July 04, 2020, 11:44:51 AM
Author Topic: Ethanol analyzer  (Read 386 times)
Offline WinPlaceSHO
  • Forum Supporters
  • Jr. Member
  • East side of the L.B.C. On a mission trying to find Mr. Warren G
  • -Given: 44
  • -Received: 25
Ethanol analyzer
« on: March 29, 2020, 10:06:53 AM »
Ok, what is the red part called on this, I'll need a new one because when I touched it I broke it, and how do I get it apart to add the ethanol analyzer?
Thanks!
Sent from my SM-N960U using Tapatalk
Black 2018 SHO Non-PP | GH e30/AO Tune | PPE Catted Downpipes | Dicunzolo Gen2 Trans Mount | SP-542's | 170 Tstat | 3 bar | K&N drop in | H&R Springs | XDI-35 | Badges removed  | Chrome delete
On deck: GH IC, EPP CAI, Noisemaker delete, MSD coils
Offline ridered74
  • RotM Winner
  • Full Member
  • -Given: 121
  • -Received: 160
Re: Ethanol analyzer
« Reply #1 on: March 29, 2020, 02:22:34 PM »
Thanks!
Watch some youtube videos on disconnecting fuel lines. Helps to have a fuel line disconnect tool You can get a set at harbor freight for 10 bucks or so.
That red piece is a clip and there should be a second one on the underside. I believe before broken, the red pieces on top and bottom are actually one piece but I don't remember for sure. There is a push tab that releases it and allows it to slide out. After that you use a fuel line disconnect tool to disconnect the fuel line.
Firestorm hpfp, catted downpipes, Corsa catback, 160 degree thermostat, 3 bar map, Gearhead E30 tune, Gearhead intercooler and upgraded trans mounts.
12.2479 @ 118.05 fastest trap
11.7513 @ 117.04   fastest ET
Offline WinPlaceSHO
  • Forum Supporters
  • Jr. Member
  • -Given: 44
  • -Received: 25
« Reply #2 on: March 29, 2020, 04:44:32 PM »
Ok, my "Google-Fu" wasn't working yesterday, but I finally found it -- Common fuel connectors.  There is that red retaining clip, then you just push on the one side, and it comes off.  Now I just have to figure out what that red retaining clip is called so I can get it replaced.
Offline FiveLeeter918
  • Ortiz Performance - Technical Sales
  • Vendor
  • Sr. Member
  • Tulsa, OK
  • -Given: 18
  • -Received: 251
  • Bewsted SHO
    • Ortiz Tuning and Performance
« Reply #3 on: May 29, 2020, 01:39:45 AM »
The red clip has no function other than to say "hey, I'm important, are you sure you want to remove me?"
Remove it, then push in on that rectangle on the underside and it will pull off.
- Lee
Back to top
