July 03, 2020, 12:01:57 PM
Author Topic: Help with aftermarket bov epp hotpipes  (Read 336 times)
Offline Cole.C
  • Jr. Member
  • Thank You
  • -Given: 116
  • -Received: 27
  • Ecobooster
« on: April 04, 2020, 12:01:37 PM »
Need help Thought i might try asking here, installing some EPP hotpipes and with the aftermarket bovs vacuum line Mike said to tap into the brake booster line behind the throttlebody but in my car it is a hard plastic line most the way back(outlined in red)into a larger1/2" pipe (outlined in blue) with a much larger ID then 1/16th inch. I havent heard back from mike on whether i could tap into this line(outlined in green) in front of the intake it seems to be on the intake piping similiar to the brake booster line.  Any opinions on if its safe to do so or what anyone recommends would be appreciated! Thanks guys.
Offline Nova
  • Full Member
  • Thank You
  • -Given: 61
  • -Received: 77
  • Ecobooster
Re: Help with aftermarket bov epp hotpipes
« Reply #1 on: April 04, 2020, 12:37:14 PM »
Read this, its helpful and should answer the questions you have.
http://www.ecoboostperformanceforum.com/index.php?topic=9409.0
« Last Edit: April 04, 2020, 12:41:31 PM by Nova »
Offline Cole.C
  • Jr. Member
  • Thank You
  • -Given: 116
  • -Received: 27
  • Ecobooster
« Reply #2 on: April 04, 2020, 05:30:57 PM »
So do you know if i just cap off the oem recirculating bov inlets into the intake? Will i throw codes without a tune revision having just unplugged the oem bov sensors?
Thanks for the help!
Offline Nova
  • Full Member
  • Thank You
  • -Given: 61
  • -Received: 77
  • Ecobooster
« Reply #3 on: April 04, 2020, 06:29:23 PM »
Yes you cap the recirculation inlets with rubber leg tips from home depot. I'll link a YouTube video showing how to cap off the recirc inlets.
If I'm not mistaken you have to have the rear bov plugged in and zip tied off to the side so that it won't be just hanging by the wire, and the front bov doesn't need to be plugged in. In doing this it won't throw any codes and no tune is needed.
Sent from my SM-G986U using Tapatalk
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • Elite Member
  • New York SHO
  • Thank You
  • -Given: 1934
  • -Received: 4069
« Reply #4 on: April 04, 2020, 07:51:38 PM »
1." inch OD silicone high temp caps are ideal. I would avoid the leg end caps as they are not suitable for high temps and will sooner than later fall apart. Z
https://www.mcmaster.com/caps/
https://www.ecoboostperformanceforum.com/index.php/topic,8616.0.html
https://www.ecoboostperformanceforum.com/index.php/topic,8616.75.html
« Last Edit: April 04, 2020, 09:47:43 PM by ZSHO »
Offline FiveLeeter918
  • Ortiz Performance - Technical Sales
  • Vendor
  • Sr. Member
  • Tulsa, OK
  • Thank You
  • -Given: 18
  • -Received: 251
  • Bewsted SHO
    • Ortiz Tuning and Performance
« Reply #5 on: April 17, 2020, 12:52:32 AM »
I prefer the TurboSmart Boost Reference Adapter, it goes under the MAP sensor on the intake manifold and it's a much cleaner install IMHO.
https://www.ortizperformance.com/product-page/turbosmart-boost-reference-adapter-2010-3-5l-ecoboost-black
And I personally had chair caps for 2 years before the EPP dual intake and never had an issue. I replaced them twice just out of peace of mind but never leaked.
- Lee
Ortiz Performance Vendor Forum | Find us on Facebook! | Shop Today!
* Recent Topics
Re: New member Omaha, Nebraska
by BigGrey150 | July 02, 2020, 08:15:35 PM
I actually live in bellevue on the north east side of the base. I just...
Forum Stickers
by StealBlueSho | July 02, 2020, 01:47:07 PM
EBPF Family..Anyone have any recommendations on who to go through for ...
Re: Ride of The Month - July 2020!!
by WinPlaceSHO | July 02, 2020, 01:34:42 PM
I'll bite... it's a good ole fashioned SHO down, mine is the...
Re: B1086- Air Distribution Damper Motor - Panel/floor/defrost not working
by Gjkrisa | July 02, 2020, 01:19:45 PM
New panel worked think I cracked part of the new facia trying to take ...
Re: DannyMack 13 MKS "Old Man" Build and Maintenance Thread
by Dannymack | July 02, 2020, 01:17:24 PM
Quick update. Been enjoying the car in its current form for a couple m...
Re: Help! Removal of Rear Turbo
by 802SHO | July 02, 2020, 12:18:51 PM
Thanks to you guys for all the tips. I wasn't sure about the knuc...
Re: 2015 Ford Explorer Sport - AC Compressor Not Starting
by lotusnotes | July 02, 2020, 12:07:40 PM
So I figured this out - whoever mounted the light bar on this truck be...
Re: TASCA=Fail....
by nickstewartroc | July 02, 2020, 12:01:03 PM
I usually use tasca to look up part numbers.  And then go to my l...
Re: So Lets start some banter
by nickstewartroc | July 02, 2020, 11:59:05 AM
+1 on the FiST. Love mine, going on 5 years now with it, upgraded turb...
Re: 2020 June RoTM Winner!!!
by StealBlueSho | July 02, 2020, 10:34:19 AM
Sweet!! I'll PM you my address so you can send me the trophy and ...
Back to top
