July 04, 2020, 10:21:17 AM
Author Topic: Bolt torque specs for front and rear transmission mounts?  (Read 5270 times)
Offline 10ECOMKS
  • Jr. Member
  • Thank You
  • -Given: 0
  • -Received: 21
  • Ecobooster
« on: March 03, 2020, 06:26:59 PM »
Anyone have this info that could pass along?
Offline ridered74
  • RotM Winner
  • Full Member
  • Thank You
  • -Given: 121
  • -Received: 160
Re: Bolt torque specs for front and rear transmission mounts?
« Reply #1 on: March 03, 2020, 11:25:57 PM »
Mine came with that info. If I remember right it was 80 ft/lbs. Been awhile tho so I could be wrong. Weird that you didn't get that info with yours.
Firestorm hpfp, catted downpipes, Corsa catback, 160 degree thermostat, 3 bar map, Gearhead E30 tune, Gearhead intercooler and upgraded trans mounts.
12.2479 @ 118.05 fastest trap
11.7513 @ 117.04   fastest ET
Offline 10ECOMKS
  • Jr. Member
  • Thank You
  • -Given: 0
  • -Received: 21
  • Ecobooster
« Reply #2 on: March 04, 2020, 12:00:51 AM »
Thanks ridered74. I should be getting my set this Friday. I wasn't sure if they would come with the torque specs or not, so I wanted to ask ahead of time. I didn't recall seeing anyone post it and I'm a stickler when it comes to proper torquing.
Offline SM105K
  • IG @egocheckersho
  • Forum Supporters
  • Elite Member
  • Arizona
  • Thank You
  • -Given: 929
  • -Received: 1091
  • Thee Forum Cowboy
« Reply #3 on: March 04, 2020, 07:57:46 AM »
I went with 4 ugga duggas.
"M" 2013 SHO PP | AJPTurbo E30 Tune | GH Intercooler | PPE Downpipes | Custom Magnaflow Resonator | 3rd Cat Delete | Dicunzolo Gen2 Trans Mounts| EPP Noisemaker Eliminator | MSD Coil Over Plugs | SP-542's | UPR Dual Valve Catch Can | K&N Drop In | Power Stop Slotted and Drilled Rotors with Stock PP Pads | H&R Springs  | Curva Concept C7's | Continental DWS06 Extreme Contact Rubber |
"The Fukus" 2013 Focus ST | AJPTurbo Flex Fuel Tune | Megan Racing Catless Downpipe | Boomba BOV | FSWerks Short Shifter | Power Stop Brakes | Continental DWS06 Extreme Contact Rubber |
Offline 10ECOMKS
  • Jr. Member
  • Thank You
  • -Given: 0
  • -Received: 21
  • Ecobooster
« Reply #4 on: March 04, 2020, 08:58:05 AM »
4 ugga duggas seems about right...... With the correct number of beers consumed and properly correlated calibration of ugga dagga, that should work out to exactly 80ft/lbs.   :biggrin:
Offline SM105K
  • IG @egocheckersho
  • Forum Supporters
  • Elite Member
  • Arizona
  • Thank You
  • -Given: 929
  • -Received: 1091
  • Thee Forum Cowboy
« Reply #5 on: March 04, 2020, 09:29:03 AM »
My man!
Offline ridered74
  • RotM Winner
  • Full Member
  • Thank You
  • -Given: 121
  • -Received: 160
« Reply #6 on: March 04, 2020, 08:03:20 PM »
I've been racking my brain trying to remember, but I'm old as dirt so that didn't go well. I feel like it was either 80 or 105 but I didn't save the instructions and don't remember for sure. If yours don't come with the specs I would try 80 first and if there is a lot of NVH maybe tighten it up to 105. Pretty sure 80 is 2 ugga duggas and 105 would be right about 4 ugga duggas.
Offline 10ECOMKS
  • Jr. Member
  • Thank You
  • -Given: 0
  • -Received: 21
  • Ecobooster
« Reply #7 on: March 12, 2020, 04:55:16 PM »
Thanks for your input ridered74. Mine didn't come with torque specs, so I torqued them to 80ft/lbs. ...It felt right. It didn't take much to brake the bolts loose
Offline 10ECOMKS
  • Jr. Member
  • Thank You
  • -Given: 0
  • -Received: 21
  • Ecobooster
« Reply #8 on: March 23, 2020, 06:40:32 PM »
For anyone interested...the factory torque spec for the (4) 15mm front and rear mount bolts is 66ft/lbs on the frame sides (farthest forward and farthest rear) and 76 ft/lbs for the bolts that are on the engine/transaxle sides of the mounts.
« Last Edit: March 31, 2020, 07:03:00 PM by 10ECOMKS »
Offline avidmotion
  • Sr. Member
  • Thank You
  • -Given: 5
  • -Received: 86
  • Ecobooster
« Reply #9 on: May 08, 2020, 01:45:30 AM »
....miss placed uggga torque wrench, but is it 80 lbs then for the 2nd gen AD mounts?
Offline avidmotion
  • Sr. Member
  • Thank You
  • -Given: 5
  • -Received: 86
  • Ecobooster
« Reply #10 on: May 09, 2020, 01:07:55 AM »
Anyone have torque specs on the 2nd gen AD wishbones?
Offline avidmotion
  • Sr. Member
  • Thank You
  • -Given: 5
  • -Received: 86
  • Ecobooster
« Reply #11 on: May 20, 2020, 06:30:11 PM »
Ok then.....ill try 80 lbs.....
* Recent Topics
Re: New Moderator
by ZSHO | Today at 08:05:01 AM
Congrats E!  I have not been active much but Great to see others ...
Re: New member Omaha, Nebraska
by FearlessAZ | Today at 04:50:17 AM
Welcome to the forum!Love that color. Was that a factory color or some...
Re: Finally bought an XDI35 HPFP
by bamsho | July 03, 2020, 10:42:00 PM
Here is a comparison slips.  There is an 20 degree ambient temp d...
Re: Ride of The Month - July 2020!!
by Dannymack | July 03, 2020, 06:29:59 PM
Going for round #2.2013 MKSAJP E30Godspeed SpringsBunch of Aesthetic M...
Forum Stickers
by StealBlueSho | July 02, 2020, 01:47:07 PM
EBPF Family..Anyone have any recommendations on who to go through for ...
Re: B1086- Air Distribution Damper Motor - Panel/floor/defrost not working
by Gjkrisa | July 02, 2020, 01:19:45 PM
New panel worked think I cracked part of the new facia trying to take ...
Re: DannyMack 13 MKS "Old Man" Build and Maintenance Thread
by Dannymack | July 02, 2020, 01:17:24 PM
Quick update. Been enjoying the car in its current form for a couple m...
Re: Help! Removal of Rear Turbo
by 802SHO | July 02, 2020, 12:18:51 PM
Thanks to you guys for all the tips. I wasn't sure about the knuc...
Re: 2015 Ford Explorer Sport - AC Compressor Not Starting
by lotusnotes | July 02, 2020, 12:07:40 PM
So I figured this out - whoever mounted the light bar on this truck be...
Re: TASCA=Fail....
by nickstewartroc | July 02, 2020, 12:01:03 PM
I usually use tasca to look up part numbers.  And then go to my l...
Back to top
