August 11, 2020, 02:26:55 PM
Author Topic: Finally bought an XDI35 HPFP  (Read 383 times)
Offline bamsho
  • south williamsport, pa
  • -Given: 197
  • -Received: 514
« on: July 01, 2020, 06:13:55 AM »
Well I finally broke down and pulled the trigger and bought an XDI35 HPFP.  Received my new tune files and installed everything.  Fairly easy install except for try the bend the high pressure line a little to fit into the new pump.
Loaded tunes and the checked for leaks then took the wife and I took the car for a ride.  I turned off the meth system.  We were amazed when I punched it and nice to see negative knock at WOT.
Did an test launch on the road up to our house.  Left at 2200 and car did a quick chirp of the front tire, and she was gone.  Sure felt faster, I saw the speedo higher at the point I let off.
I will find out this Friday if my butt was correct, going to the track for testing.
Oh pics if old and new pump
Offline bamsho
  • -Given: 197
  • -Received: 514
Re: Finally bought an XDI35 HPFP
« Reply #1 on: July 01, 2020, 06:28:25 AM »
Oh on a side note, my tunes were delayed due to SCT updating.  Matt told me that he now has fuel pump parameters for my strategy.  Hopefully they did it for other ones too.
Offline 76fomoco
  • Full Member
  • Nampa, ID
  • -Given: 75
  • -Received: 141
  • Rabbit Hole master
« Reply #2 on: July 01, 2020, 09:44:11 AM »
they did it for my strategy too. It fixed the problem.
2013 PP AJP 93 +meth 160 TS, sp542 plugs, 3 bar, PPE catted DP's, GH IC, GH turbos, XDI-35
Best 5-16-2020  12.40 with 3850 DA trap best 116.79
E30 = 415 whp & 470 before GH turbos and xdi-35
current tunes: AJP 93, 93+meth, E30 :) GH E30
Offline ridered74
  • RotM Winner
  • Full Member
  • -Given: 145
  • -Received: 198
    • Ken Kyle Racing
« Reply #3 on: July 01, 2020, 11:21:50 AM »
Good news is now that the line is bent, it will be much easier to get back on anytime you need to disconnect it. I put off doing plugs because of how much of a PITA mine was, but it went surprisingly smooth getting it back on the 2nd time.
I squeezed a 12.48 out of my AO tune with dragy, but that was before I got any revisions for it and had really good DA. Can't seem to switch over from E30 tune long enough to try it again. I think you will definitely be satisfied with the purchase tho!
Firestorm hpfp, catted downpipes, Corsa catback, 160 degree thermostat, 3 bar map, Gearhead E30 tune, Gearhead intercooler, upgraded trans mounts and EPP intake.
12.2479 @ 118.05 fastest trap
11.7513 @ 117.04   fastest ET
Offline bamsho
  • -Given: 197
  • -Received: 514
« Reply #4 on: July 01, 2020, 03:55:40 PM »
I loaded the E30 tune right off.  Going to use the AO tune for when we go on trips.
Offline ridered74
  • RotM Winner
  • Full Member
  • -Given: 145
  • -Received: 198
    • Ken Kyle Racing
« Reply #5 on: July 01, 2020, 11:27:31 PM »
Oh you are really going to like the E30 tune.
Offline bamsho
  • -Given: 197
  • -Received: 514
« Reply #6 on: July 03, 2020, 10:41:16 PM »
Here are my slips from tonight's test session with the new XDI35 pump.  First was freakin hot today, ambient was 94, with high humidity, with 3800 DA YUCK!!  Also AIT2 was least 150 degrees at the line, but overvall I was very pleased with each run.  First run 12.57 I wasn't spraying meth, next 3 I had to just cause it was just so hot.  As you see it was getting faster each pass.
Couple weeks earlier weather was low 70s, low humidity and 1800 DA.  I ran 12.42, 12.38, that was with the stock HPFP.  To get this close to those numbers in these conditions today, shows me, there is def more in her.  Also I ran with the intial tune, no tweeks to it yet.
Thanks again to the guys at Gearhead, 👍👍.
So side not, I made it into the fast 8 for tonight, I was number 6.  It was a money race, but mother nature decided to send the rain and ruined the night.
Offline bamsho
  • -Given: 197
  • -Received: 514
« Reply #7 on: July 03, 2020, 10:42:00 PM »
Here is a comparison slips.  There is an 20 degree ambient temp difference between the two.
Offline 802SHO
  • RotM Winner
  • Essex Junction Vermont
  • -Given: 2271
  • -Received: 1095
  • Boosted
« Reply #8 on: July 05, 2020, 08:04:23 PM »
If you're 60 ft would have been the same you would have beat it even with 20 hotter.  So that's very good to see
2010 SHO non PP, Tuned by AJP Turbo, Ported GH upgraded turbos, Ported 13+ Exhaust Manifolds, GH upgraded IC, EPP Hot Pipes, EPP Dual CAI, XDI35 HPFP, Deatschwerks LPFP, Alky Control Methonal Injection, Alky dual nozzle upgrade, Zex Nitrous, Dicunzolo Gen2 torque mounts, MSD Coils, SP542 .026, 160 T, 3bar, Catless Downpipes, custom stainless 2.5" double xpipe w/muffler deletes 4" quad tips, UPR Dual Valve Catch Can, Derale 10000 series 16 row trans cooler, 13+ PP Trans Cooler, Econoaid throttle Body Booster, Mickey Thompson 20x9 SC-5 Wheels, Continental Extreme Contact DW tires F: 245/40/20 R: 275/35/20, H&R Springs all around w/rear cut 1/2", 1" hubcentric wheel spacers m14 1.5 stud/lug conversion, Aeroforce Interceptor Gauge.
Highest Trap Speed 123.22 mph
PB 11.368 @ 122.68 NED 10/20/19
Offline bamsho
  • -Given: 197
  • -Received: 514
« Reply #9 on: July 05, 2020, 10:30:50 PM »
Yeah, this has been one of the few times I have gone to the track with a major change and been pleased with the results.  I actually had to up tire pressures cause the track had lots of grip.
* Recent Topics
Re: 802SHO 2010 Build
by GotGrip? | Today at 02:11:34 PM
Are you running 91/93 or e30?...
Re: SCT X4 usage
by StealBlueSho | Today at 12:18:06 PM
I've looked everywhere including the SCT website and can't f...
Re: Ride of The Month - AUGUST 2020!!
by sm105k | Today at 11:35:34 AM
Hes moving awfully slow for sure.....Hahah tough crowd.... geez. ...
Re: Any Explorer Sport intercoolers available?
by Ecoboost_xsport | Today at 08:34:20 AM
Just checking in to see what updates you have for us. Any new developm...
Engine Oil ?
by joe raptor | August 10, 2020, 04:43:40 PM
Hey brothers what do you guys think about using "Liqui Moly"...
Re: Wheel pulls bad one way then snaps back
by 402Sho | August 10, 2020, 01:57:56 PM
Yes I wrote a review on yelp and got contacted by the head office for ...
by ChrisxHowe | August 10, 2020, 12:14:51 PM
Intercooler pipes arrived today and I also started reforming the lower...
Re: door delaminated
by jims2015 | August 10, 2020, 11:04:31 AM
finally after 6.5 yrs my passenger door lining delaminated. I understa...
Re: can we add an aviator forum?
by sm105k | August 10, 2020, 10:55:55 AM
posted this in New member area as well. Just found this forum.Let me g...
by xkrexplorer | August 09, 2020, 06:14:06 PM
spent 6.5 hours putting car back to stock to sell it. Aviator gt on or...
Back to top
