently white smoke can also be ca...
if you replaced the 2 bar map with a 3 bar and did not tune for it, th...
Do you mind sharing the part number ofDescriptions. Or should I ...
Hey all, just an update and I am sure it won't be a surprise.&nbs...
My ford Taurus sho usually makes a grinding noise when the tires spin....
idk if rockauto is still monitoring this site. but in the meantime, go...
Non E 91 is a good choice.5000 ft is tough on turbo output but the tun...
Ford OEM rotors are bad. Same issues with the Edge ST. PP rotors are b...
