September 25, 2020, 09:22:26 PM
Author Topic:  Any Explorer Sport intercoolers available?  (Read 6946 times)
Online Ecoboost_xsport
  • 2015 Ford Explorer Sport
  • Full Member
  • Orangevale, CA
  • -Given: 46
  • -Received: 57
  • Mad Scientist
    • The Workshop
  • Liked:
  • Likes Given: 0
Re: Any Explorer Sport intercoolers available?
« Reply #60 on: August 11, 2020, 08:34:20 AM »
Just checking in to see what updates you have for us. Any new developments? Anything you would do different?
Sent from my SM-G965U1 using Tapatalk
IG: ecoboost_xsport
Airaid CAI | ATP +2 Garret Turbo Upgrade | Big Head Motorsports Catless Turbo-Back Exhaust | MSD Ignition Coils | XDI-60 HPFP | FoMoCo 3bar MAP | DeatschWerks DW300c LPFP | UPR Catch Can |  AD Gen 2 Torque Mounts | Braille i25X Lithium Battery | Brisk Silver Racing RR12YS Plugs (0.26 Gap) | EPP Hot Pipes | Tial Sport QR 50mm VTA BOV | 160į Livernois Thermostat | H&R Super Sport Lowering Springs | Wilwood 15.00" Front Rotors  | Wilwood 14.25" Rear Rotor | Wilwood W4A Front & Rear Calipers | Advan GT Premium Wheels 20x11-15mm | Hankook Ventus ST RH06 295/45-20 | Bilstein B6 Front Struts | Bilstein B6 Rear Shocks | Steeda Rear Sway Bar | Steeda Rear Toe Links | Steeda Rear Trailing Arm | SPC Front & Rear Camber Adjustment Bolts | Innovate Motorsports MTX-D Ethanol Content Gauge w/GM 13577429 Flex Fuel Sensor | Redline Tuning Hood Struts | FoMoCo PI Rear X-Brace | Diode Dynamics SS3 Pro Yellow LED Foglights | Custom RaceSeng Front Tow Hook | WR: 3rd Row Seat Removed | SCT Livewire TS+ | 100 OCT AJPTurbo Tune
Offline xartic1
  • Jr. Member
  • -Given: 2
  • -Received: 18
  • Twin Turbskies
  • Liked:
  • Likes Given: 0
« Reply #61 on: August 11, 2020, 08:22:10 PM »
I can say with certainty that the intercooler is definitely an improvement. I've been monitoring the temps at the intake, after the intercooler and at the manifold more this past week. The temperature after the intercooler will hover right around the air intake temp, except when in traffic and the intercooler temp cools down much quicker than at the air intake.  The manifold on the other hand, seems to be a bit cooler than with the stock intercooler but that sensor is in a naturally hot location anyway.
As for boost differences, it's been hard to tell since the outside temps have been around 100 lately compared to high 80's/ low 90s when I first installed it. I have no proof other than my butt dyno that it does feel like it pulls harder if I do a 0-100 run on it.
Mishimoto is sending a stencil of the "M" so I can paint it on myself. They don't sell the black one with any markings on it for the stealth look, even though every picture but their website shows otherise.
2014 Explorer Sport - Livernois 91 tune, 3 Bar MAP, Bilstein B6's, Dicunzolo Transmission Mounts, Mishimoto J-Line FMIC, AEM Drop In Filter, Steeda Rear Sway Bar, PPE Engineering Catless Downpipes, Reische 170 T-stat
2011 Mustang GT Brembo - Bama 91 tune, Steeda Intake,  LTH, 3" full exhaust with O/R X-Pipe no resonator, every possible suspension component replaced, weighs 3505 with 1/4 gas
Offline xartic1
  • Jr. Member
  • -Given: 2
  • -Received: 18
  • Twin Turbskies
  • Liked:
  • Likes Given: 0
« Reply #62 on: August 16, 2020, 09:28:22 PM »
Just to put it out there, the stock intercooler weighs 7.40lbs on my scale and the Mishimoto is 18.7lbs according to the website. I didnít weigh the J-Line with any of the couplers or the aluminum extensions.
  • Full Member
  • Orangevale, CA
  • -Given: 46
  • -Received: 57
  • Mad Scientist
    • The Workshop
  • Liked:
  • Likes Given: 0
« Reply #63 on: August 16, 2020, 10:11:35 PM »
Oh ok, but it did feel heavier than the stock one though huh? I think the benefits of the intercooler outweigh the weight gain though.
IG: ecoboost_xsport
Offline xartic1
  • Jr. Member
  • -Given: 2
  • -Received: 18
  • Twin Turbskies
  • Liked:
  • Likes Given: 0
« Reply #64 on: August 16, 2020, 11:00:10 PM »
Yeah it was noticeable when I took it out and put the Mishimoto in. One of the cons of a bar and plate IC but like you said the benefit of the cooling makes up for it.
I did pull on a 370z today while giving him the jump at a stop light. He looked puzzled afterwards.
Offline xartic1
  • Jr. Member
  • -Given: 2
  • -Received: 18
  • Twin Turbskies
  • Liked:
  • Likes Given: 0
« Reply #65 on: September 05, 2020, 10:09:22 PM »
So I painted my J Line two days ago and it makes me realize how restricted the front is for pushing air through the intercooler. I was looking into the raptor grille but it looks like the airflow is even worse. There is one company that sells a bottom and top billet grille but honestly seeing through it looks even worse than a stock one.
I also almost donít like the M for how italicized it is making it look off center. It was lined up by the top right and bottom left correctly too.
Bottom grille received a glossy black coat too.
One item I recommend using for the plastic trim along the bottom of the Explorers is the Wizardís Black Renew. Makes Motherís back to black look like a joke.
  • Full Member
  • Orangevale, CA
  • -Given: 46
  • -Received: 57
  • Mad Scientist
    • The Workshop
  • Liked:
  • Likes Given: 0
« Reply #66 on: September 05, 2020, 10:17:00 PM »
Nice. I feel you on the airflow issue. I've been trying to visualize something that would look good but also functional. I absolutely hate those Raptor grilles, they look ridiculous on anything but a Raptor.  But you might be interested in the police interceptor grille. I was thinking about it but it would also need some cutting I think..
There are just no real options for the XSport, tbh.
Anyway, I would've left the IC raw aluminum. I like the look, like it means business with a mean looking aluminum intercooler in your face. There's also actually been some tests showing black intercoolers may not be as efficient as raw aluminum...I'll look for the link and pass it on.
But it's really cool what you've done and I am excited to get my version going as well. These things desperately need a more efficient IC.
EDIT: video link
« Last Edit: September 05, 2020, 10:22:55 PM by Ecoboost_xsport »
IG: ecoboost_xsport
Offline xartic1
  • Jr. Member
  • -Given: 2
  • -Received: 18
  • Twin Turbskies
  • Liked:
  • Likes Given: 0
« Reply #67 on: September 05, 2020, 10:26:57 PM »
I was going to go with the unpainted IC but I figured black was going to be the best look overall. At this point I can just hope a car wash that has a bit of a higher pressure than a normal one can take my paint off slowly without damaging the fins.
The stock XLT grille looks like it has holes in it which I wonder if it would be able to line up with the Sports where we could turn those holes into vents for the intercooler.
I will say I averaged 25.7MPG going to Pagosa Springs this weekend which was about a 410 mile round trip with elevation varying from 4,600-10,800ft and 7% grades. I would see the temp at the throttle body cooler than at the airbox quite often too which was noticeable climbing elevation. Had cruise control on mostly at 67-77mph as well with temps 80-95F ambient.
  • Full Member
  • Orangevale, CA
  • -Given: 46
  • -Received: 57
  • Mad Scientist
    • The Workshop
  • Liked:
  • Likes Given: 0
« Reply #68 on: September 05, 2020, 10:30:49 PM »
Awesome results. Need to do some data logging on a few particular parameters so you can find out how truly efficient it is.  Calculating Boost Air Density is a great way to compare apples to apples when doing mods and seeing how they effected performance even under different test conditions.
IG: ecoboost_xsport
