August 11, 2020, 03:11:16 PM
Author Topic: Has anyone install custom Hood?  (Read 492 times)
Offline KMAN69
  • Newbie
  • -Given: 0
  • -Received: 3
  • SHO Ecobooster
« on: July 05, 2020, 12:55:00 PM »
I have a 2017 SHO and looking for the Front Lip Air Dam and to see if it will fit. I came across this page with custom hoods anyone have one ?
https://www.bodykits.com/i-31651244-ford-taurus-gt500-v2-duraflex-body-kit-hood-115368.html
Offline 802SHO
  • RotM Winner
  • Essex Junction Vermont
  • -Given: 2271
  • -Received: 1095
  • Boosted
Re: Has anyone install custom Hood?
« Reply #1 on: July 05, 2020, 07:16:53 PM »
Yeah over on SHOForum.  Looks decent from what I could tell
2010 SHO non PP, Tuned by AJP Turbo, Ported GH upgraded turbos, Ported 13+ Exhaust Manifolds, GH upgraded IC, EPP Hot Pipes, EPP Dual CAI, XDI35 HPFP, Deatschwerks LPFP, Alky Control Methonal Injection, Alky dual nozzle upgrade, Zex Nitrous, Dicunzolo Gen2 torque mounts, MSD Coils, SP542 .026, 160 T, 3bar, Catless Downpipes, custom stainless 2.5" double xpipe w/muffler deletes 4" quad tips, UPR Dual Valve Catch Can, Derale 10000 series 16 row trans cooler, 13+ PP Trans Cooler, Econoaid throttle Body Booster, Mickey Thompson 20x9 SC-5 Wheels, Continental Extreme Contact DW tires F: 245/40/20 R: 275/35/20, H&R Springs all around w/rear cut 1/2", 1" hubcentric wheel spacers m14 1.5 stud/lug conversion, Aeroforce Interceptor Gauge.
Highest Trap Speed 123.22 mph
PB 11.368 @ 122.68 NED 10/20/19
Online SM105K
  • IG @egocheckersho
  • Forum Supporters
  • Arizona
  • -Given: 999
  • -Received: 1141
  • Thee Forum Cowboy
« Reply #2 on: July 06, 2020, 11:36:00 AM »
Over on SHOForum member Skyshadow bought the fiberglass hood and said it was junk.
GotGrip is another member on here and over there.  He bought the CF version and we are awaiting what he has to say about it.
If you bought the duraflex front lip, it will not bolt onto the 13+ SHO's.  You will have to take it to a body shop and they will have to graft it onto your lower bumper.
M" 2013 SHO PP | AJPTurbo E30 Tune | FS HPFP | GH Intercooler | PPE Downpipes | Custom Magnaflow Resonator | 3rd Cat Delete | Derale Trans Cooler | Dicunzolo Gen2 Trans Mounts| EPP Noisemaker Eliminator | MSD Coil Over Plugs | SP-542's | UPR Dual Valve Catch Can | K&N Drop In | Power Stop Slotted and Drilled Rotors with Stock PP Pads | H&R Springs  | AVS Flush Deflector | Curva Concept C7's | Continental DWS06 Extreme Contact Rubber |
Offline StealBlueSHO
  • Administrator
  • -Given: 2707
  • -Received: 2736
  • I poke at BPD1151
« Reply #3 on: July 06, 2020, 11:54:45 AM »
There are at least two guys who purchased the fiberglass version. One of who is a friend of mine said his body shop couldn't even fix all the issues. He literally is trying to return it.. not sure where it is..
There is a guy who purchased the CF version and said it was good. The pictures posted looked decent from a fitment standpoint.. at least from a camera lens.
The duraflex front lip is designed for the 2010-2012 vehicles. I spoke to a guy who is running it on his 2015 and he said the only issue was the mounting on backside in the wheel wells... there was a different bolt and a small amount of trimming. But its not a direct bolt on. He did say it was still really easy.
2016 Taurus SHO Performance Pack, Gearhead Custom Tunes, Gearhead Gen3 Turbos, Gearhead Intercooler, Gearhead 170 Tstat, EPP Dual Feed Intake, EPP Hot Pipes, EPP Ceramic Coated Catted Downpipes, Corsa Exhaust, XDI-35 Fuel Pump, DW In-Tank Fuel Pump, Fuel-It Bluetooth Ethanol Analyzer, HR Lowering Springs, AD Lower Trans Mounts, 3Bar MAP, SP-542 Plugs, Custom SHO Puddle Lights, Custom Gearhead emblem overlays. Best time currently is 11.922 @ 115mph full weight, stock wheels, stock tires... just like it came off the show room floor.
Online SM105K
  • IG @egocheckersho
  • Forum Supporters
  • Arizona
  • -Given: 999
  • -Received: 1141
  • Thee Forum Cowboy
« Reply #4 on: July 06, 2020, 01:00:52 PM »
Mine is a complete nightmare, hence why it isnt on the car.  Nothing lines up, and there are gaps in it.  I wonder what it looks like in the front on his 15.  Maybe you could ask him to post pics?
Offline 802SHO
  • RotM Winner
  • -Given: 2271
  • -Received: 1095
  • Boosted
« Reply #5 on: July 07, 2020, 05:18:06 AM »
Looks like this on this car...
Online SM105K
  • IG @egocheckersho
  • Forum Supporters
  • Arizona
  • -Given: 999
  • -Received: 1141
  • Thee Forum Cowboy
« Reply #6 on: July 07, 2020, 09:24:45 AM »
I see that.  I wonder what he did. I must have modified his stock bumper, because it looks different than mine. How did he mount it as well?
  • Administrator
  • -Given: 2707
  • -Received: 2736
  • I poke at BPD1151
« Reply #7 on: July 07, 2020, 09:54:32 AM »
Ford Derrick is the owner, I pinged him back in May of last year.. attached is the screen shot of our quick convo...
"No problem you have to trim 2 spots on each side of the lower grill you will see where its hitting"
"I also installed elevator bolts with epoxy on the back with brackets to reinforce it because I lost one on the highway"
Fun Fun!!
Offline 802SHO
  • RotM Winner
  • -Given: 2271
  • -Received: 1095
  • Boosted
« Reply #8 on: July 07, 2020, 10:17:48 AM »
Yeah it's the biggest downfall of the chin spoiler.  It is not ready for install.  The body shop that did mine reinforced the center with part if a license plate bracket, they also trimmed some of the length.  I basically just had to let them do whatever they wanted.  They also had my bumper, so I had them fill all the rock chips and repaint that at the same time.  They attached pieces of plastic they heated up and bent into clips on the chin spoiler, so it aligns with the existing holes of the lower cladding that gets removed for the chin spoiler.  So it slides in perfectly and I have one bolt on each end, then where the clips are, they drilled holes, once inserted into the bumper slots, I simply thread a Philips head screw in...its never come off.  Attaching the splash guard is also fun bc now there's nothing for the splash guard to attach to in thr front, so I use stainless steel zip ties...(plastic zip ties ripped and I mangled some of the splash guard from dragging it) I attach the stainless steel zip ties into the splash guard then in and out of the plastic slots for the OEM lower cladding and it doesn't budge..tightens up the whole front end with that splash guard.  Bc I've been testing a lot of things recently on my car, I've left the splash guard off, so I can take off and put my front bumper back on ...which I've done 6 or 7 times already.  The whole front end flexes slightly without that splash guard ...and I've done some quarter mile Dragy pulls without the splash guard lol...can't be good for aerodynamics.  Front end is probably like a parachute, catching all the air instead of it flowing under the car lol!  So maybe I'll get a faster Dragy with my splash guard back on...who knows.
Online SM105K
  • IG @egocheckersho
  • Forum Supporters
  • Arizona
  • -Given: 999
  • -Received: 1141
  • Thee Forum Cowboy
« Reply #9 on: July 07, 2020, 11:07:33 AM »
Fun Fun!!
DUDE!!!!!!!!!!!!!!!!  Effing Mike F of the win!!!!!!!!
I was having the same issue with fitment on mine.  Those two pieces he trimmed were completely screwing me up.  On the 2010 to 2012 the bottom lip is flush, on the 13+ it has those two spots.
Offline GotGrip?
  • The work around guy
  • Jr. Member
  • Minnesota
  • -Given: 9
  • -Received: 26
  • The Dude
« Reply #10 on: July 09, 2020, 09:18:31 AM »
I am unfortunately still waiting as mentioned above, there was a mailing/freight issue that I am waiting for them to resolve. Part was sent to my state but was never scanned in before be loaded on the truck. So all I can see is the info was received and no updates on tracking location. Been on the phone with "Pilotdelivers" and man they are awful, probably would have paid the extra to go through someone else to at least have shipping info.
2016 SHO Non-PP, GH/AJP E30 Tune,3Bar MAP, K&N Typoon, EPP Noisemaker Delete, MSD Coils, Catch Can, H&R Springs, ZEDD SL5 19x9.5, PS Drilled/Slotted rotors, TreadStone TR8C FMIC, SSM Trans Mounts, TCE Custom Catted DPs, FMIC Sprayer, XDI35 (in route)
Upcoming - XDI35
Offline 6500rpm
  • Quality Always Shoots Straight
  • Full Member
  • the safe zone just outside St Louis
  • -Given: 50
  • -Received: 104
« Reply #11 on: July 09, 2020, 03:57:41 PM »
I put the chin spoiler  on my 13, required a little profiling in the area between  the driving lights and lower grill mostly. I used a dremel multi tool with the sanding triangle  attachment. It a honeymoon fit for sure but it's  doable. I  also used 3M trim tape at the top and made four z shaped brackets to help stabilize  the bottom since the only two provided mounting points are at the wheel wells. In general, fiberglass sucks imho. The chin spoiler would have been a much better, easier design in plastic. Hopefully the carbon fiber hood gets better  reviews than the fiberglass version.
Edit-Holy Cow 802SHO, I wasn't signed in when I read your post and missed the pics. They went yard on your spoiler-two thumbs up!
« Last Edit: July 11, 2020, 12:35:46 AM by 6500rpm »
2013 SHO PP in Ruby Red Metallic, GTG Billet Grills, Duraflex Racer Chin Spoiler, DriveBright LED Driving/Turn Lights,160 T Stat, MSD Coils, All Royal Purple Lubricants, EPP Gen 2 Duel Intake and hotpipes
* Recent Topics
Re: 802SHO 2010 Build
by GotGrip? | Today at 02:11:34 PM
Are you running 91/93 or e30?...
Re: SCT X4 usage
by StealBlueSho | Today at 12:18:06 PM
I've looked everywhere including the SCT website and can't f...
Re: Ride of The Month - AUGUST 2020!!
by sm105k | Today at 11:35:34 AM
Hes moving awfully slow for sure.....Hahah tough crowd.... geez. ...
Re: Any Explorer Sport intercoolers available?
by Ecoboost_xsport | Today at 08:34:20 AM
Just checking in to see what updates you have for us. Any new developm...
Engine Oil ?
by joe raptor | August 10, 2020, 04:43:40 PM
Hey brothers what do you guys think about using "Liqui Moly"...
Re: Wheel pulls bad one way then snaps back
by 402Sho | August 10, 2020, 01:57:56 PM
Yes I wrote a review on yelp and got contacted by the head office for ...
by ChrisxHowe | August 10, 2020, 12:14:51 PM
Intercooler pipes arrived today and I also started reforming the lower...
Re: door delaminated
by jims2015 | August 10, 2020, 11:04:31 AM
finally after 6.5 yrs my passenger door lining delaminated. I understa...
Re: can we add an aviator forum?
by sm105k | August 10, 2020, 10:55:55 AM
posted this in New member area as well. Just found this forum.Let me g...
by xkrexplorer | August 09, 2020, 06:14:06 PM
spent 6.5 hours putting car back to stock to sell it. Aviator gt on or...
Back to top
