Plugs for sure can cause bad MPG. So can Winter fuel if you live in the north. A stuck injector will as well butt that should throw a code.A vacuum leak will cause bad MPG.Scan for codes and see what happens there.[size=78%] [/size]So you are saying. 150 ish miles and you are going through 15 gallons of gas ? Thats 10mpg.
MY, mileage, maintenance history, ambient temps at cold start ...22 miles roundtrip or oneway?remote starting / extended idling? all highway, mostly highway, mostly city, ?
I would change the plugs just because its fairly easy.Check the tire pressure.Change fuel brand. Use Shell if you are using Sunoco etc.10mpg is way too low. There has to be an easy reason.
