April 01, 2023, 09:33:17 PM
Author Topic:  Ruthenium HX Spark Plugs LTR6BHX or M-12405-35T  (Read 428 times)
Offline Hminus3505
  • Newbie
  • Thank You
  • -Given: 0
  • -Received: 0
  • Ecobooster
  • Liked:
  • Likes Given: 0
« on: January 03, 2023, 04:25:04 PM »
Forum newbie...
Just picked up a virgin 2016 SHO non-pp with 30K on the ODO previously owned by an older gentleman and his wife.  Working on putting together a list of upgrades and am curious about plugs? I've seen on the forum (only one post) about Ruthenium holds gap better, but is it too cold of a plug compared to the 12405's
Ruthenium HX Spark Plugs LTR6BHX or M-12405-35T.
Thanks in advance.
Offline Macgyver
  • Super Moderator
  • Elite Member
  • Eastern Pa.......
  • Thank You
  • -Given: 100
  • -Received: 396
  • 2020 Red ST
  • Liked:
  • Likes Given: 37
Re: Ruthenium HX Spark Plugs LTR6BHX or M-12405-35T
« Reply #1 on: January 03, 2023, 09:57:52 PM »
OEM Plugs are fine for most power situations. I would not stray from these unless you are tuning Well above what most tune for.
I had Brad, AJ Turbo, tune my 2015 SHO and he said just use the OEM heat range. I was tuned to a high 93 tune, E30, and FULL E85 tune. Brad said there was absolutely nothing to gain by going colder. Same with the Thermostat.
OEM plugs are inexpensive, easy to replace, and unless you are driving like a mad man. They will hold gap pretty well.
Iridium are not "Gap able ". Are these ? When tuning. You want to gap a lot smaller to avoid blowing out.
I am showing like $25 a plug. Yeah not worth it imho.
* Recent Topics
Re: Fresh Meat
by Dxlnt1 | March 31, 2023, 10:57:48 AM
Firestone fire hawk 275/40-20...
Possible RFA module/key fob issue
by Mml665 | March 30, 2023, 09:38:20 AM
I am getting the key fob not detected error.  The key fob will no...
by Mml665 | March 30, 2023, 09:28:53 AM
I apologize for the double post but the first post I attempted using T...
Key Fob Issue possible rfa module
by Mml665 | March 30, 2023, 09:13:46 AM
The other day MKS wouldn...
Pcv issue or turbo seals?
by 13shonuff | March 07, 2023, 04:51:15 PM
I have a 2013 SHO. after my atp turbos blew up from turbine housing cr...
Re: P0016 code, But cam positions in range.
by SHOdded | March 05, 2023, 10:02:43 AM
still not seeing the adverr values. but i checked my logs for our 2007...
Re: New from the Puget sound Washington area
by PDSHO | March 03, 2023, 09:57:38 PM
Greetings from Nebraska.Greg...
Re: SHO'Nuff
by PDSHO | March 03, 2023, 09:56:14 PM
Re: 2013 SHO w/pp. Replaced timing chain and water pump. still have issues
by SHOdded | February 27, 2023, 10:17:12 AM
yes recheck the timing chain marks, make sure they line up perfectly.&...
Re: That's the Brakes
by SHOdded | February 11, 2023, 04:34:03 AM
Thank you all for your valuable input. I successfully bought & rep...
