Racing Department
Dyno Results
First dyno for the sleeper sedan
Started by WinPlaceSHO, April 13, 2020, 11:01:58 AM
Forum Supporters
Re: First dyno for the sleeper sedan
#15
April 13, 2020, 08:59:06 PM
Last Edit
: April 13, 2020, 09:08:06 PM by SHOdded
1:1 is the last gear before overdrive, 5th in this case.
http://www.nicksmustangranch.com/Service_Manuals/2014/2014_Taurus/Service%20Manual.htm
Gear Ratio Chart
Gear Ratio
1st/low 4.484:1
2nd 2.872:1
3rd 1.842:1
4th 1.414:1
5th 1:1
6th 0.742:1
Reverse 2.882:1
76fomoco
Full Member
Rabbit Hole master
#16
April 14, 2020, 09:56:20 AM
almost the same mods as you with AJP E30 on stock hpfp and stock IC I put 415hp and 470 tq on a mustang dyno and the car run 12.5 with 3500 DA at 70 * you can adjust about .1 per 1000' of DA
2013 PP AJP E30 160 TS, sp542 plugs, 3 bar, PPE catted DP's, GH IC, GH turbos, XDI-35, EPP hot and intake
Best 3-29-21 11.85 with 3000 DA
DA trap best 117.96
E30 = 492 whp, 536 wtq
E30+meth 498 whp, 539 wtq
Racing Department
Dyno Results
