September 25, 2020, 09:41:02 PM
Author Topic:  PTU and Engine Oil Change...  (Read 557 times)
Offline Ecoboost_xsport
  • 2015 Ford Explorer Sport
  • Full Member
  • Orangevale, CA
  • -Given: 46
  • -Received: 57
  • Mad Scientist
    • The Workshop
  • Liked:
  • Likes Given: 0
« on: July 25, 2020, 01:59:49 AM »
So you guys know I did the RDU the other day.  Also I'm putting the trans fluid change on hold until I can get a true fluid exchange done since I'm changing fluid types.  Anyway, got the engine oil done as well as the PTU done.
Engine Oil: Pretty straight forward, just showing you guys the switch I made from el cheapo middle of the road Pennzoil stuff to some better Amsoil fluid and filter...
Oil filter is about 33% larger than that cheap service station filter I had on there...btw, I WON'T be changing that filter after 25,000 miles, lol.
Onto the PTU.  I am still experimenting with beefing up the PTU I have on my bench, but in the meantime, I am still running my original one and decided to do the drain plug and vent tube extension mod.
This PTU fluid is coming from somewhere. Top of the vent tube and vent tube hose was clean, so wondering if it is leaking from somewhere else.
I like the idea of having the drain on the lowest point to get all of it out, so I bypassed the existing drain port and just added the bottom one.   I was only able to drain out 12 ounces...so 6 ounces disappeared somewhere.  When I drilled the hole for the bottom drain, I stuck a paperclip in there (bent like and "L") and spun it around to see if any grease or sludge would be on it as maybe those 6 ounces converted to "grease", but, to my surprise, came out clean.  IDK...weird.  I never had an oily spot on my driveway.
Drain plug installed...matched my RDU drain plug.  Also put heatshrink around it to keep the cap from ever spinning off.
Love the v-bands...so easy, LOL:
With removal of the front downpipe, I could very easily get to the top vent.  By feel of course, but very easy to reach.  Added the hose and was able to get this clamp on tight:
Used this tool to tighten it blind.  Was pretty easy actually:
Bottom end buttoned up:
Removal of the vent cap and placed this barbed fitting for filling only:
Since I only needed 18 ounces, and there's 32 in the quart pack, I poured out 14 ounces and storing it in another bottle for later:
IV bottle style fill job:
Hole was punctured in bottom of pouch. Even so, it really did take quite awhile.  I let it hang there in the hot sun so it got very viscous, I'm sure, but still took a few hours to drain.  On the new PTU, I will be adding a second fill line next to the vent port.  This will keep from fighting the air coming up.
Installed vent cap, zip tied it off to the side and all done!
« Last Edit: August 04, 2020, 02:06:16 PM by Ecoboost_xsport »
IG: ecoboost_xsport
Airaid CAI | ATP +2 Garret Turbo Upgrade | Big Head Motorsports Catless Turbo-Back Exhaust | MSD Ignition Coils | XDI-60 HPFP | FoMoCo 3bar MAP | DeatschWerks DW300c LPFP | UPR Catch Can |  AD Gen 2 Torque Mounts | Braille i25X Lithium Battery | Brisk Silver Racing RR12YS Plugs (0.26 Gap) | EPP Hot Pipes | Tial Sport QR 50mm VTA BOV | 160 Livernois Thermostat | H&R Super Sport Lowering Springs | Wilwood 15.00" Front Rotors  | Wilwood 14.25" Rear Rotor | Wilwood W4A Front & Rear Calipers | Advan GT Premium Wheels 20x11-15mm | Hankook Ventus ST RH06 295/45-20 | Bilstein B6 Front Struts | Bilstein B6 Rear Shocks | Steeda Rear Sway Bar | Steeda Rear Toe Links | Steeda Rear Trailing Arm | SPC Front & Rear Camber Adjustment Bolts | Innovate Motorsports MTX-D Ethanol Content Gauge w/GM 13577429 Flex Fuel Sensor | Redline Tuning Hood Struts | FoMoCo PI Rear X-Brace | Diode Dynamics SS3 Pro Yellow LED Foglights | Custom RaceSeng Front Tow Hook | WR: 3rd Row Seat Removed | SCT Livewire TS+ | 100 OCT AJPTurbo Tune
Offline SM105K
  • IG @egocheckersho
  • Forum Supporters
  • Arizona
  • -Given: 1036
  • -Received: 1198
  • Thee Forum Cowboy
  • Liked:
  • Likes Given: 13
Re: PTU and Engine Oil Change...
« Reply #1 on: July 25, 2020, 10:11:46 AM »
Top Notch work as always.
"M" 2013 SHO PP | AJPTurbo E30 Tune | FS HPFP | GH Intercooler w/ DIY Ice Water IC Sprayer | PPE Downpipes | Custom Magnaflow Resonator | 3rd Cat Delete | Derale Upgraded Trans Cooler | Dicunzolo Gen2 Trans Mounts| EPP Noisemaker Eliminator | MSD Coil Over Plugs | SP-542's | UPR Dual Valve Catch Can | K&N Drop In | Power Stop Slotted and Drilled Rotors with Stock PP Pads | H&R Springs  | AVS Flush Deflector | 802SHO Custom Splitter | Duraflex Chin Spoiler | Curva Concept C7's | Continental DWS06 Extreme Contact Rubber |
Offline Macgyver
  • Super Moderator
  • Reading, Pa.......
  • -Given: 99
  • -Received: 355
  • Liked:
  • Likes Given: 6
« Reply #2 on: August 04, 2020, 01:46:20 PM »
Yes once again. Super well done !!!
Offline WinPlaceSHO
  • Forum Supporters
  • Jr. Member
  • Midwest
  • -Given: 58
  • -Received: 32
  • Liked:
  • Likes Given: 9
« Reply #3 on: August 04, 2020, 02:12:47 PM »
I love that it looks like it's getting an IV drip of Amsoil!
Black 2018 SHO Non-PP | GH e30/AO Tune | PPE Catted Downpipes | Dicunzolo Gen2 Trans Mount | SP-542's | 170 Tstat | 3 bar | H&R Springs | XDI-35 | Badges removed  | Chrome delete | GH IC | EPP CAI | Noisemaker delete | MSD coils
Offline Macgyver
  • Super Moderator
  • -Given: 99
  • -Received: 355
  • Liked:
  • Likes Given: 6
« Reply #4 on: August 04, 2020, 09:50:10 PM »
Funny how the Ford Edge ST/Sport 2.7 liter TT and F150 and Fusion and Lincoln is a similar platform but they have totally different Oil changes.
It uses a cartridge filter and the oil pan is composite with a plastic drain plug.
  • Full Member
  • Orangevale, CA
  • -Given: 46
  • -Received: 57
  • Mad Scientist
    • The Workshop
  • Liked:
  • Likes Given: 0
« Reply #5 on: August 04, 2020, 10:16:30 PM »
The 2.7 and 3.5 are completely different engine platforms that share almost nothing besides being a V6.  The 2.7 is based on the Ford Nano engine family, while the 3.5 is of the Cyclone (duratec) engine family.
There is very little in common between the 2 engine families except maybe the DI fuel delivery technology as well as the variable cam timing. Not a surprise that they would have different  oil pans and filters...
Sent from my SM-G965U1 using Tapatalk
IG: ecoboost_xsport
Offline TopherSho
  • Eugene Oregon
  • -Given: 489
  • -Received: 380
  • 1st boosted rig!
  • Liked:
  • Likes Given: 0
« Reply #6 on: August 06, 2020, 10:35:28 AM »
I think he means the actual 2.7L available for the F150 ;)       /me runs away!/
  • Full Member
  • Orangevale, CA
  • -Given: 46
  • -Received: 57
  • Mad Scientist
    • The Workshop
  • Liked:
  • Likes Given: 0
« Reply #7 on: August 06, 2020, 11:10:40 AM »
Ahhhhhh, I see...yeah, I must've misinterpreted the comment...this being a thread about the 3.5 ecoboost drivetrain and all...
My mistake...
IG: ecoboost_xsport
Offline Macgyver
  • Super Moderator
  • -Given: 99
  • -Received: 355
  • Liked:
  • Likes Given: 6
« Reply #8 on: August 06, 2020, 11:09:55 PM »
Yeah it was just a shocker when I went to dump the oil and it was a whole new process to me.
* Recent Topics
Re: SHO vs Hellcat Redeye
by bamsho | Today at 09:32:46 PM
What rims and tires are you running on the fronts?  You gapped hi...
Re: BamSHO 12.14 MIR Extra Preppy!!
by bamsho | Today at 08:56:08 PM
If you turn up the speakers you can literally hear the tires sticking ...
Re: Need inexpensive tires for my 2013 SHO
by avidmotion | Today at 08:19:45 PM
https://simpletire.com/brands/general-tires/g-max-rs#v=1&tireSize=...
by GotGrip? | Today at 04:24:56 PM
So I was watching this ocean show with my daughter on disney+ and it w...
Re: Whiteline 24mm Adjustable Rear Sway Bar for 2010-2019 Taurus SHO/MKS/Flex/MKT
by SHO_NVS | Today at 02:32:21 AM
I'm in. PM sent...
Re: Water in passenger floor
by SHO_NVS | Today at 02:28:51 AM
Oh man, glad you found it.  Hopefully that fixes it.  I live...
Re: Carbon hood install
by SHO_NVS | Today at 02:23:04 AM
That looks nice! Good job!...
Re: Wheel pulls bad one way then snaps back
by SHO_NVS | Today at 02:18:05 AM
Glad you found that loose bolt, crazy.  How do you like the down ...
Re: And the award for most frequently broken car goes to...
by Macgyver | September 24, 2020, 10:28:06 PM
Oh Boys. Lets hope she holds together !!!...
Re: Daily driver MKT
by TopherSho | September 24, 2020, 08:07:20 PM
:zumbujump: :zumbujump: :zumbujump: :zumbujump: :) :) :)Curious of op...
