July 03, 2020, 01:13:09 PM
Author Topic: F150 Boost pressure feels limited  (Read 15190 times)
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 13013
  • -Received: 4215
Re: F150 Boost pressure feels limited
« Reply #90 on: March 26, 2020, 06:38:59 PM »
They have one for the regular Taurii that are flex fuel capable, but none otherwise.  Same for F150 I expect.
Offline Defhd10
  • Full Member
  • -Given: 5
  • -Received: 1
« Reply #91 on: March 26, 2020, 07:13:02 PM »
So any ideas on where to start or what to do now at this point?  Could this explain why my turbos are much louder but yet being limited to 7lbs when not under wot?  Or do i just still have a really bad batch of fuel in my tank?  I didnt see a pid for the high pressure fuel pump.  Could there be something wrong with it causing these problems?  I appreciate all the help guys.
Offline TopherSho
  • Eugene Oregon
  • -Given: 483
  • -Received: 367
  • 1st boosted rig!
« Reply #92 on: March 26, 2020, 11:05:42 PM »
the OAR value should not drop like that,  could it be bad gas?  maybe?  But I assume you have been fueling more than once recently so I think the likelihood is less for bad fuel.  To much Ethanol is a possibility,  but you would have to run north of E30 to see it,  and as soon as you fueled up again with 92 it would resolve.
With the comment from SHOdded that you may not have a true flexfuel sensor for that year were back to possible O2 sensors.. your cats seemed fine as compared to your fathers.  O2's they play a large role in determining fuel 'type'.  are you 100% certain the dealer really replaced the o2's  and did they do the fronts AND back ?
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 13013
  • -Received: 4215
« Reply #93 on: March 26, 2020, 11:37:57 PM »
Def verify the O2s are new and not fouled out
Offline Defhd10
  • Full Member
  • -Given: 5
  • -Received: 1
« Reply #94 on: March 27, 2020, 09:34:36 AM »
Uh the dealer hasnt touched anything on the truck other then the reprogramming. Everything thats been swapped/changed was done by me so the o2s are the originals. Ill pull them this weekend to take a look and clean them. Plenty tanks of fuel have been ran through since the beginning of this so i dont foresee it being bad fuel either.
Offline TopherSho
  • Eugene Oregon
  • -Given: 483
  • -Received: 367
  • 1st boosted rig!
« Reply #95 on: March 27, 2020, 12:31:36 PM »
Sorry on the parts touching ;) .. I remember now that you did the hardware.  In my head cleaning my help,  but if the tips are embedded with debris or the voltage coming out of them is out of range the ECU may still be doing the unusual adjustments.  Im still a bit perplexed with the throttle actual behavior but the OAR sinking like a rock is all we have to go on :/
Offline Defhd10
  • Full Member
  • -Given: 5
  • -Received: 1
« Reply #96 on: March 27, 2020, 12:53:45 PM »
Its all good and again i greatly appreciate all the help.  Maybe the water indigestion and misfire caused the o2s to get out of sync i dont know. I really wish it would throw a code. It would make me feel alot better if the truck knew there was a problem going on. I did try my dads throttle body awhile back thinking maybe a throttle position sensor issue, but of course it didnt change anything.
Offline TopherSho
  • Eugene Oregon
  • -Given: 483
  • -Received: 367
  • 1st boosted rig!
« Reply #97 on: March 27, 2020, 02:14:11 PM »
NP!
Offline Defhd10
  • Full Member
  • -Given: 5
  • -Received: 1
« Reply #98 on: March 29, 2020, 03:14:19 PM »
Decided im not going to touch the o2s. Atleast not yet. Im not getting any codes associated with them like i should if they were a problem, and i dont want to ruin them by attempting to clean. To the point now im going to run it until it throws a code or a rod. Really dont care at this point. Ive wasted so much time and money and not one single thing i do makes any bit of improvement.  Really appreciate all the help guys, but ive pretty much given up. If i knew what it was i wouldnt have a problem spending the money to fix it, but im done wasting my money on the things that wont fix it.
Offline TopherSho
  • Eugene Oregon
  • -Given: 483
  • -Received: 367
  • 1st boosted rig!
« Reply #99 on: March 30, 2020, 10:58:36 AM »
I'd be very careful tossing a rod,  if the dealership/ford network/warranty-company has you marked down as 'modified' they will not honor a engine rebuild.  I ran into that with my Bad injector taking my block out.  I had to pay out of pocket.
Understand the frustration though...
Offline SM105K
  • IG @egocheckersho
  • Forum Supporters
  • Arizona
  • -Given: 929
  • -Received: 1090
  • Thee Forum Cowboy
« Reply #100 on: March 30, 2020, 12:42:25 PM »
The Dealership did it.  It most likely corrupted the ECU with the new flash.
« Last Edit: March 30, 2020, 12:46:06 PM by SM105K »
"M" 2013 SHO PP | AJPTurbo E30 Tune | GH Intercooler | PPE Downpipes | Custom Magnaflow Resonator | 3rd Cat Delete | Dicunzolo Gen2 Trans Mounts| EPP Noisemaker Eliminator | MSD Coil Over Plugs | SP-542's | UPR Dual Valve Catch Can | K&N Drop In | Power Stop Slotted and Drilled Rotors with Stock PP Pads | H&R Springs  | Curva Concept C7's | Continental DWS06 Extreme Contact Rubber |
Offline Defhd10
  • Full Member
  • -Given: 5
  • -Received: 1
« Reply #101 on: March 30, 2020, 01:38:42 PM »
Im already out of warranty, so nothing really to lose at this point.
Offline Defhd10
  • Full Member
  • -Given: 5
  • -Received: 1
« Reply #102 on: March 30, 2020, 01:46:51 PM »
I would like to believe this is true, but i really dont know. I had too many things happen at once for me to point it directly at the flash. Im mostly leaning towards the condensation causing the problem. I cant confirm 100% what the boost was directly after the misfire because i was stock tuned and wasnt paying any attention. As soon as i got the tune back on is when i noticed the problem. And when switching back to stock i noticed it was still present because i was paying attention to it. Granted this was after the dealer flash, but i still cant confirm thats what caused it.
Offline Defhd10
  • Full Member
  • -Given: 5
  • -Received: 1
« Reply #103 on: April 05, 2020, 05:25:45 PM »
Curiosity got the best of me today so i pulled my o2 sensors as well as dropping the downpipe to take a look at the back side of the turbos. The o2 sensors look fine. Driver side looks the same as the passenger side. The back side of the turbos look fine too. I was really hoping to find a wore out wastegate, but of course i didnt. Both are seated when closed and no play when open. With that said i feel like ive explored all my options at this point.
Does anyone know why i would have erratic OAR like Topher pointed out?  Ive fuelled from a different station that i normally do that past 2 fillups and used 93 octane rather then 89. I will say that the truck does feel like its running a bit smoother on the 93, but still having the boost limited to 7 lbs. Im trying not to give up on this thing, but the end is near.
Offline Defhd10
  • Full Member
  • -Given: 5
  • -Received: 1
« Reply #104 on: April 08, 2020, 11:42:31 PM »
Okay guys the truck finally threw 2 codes tonight. Both related to throttle position voltage to low. Now i had tried a throttle body in the past with no change, do you think it could be the accelerator pedal?
* Recent Topics
Re: New member Omaha, Nebraska
by BigGrey150 | July 02, 2020, 08:15:35 PM
I actually live in bellevue on the north east side of the base. I just...
Forum Stickers
by StealBlueSho | July 02, 2020, 01:47:07 PM
EBPF Family..Anyone have any recommendations on who to go through for ...
by WinPlaceSHO | July 02, 2020, 01:34:42 PM
I'll bite... it's a good ole fashioned SHO down, mine is the...
Re: B1086- Air Distribution Damper Motor - Panel/floor/defrost not working
by Gjkrisa | July 02, 2020, 01:19:45 PM
New panel worked think I cracked part of the new facia trying to take ...
by Dannymack | July 02, 2020, 01:17:24 PM
Quick update. Been enjoying the car in its current form for a couple m...
Re: Help! Removal of Rear Turbo
by 802SHO | July 02, 2020, 12:18:51 PM
Thanks to you guys for all the tips. I wasn't sure about the knuc...
Re: 2015 Ford Explorer Sport - AC Compressor Not Starting
by lotusnotes | July 02, 2020, 12:07:40 PM
So I figured this out - whoever mounted the light bar on this truck be...
Re: TASCA=Fail....
by nickstewartroc | July 02, 2020, 12:01:03 PM
I usually use tasca to look up part numbers.  And then go to my l...
Re: So Lets start some banter
by nickstewartroc | July 02, 2020, 11:59:05 AM
+1 on the FiST. Love mine, going on 5 years now with it, upgraded turb...
Re: 2020 June RoTM Winner!!!
by StealBlueSho | July 02, 2020, 10:34:19 AM
Sweet!! I'll PM you my address so you can send me the trophy and ...
Back to top
