July 09, 2020, 11:15:54 PM
Author Topic: Stock BOV O-ring ?  (Read 257 times)
Offline StinkinLinkin13
  • Sr. Member
  • San Antonio, Texas
  • Thank You
  • -Given: 60
  • -Received: 172
  • Ecoboosted
Stock BOV O-ring ?
« on: April 06, 2020, 01:14:59 PM »
I had a boost leak from this o-ring. Is there a standalone replacement available? So far all I find is the entire BOV. I have some spare bovs so just the o-rings is what I need.
Livernois Catless downpipes with Magnaflow mufflers - Livernois E85 tune - Firestorm HPFP - 3 Bar Map - Alky Controls Meth Injection - 160 Thermostat - EPP Hot Pipes - AEM Dryflow Filter - BOV VTA - SSM Polyurethane Torque Struts - H&R Sport Springs - 20"x10" Niche Veronas on 275/40-20 DWS06 -
Offline Cole.C
  • Jr. Member
  • Thank You
  • -Given: 116
  • -Received: 27
  • Ecobooster
Re: Stock BOV O-ring ?
« Reply #1 on: April 06, 2020, 01:30:44 PM »
Nitrile Rubber O Ring Kit O Rings Assortment Kit Set 24Sizes 1200Pcs Oil Resistant NBR Metric O-Ring Sealing Assortment Kit for Air Plumbing, Fuel Injector and Faucet Seal O Rings https://www.amazon.com/dp/B07QFVCNSN/ref=cm_sw_r_other_apa_i_ox2IEb14JKE2E
Finding a o ring labeled for the specific use is probably difficult. Sure one of these would work for you and all your future o ring needs, Good luck!
Offline ridered74
  • RotM Winner
  • Full Member
  • Thank You
  • -Given: 125
  • -Received: 172
    • Ken Kyle Racing
« Reply #2 on: April 06, 2020, 01:32:09 PM »
Same here. Have not had any luck so far finding one specific to our car. I was thinking about just trying to find one the same size and see what happens, but I don't want to risk damaging the o rings on my brand new blow off valves by swapping them out.
Firestorm hpfp, catted downpipes, Corsa catback, 160 degree thermostat, 3 bar map, Gearhead E30 tune, Gearhead intercooler, upgraded trans mounts and EPP intake.
12.2479 @ 118.05 fastest trap
11.7513 @ 117.04   fastest ET
Offline Jordan
  • Elite Member
  • Columbia, Mo
  • Thank You
  • -Given: 224
  • -Received: 643
  • I'm the captain of this SHIP
« Reply #3 on: April 06, 2020, 04:33:58 PM »
A universal o-ring kit won't work. You need an extremely thin wide gasket. I searched and searched and ended up buying another stock BOV because of a tear in mine. $50 for a BOV through ford. I am sure you can find one just depends on how much you want to search. Let us know what you find.
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • Elite Member
  • New York SHO
  • Thank You
  • -Given: 1935
  • -Received: 4070
« Reply #4 on: April 06, 2020, 06:57:52 PM »
There are no interchangeable parts AFAIK. Z
It seems the prices fortunately have dropped on the BOV!!  :) Best of luck. .
$35.80
Turbocharger Boost Pressure Relief Valve - Ford (AA5Z-9U465-A)
https://www.tascaparts.com/oem-parts/ford-turbocharger-boost-pressure-relief-valve-aa5z9u465a/?c=Zz1jb29saW5nLXN5c3RlbSZzPWludGVyY29vbGVyJmk9TUExNTEwNDUmcj0xMiZhPWZvcmQmbz10YXVydXMmeT0yMDEzJnQ9c2hvJmU9My01bC12Ni1nYXM%3D
« Last Edit: April 06, 2020, 07:02:37 PM by ZSHO »
  • Sr. Member
  • Thank You
  • -Given: 60
  • -Received: 172
  • Ecoboosted
« Reply #5 on: April 06, 2020, 08:11:37 PM »
Well that sucks a$$... I've got 2 spare bovs and they both have worn or damaged orings. Keep you posted should I find something.
Back to top
