September 24, 2020, 11:41:12 PM
Author Topic:  HOW-TO: Improve a bit on the X35 Phenolic Spacer  (Read 548 times)
Online Ecoboost_xsport
  • 2015 Ford Explorer Sport
  • Full Member
  • Orangevale, CA
  • Thank You
  • -Given: 46
  • -Received: 57
  • Mad Scientist
    • The Workshop
  • Liked:
  • Likes Given: 0
« on: July 30, 2020, 11:09:48 PM »
..and think I found a small way to improve it...
Got it today and looks like a great product and look forward to getting it installed to see if it can mitigate IM heat soak issues further.  I still need to order the additional gaskets before I can install it.
When I mocked it up and placed the hardware in the holes so I can see if I would need to do any port matching, I found it suffered from the same issue as the BBK throttle body.  Not the fault of the spacer, but more the fault of the IM.  The bolts holes are just too large for the hardware and allow for a lot of play.  This would make any attempt at port matching it futile as it would be difficult to place properly when installing it.  So...just as with the BBK, I used the same logic here. and it worked perfect...
Spacer with gaskets installed:
Thickness of spacer for those curious:
Dowels created for improvement:
5/16" OD,  0.035" wall thickness, 304 stainless tubing, cut to about 0.8" length (can't be any longer than 0.9")
Picked any 2 holes far apart from each other and drilled with 5/16" drill bit:
Drilled matching holes in spacer, same 5/16" drill bit:
Dowels installed into spacer:
Perfect tight fit onto IM:
Will need minimal port matching, mostly just a little of the spacer needs to be matched to the ports, but Steve did a great job of getting it super close.
There ya go.  I can probably drill the bolt hole very slightly using the same 5/16" drill bit for the match holes in the heads and push those dowels through the spacer slightly.  That would get this setup 100% dead-nuts tight and centered from head to spacer to IM...
« Last Edit: July 31, 2020, 11:44:45 AM by Ecoboost_xsport »
IG: ecoboost_xsport
Airaid CAI | ATP +2 Garret Turbo Upgrade | Big Head Motorsports Catless Turbo-Back Exhaust | MSD Ignition Coils | XDI-60 HPFP | FoMoCo 3bar MAP | DeatschWerks DW300c LPFP | UPR Catch Can |  AD Gen 2 Torque Mounts | Braille i25X Lithium Battery | Brisk Silver Racing RR12YS Plugs (0.26 Gap) | EPP Hot Pipes | Tial Sport QR 50mm VTA BOV | 160 Livernois Thermostat | H&R Super Sport Lowering Springs | Wilwood 15.00" Front Rotors  | Wilwood 14.25" Rear Rotor | Wilwood W4A Front & Rear Calipers | Advan GT Premium Wheels 20x11-15mm | Hankook Ventus ST RH06 295/45-20 | Bilstein B6 Front Struts | Bilstein B6 Rear Shocks | Steeda Rear Sway Bar | Steeda Rear Toe Links | Steeda Rear Trailing Arm | SPC Front & Rear Camber Adjustment Bolts | Innovate Motorsports MTX-D Ethanol Content Gauge w/GM 13577429 Flex Fuel Sensor | Redline Tuning Hood Struts | FoMoCo PI Rear X-Brace | Diode Dynamics SS3 Pro Yellow LED Foglights | Custom RaceSeng Front Tow Hook | WR: 3rd Row Seat Removed | SCT Livewire TS+ | 100 OCT AJPTurbo Tune
Offline MKS Tom
  • Super Moderator
  • Full Member
  • PA
  • Thank You
  • -Given: 80
  • -Received: 111
  • Weirdo
  • Liked:
  • Likes Given: 3
Re: HOW-TO: Improve a bit on the X35 Phenolic Spacer
« Reply #1 on: July 31, 2020, 10:05:08 AM »
Excellent idea.
2013 Lincoln MKS ecoboost, 70,000 miles.  3 bar map 93 tune (E30 in the future) by both AJP Turbo and Ortiz Performance.  PPE catted down pipes, EPP dual CAI (not yet installed so K&N drop in), .026 gapped SP542, 170 degree thermostat, Dynomax axlebacks, and Power Stop Z23 pads and rotors.
  • Full Member
  • Orangevale, CA
  • Thank You
  • -Given: 46
  • -Received: 57
  • Mad Scientist
    • The Workshop
  • Liked:
  • Likes Given: 0
« Reply #2 on: July 31, 2020, 11:59:25 AM »
I've been asked about making these available.
Anybody else interested? I could do these sets for, let's say $20 shipped. I'm not making much. About $8.50 is shipping ,PayPal takes 4%, plus cost of materials (per set). I'm making lil more than $5 a set for my labor.
LOL...damn, I might need to charge more haha.
IG: ecoboost_xsport
Offline x35design
  • Vendor
  • Newbie
  • TX USA
  • Thank You
  • -Given: 1
  • -Received: 11
  • Ecoboost SHO Spacer man
    • X35 Design Website
  • Liked:
  • Likes Given: 0
« Reply #3 on: July 31, 2020, 07:00:05 PM »
Good idea - I had a similar idea in my mind at the start of the project too, but I wasn't sure if it would work for every car, given the giant holes Ford puts in the IM vs the diameter of the bolts...I figured I better copy their scheme, as there might have been a reason.  After seeing a few spacers get installed, it appears that they are all pretty similar and fit consistently though.
 :beer2:
Oh BTW, I've about 14 left to make to finish the wait list, then the spacers will be set up in my store like a normal item, so if you didn't / couldn't get in now, they'll be available in the future.
  • Full Member
  • Orangevale, CA
  • Thank You
  • -Given: 46
  • -Received: 57
  • Mad Scientist
    • The Workshop
  • Liked:
  • Likes Given: 0
« Reply #4 on: July 31, 2020, 09:25:01 PM »
 :beer2:
Thanks!
Sent from my SM-G965U1 using Tapatalk
IG: ecoboost_xsport
  • Full Member
  • Orangevale, CA
  • Thank You
  • -Given: 46
  • -Received: 57
  • Mad Scientist
    • The Workshop
  • Liked:
  • Likes Given: 0
« Reply #5 on: August 06, 2020, 08:45:19 PM »
Finally have a few sets done if you are interested.
I know there were a few on other boards that showed interest, just hit me up here and I'll DM you paypal info if you are interested.  It'll be $20 shipped.  Thanks.
« Last Edit: August 06, 2020, 09:20:16 PM by Ecoboost_xsport »
IG: ecoboost_xsport
  • Full Member
  • Orangevale, CA
  • Thank You
  • -Given: 46
  • -Received: 57
  • Mad Scientist
    • The Workshop
  • Liked:
  • Likes Given: 0
« Reply #6 on: August 08, 2020, 09:46:21 PM »
Just got done port matching my spacer to my intake runners.  You can't even feel a change in the transition it's so smooth. This process is not possible without the alignment dowels.
Now, when I get my heads exposed, I'll entertain the idea of matching the bottom part of the spacer to the openings in the head...
"Those balls look smooth as eggs!!!" - Dave Chappelle
IG: ecoboost_xsport
Offline Macgyver
  • Super Moderator
  • Elite Member
  • Reading, Pa.......
  • Thank You
  • -Given: 99
  • -Received: 355
  • Ecobooster
  • Liked:
  • Likes Given: 6
« Reply #7 on: August 09, 2020, 03:37:36 PM »
Nice !!!
Good thing its not a V12.......
  • Full Member
  • Orangevale, CA
  • Thank You
  • -Given: 46
  • -Received: 57
  • Mad Scientist
    • The Workshop
  • Liked:
  • Likes Given: 0
« Reply #8 on: Today at 01:02:41 PM »
UPDATE Ladies and Germs!
Finally got this thing mounted onto the engine (video forthcoming on that), but here's a video on me doing the porting on the head side of the spacer...
IG: ecoboost_xsport
* Recent Topics
Re: And the award for most frequently broken car goes to...
by Macgyver | Today at 10:28:06 PM
Oh Boys. Lets hope she holds together !!!...
Re: Daily driver MKT
by TopherSho | Today at 08:07:20 PM
:zumbujump: :zumbujump: :zumbujump: :zumbujump: :) :) :)Curious of op...
Re: Whiteline 24mm Adjustable Rear Sway Bar for 2010-2019 Taurus SHO/MKS/Flex/MKT
by MKS Tom | Today at 06:54:18 PM
This will be a desirable part that will help with the weight this land...
Re: SHO vs Hellcat Redeye
by BlueSHO | Today at 06:31:14 PM
Nice win but something was seriously wrong with that Challenger..Sent ...
Re: BamSHO 12.14 MIR Extra Preppy!!
by Macgyver | Today at 02:39:20 PM
Thats what I figured. Too much is not good....
by Ecoboost_xsport | Today at 01:02:41 PM
UPDATE Ladies and Germs!Finally got this thing mounted onto the engine...
Re: Highest Dyno on Stock turbos
by GotGrip? | Today at 12:03:44 PM
https://uploads.tapatalk-cdn.com/20200911/5b545dea1037d1a123f439a1f85b...
Re: MIR Private Rental 09/23/2020
by StealBlueSho | Today at 11:58:08 AM
Got a video of the best run of the day!https://youtu.be/Nn_zQhbSut8...
Re: Any 11 second SHOs/MKSs in the south? 😂
by 10sleeper | September 23, 2020, 07:05:04 PM
Sure man, ran 11.95 rear seat out and 11.97 Full interior in Houston, ...
Re: Coilovers?
by 808San808 | September 23, 2020, 06:22:35 AM
The only one I know of is from MTM, message @JustinHagan on fb...
Official Forum Sponsor of Ecoboost Performance Forum
