July 03, 2020, 01:35:34 PM
Author Topic: BBK 3.5L/3.7L V6 70MM THROTTLE BODY for 10-19 SHO/FLEX/MKS  (Read 548 times)
Offline autobahn terror
  • Full Member
  • Germany
  • Thank You
  • -Given: 12
  • -Received: 54
« on: March 26, 2020, 10:50:18 AM »
I hate to be starting yet another Throttle body thread... But I have questions to ask of you smart folks before i decide to spend more hard earn cash on another damn TB.
Are the Throttle Blade Shaft Seals better on the BBK then Stock? Do you have to modify the Wire Harness to accommodate the upside down installation requirement?
Is this damn TB worth the $330+? Here is my problem, If i get on the throttle to hard/fast, I will "overboost" and blow out the Throttle return spring cover. This creates a boost leak, and allow contamination of the Drive by Wire motor assembly, eventually throwing codes and putting the car into limp mode.
From the photos over at Ortiz Motorsports, https://www.ortizperformance.com/product-page/bbk-mustang-v6-70mm-throttle-body-05-10, it looks like the BBK comes without the DBW Motor assembly, which is problem one for me, as the two i have are already missing the Return Spring Cover.
Thoughts?
2014 PP, Dicunzolo Gen2 Mounts, Gear Head Intercooler, EcoPowerParts Charge Pipes w/Meth Bung @1GPH, Hennessy KnN CAI W/RECIRC, Alky controls meth injection, Lightly Ported Intake drilled and tapped for Port Meth Injection 1GPH per Cylinder, ATP Turbos, American Racing CAT'ed down pipes aka 'livernois', Corsa CAT Back, 160TSTAT, 3BAR MAP, Stock Ignition coils, SP542 plugs .028, UPR Catch Can, MEGAN Coilovers,  Power Stop Z23 Brake Kit, 93octane Dynotune @ 430AWHP/430AWTQ by National Speed in Wilmigton NC
Offline Macgyver
  • Super Moderator
  • Elite Member
  • Reading, Pa.......
  • Thank You
  • -Given: 94
  • -Received: 314
  • Ecobooster
Re: BBK 3.5L/3.7L V6 70MM THROTTLE BODY for 10-19 SHO/FLEX/MKS
« Reply #1 on: March 26, 2020, 11:07:34 PM »
Well most guys would say. Before you see any benefit from a TB. You will break something in the drive line.
  • Full Member
  • Germany
  • Thank You
  • -Given: 12
  • -Received: 54
« Reply #2 on: March 28, 2020, 04:35:57 AM »
That's funny considering I already have broken a Prop Shaft...
Im looking for reliability in this case, a boost leak is a boost leak, and when it causes the TB to stop functioning correctly and throwing codes, or worse, stick open... Its a problem...
I could have swore I read somewhere on the forum a while back that someone had one but they got rid of it
« Last Edit: March 28, 2020, 04:43:00 AM by autobahn terror »
Offline Jordan
  • Elite Member
  • Columbia, Mo
  • Thank You
  • -Given: 224
  • -Received: 643
  • I'm the captain of this SHIP
« Reply #3 on: March 28, 2020, 08:21:26 AM »
I've never heard of anybody having issues on the stock throttle body. Heck, I don't have an upgraded one either. Seems non essential to me.
Offline FiveLeeter918
  • Ortiz Performance - Technical Sales
  • Vendor
  • Sr. Member
  • Tulsa, OK
  • Thank You
  • -Given: 18
  • -Received: 251
  • Bewsted SHO
    • Ortiz Tuning and Performance
« Reply #4 on: April 17, 2020, 12:49:51 AM »
To answer the specific questions, no wiring changes needed to accomodate, the reason to flip is actually because in the Mustang orientation the butterfly opens the other direction and the motor is on the outside. Plugs are the same though.
I replaced mine due to the same issue on my stock TB. I was leaking crazy boost from a blown seal in the stock unit, along with the adjuster screw dryrotting and causing a leak as well.
While it offers no performance benefit that I've seen, it is a much better built component.
Even as a dealer I couldn't justify the cost, but managed to find an "open box" item on eBay for $120 so I snagged it. They then lost it and sent me a brand new one for the same price, so it worked out even better.
Hope you get your issues taken care of!
- Lee
Ortiz Performance Vendor Forum | Find us on Facebook! | Shop Today!
  • Full Member
  • Germany
  • Thank You
  • -Given: 12
  • -Received: 54
« Reply #5 on: April 22, 2020, 10:29:36 AM »
Thanks for the info man, Does it come with a Drive By Wire motor assembly or do i need to move my existing one over?
  • Vendor
  • Sr. Member
  • Tulsa, OK
  • Thank You
  • -Given: 18
  • -Received: 251
  • Bewsted SHO
« Reply #6 on: April 22, 2020, 02:48:03 PM »
You will swap over and calibrate your existing motor to the new body.
- Lee
* Recent Topics
Re: New member Omaha, Nebraska
by BigGrey150 | July 02, 2020, 08:15:35 PM
I actually live in bellevue on the north east side of the base. I just...
Forum Stickers
by StealBlueSho | July 02, 2020, 01:47:07 PM
EBPF Family..Anyone have any recommendations on who to go through for ...
Re: Ride of The Month - July 2020!!
by WinPlaceSHO | July 02, 2020, 01:34:42 PM
I'll bite... it's a good ole fashioned SHO down, mine is the...
Re: B1086- Air Distribution Damper Motor - Panel/floor/defrost not working
by Gjkrisa | July 02, 2020, 01:19:45 PM
New panel worked think I cracked part of the new facia trying to take ...
Re: DannyMack 13 MKS "Old Man" Build and Maintenance Thread
by Dannymack | July 02, 2020, 01:17:24 PM
Quick update. Been enjoying the car in its current form for a couple m...
Re: Help! Removal of Rear Turbo
by 802SHO | July 02, 2020, 12:18:51 PM
Thanks to you guys for all the tips. I wasn't sure about the knuc...
Re: 2015 Ford Explorer Sport - AC Compressor Not Starting
by lotusnotes | July 02, 2020, 12:07:40 PM
So I figured this out - whoever mounted the light bar on this truck be...
Re: TASCA=Fail....
by nickstewartroc | July 02, 2020, 12:01:03 PM
I usually use tasca to look up part numbers.  And then go to my l...
Re: So Lets start some banter
by nickstewartroc | July 02, 2020, 11:59:05 AM
+1 on the FiST. Love mine, going on 5 years now with it, upgraded turb...
Re: 2020 June RoTM Winner!!!
by StealBlueSho | July 02, 2020, 10:34:19 AM
Sweet!! I'll PM you my address so you can send me the trophy and ...
Back to top
