July 08, 2020, 12:34:21 AM
Author Topic: F150 Boost pressure feels limited  (Read 15360 times)
Offline Defhd10
  • Full Member
  • Thank You
  • -Given: 5
  • -Received: 1
  • Ecobooster
Re: F150 Boost pressure feels limited
« Reply #120 on: April 12, 2020, 09:08:35 AM »
yeah it might be a placebo effect ...  I was wondering if both are 2.5 bar sensors or if one is 2 the other is 3 like on the SHO.  If they are identical, swap them and see if you see a change in behavior.  That kind of thing.
I believe the one before the trottle body is a 2 bar and the one on top of the intake is a 2.5.
Offline Defhd10
  • Full Member
  • Thank You
  • -Given: 5
  • -Received: 1
  • Ecobooster
« Reply #121 on: April 12, 2020, 09:11:36 AM »
Is the wastegate hose intact based on the pic below!
I would not give up on this truck that easily IMHO! Z
Yes the hose is attached. It does kind of look like its not in the pic, but it is in fact attached. Im trying my best not to give up, but ive been battling this issue for 2 months now with no fix. Although atleast i now have codes that i can tell the dealer if i chose to take it to them to look at
Offline Defhd10
  • Full Member
  • Thank You
  • -Given: 5
  • -Received: 1
  • Ecobooster
« Reply #122 on: April 12, 2020, 09:17:27 AM »
Yeah, I mean, you can always contact Ford Customer Service and tell them that your truck has been misbehaving since this flash update was applied.  If they have something (engineering team), they can help you right away, or call on the engineering team to look into it.  This is a big deal, and they want their F150 customer base, as far as I can tell LOL.
I think for right now im just going to run it for the next few weeks and see if things continue to get worse or if codes get set again. If they do i think at that point i will take it to the dealer for them to diagnose. Atleast now i have something to tell them to look at being i got the codes.
Offline SHOdded
  • Forum Supporters
  • Elite Member
  • Beltsville, MD
  • Thank You
  • -Given: 13013
  • -Received: 4215
« Reply #123 on: April 12, 2020, 12:40:21 PM »
True enuf.
Offline Defhd10
  • Full Member
  • Thank You
  • -Given: 5
  • -Received: 1
  • Ecobooster
« Reply #124 on: April 18, 2020, 02:49:14 PM »
Well its been a week on the different pedal so thought id give a small update. Codes havent came back but the truck is running the exact same as it was before if not worse. So i imagine its only a matter of time until the codes do come back. Boost is still low and still surges from time to time.
Offline SHOdded
  • Forum Supporters
  • Elite Member
  • Beltsville, MD
  • Thank You
  • -Given: 13013
  • -Received: 4215
« Reply #125 on: April 18, 2020, 07:39:16 PM »
Boo! Bah, humbug.
Offline Defhd10
  • Full Member
  • Thank You
  • -Given: 5
  • -Received: 1
  • Ecobooster
« Reply #126 on: April 18, 2020, 11:02:20 PM »
Really just disappointed at this point. On a side note my dad has been running the pedal that came out of my truck this week and his is still running perfect. No symptoms that mine had and still has.
Offline SHOdded
  • Forum Supporters
  • Elite Member
  • Beltsville, MD
  • Thank You
  • -Given: 13013
  • -Received: 4215
« Reply #127 on: April 19, 2020, 07:31:53 AM »
yeah, it is very possible the pcm has bought the farm, like sm105k said earlier.  unfortunately it is not a straight swap from your dad's truck to yours, due to security issues which would not allow your vehicle to start/run.  You would have to be out of pocket for a new pcm unless you can convince the dealer to return to the last revision, or asbuilt version.
If a faulty piece of hardware cannot be found, either a sensor is dead or the computer that takes input from the sensor is corrupted.  If a sensor is dead, the computer sets the appropriate code.  You can try putting in new MAP sensors, but that is a pure parts cannon play.  May or may not work.  We used to have problems with Gen 1 & 2 SHOs where the PCM would not have any codes, seem to be working properly, but in reality, needed to be replaced/exorcised.
Offline Defhd10
  • Full Member
  • Thank You
  • -Given: 5
  • -Received: 1
  • Ecobooster
« Reply #128 on: April 19, 2020, 09:23:09 AM »
I really feel it could be the pcm, i mean with the boost being so low lately you would think surely it would throw an underboost code. But i guess it wouldnt if thats all the pcm is commanding. Is it possible for a misfire to damage the pcm?  Because i really feel that this is when everything started.
Offline SHOdded
  • Forum Supporters
  • Elite Member
  • Beltsville, MD
  • Thank You
  • -Given: 13013
  • -Received: 4215
« Reply #129 on: April 19, 2020, 11:08:29 AM »
Misfires dont generally damage the pcm to the extent of disabling it.  Coil or injector drivers yes.  But it feels like a logic failure to me.
Offline SHOdded
  • Forum Supporters
  • Elite Member
  • Beltsville, MD
  • Thank You
  • -Given: 13013
  • -Received: 4215
« Reply #130 on: April 19, 2020, 11:10:13 AM »
You can ask circuitboarmedics.com if they will transfer configs to a known good pcm.  Lower cost alternative  to brand new. Let them know what happened.
Offline Defhd10
  • Full Member
  • Thank You
  • -Given: 5
  • -Received: 1
  • Ecobooster
« Reply #131 on: June 22, 2020, 05:30:28 PM »
So alittle over 2 months now since ive replaced the throttle pedal and to this day the codes havent yet returned,  but no fix has been found. Boost still maxing at 7lbs. Alot of times having little to no boost midway through a hill then all of a sudden itll spike and hold at 7lbs. Almost always boost spikes when it changes gears. I cant for the life of me figure it out. Had a bad experience a week ago when towing.  Came out of a turn and began to push the accelerator pedal and nothing happened. No boost, no acceleration no change in rpms just totally nothing as i continued to push the pedal further for about 5 seconds which felt like a lifetime.  Then out of nowhere a big boost spike then slowly we began accelerating. I just dont understand why im having this issue or what caused it.
* Recent Topics
Re: Ride of The Month - July 2020!!
by bpd1151 | July 07, 2020, 10:46:47 PM
That doggone BPD guy shattered my build tho lol.Sorry......Sent from ...
by 802SHO | July 07, 2020, 09:29:20 PM
I have never seen 32mpg.. good for you!I see like 14 mpg lol!  Bu...
Re: SM105K's Ownership/Performance/Maintenance Thread
by sm105k | July 07, 2020, 11:44:31 AM
On my return trip I averaged 88 mph through CA and 95 mph through AZ. ...
Re: Has anyone install custom Hood?
by sm105k | July 07, 2020, 11:07:33 AM
Ford Derrick is the owner, I pinged him back in May of last year.. att...
Re: Phenolic Spacers
by 802SHO | July 07, 2020, 09:43:41 AM
Nevermind, purchased some from my local O'Reillys for $54Sent fro...
Re: AO tune vs downpipes
by StealBlueSho | July 07, 2020, 09:37:30 AM
Matt R. said I didn't need a revision for my catted PPE's on...
Re: SHOdded Officially Retiring as Admin
by 802SHO | July 07, 2020, 05:13:28 AM
Manu you've been such a big help in so many aspects of everything...
Re: TASCA=Fail....
by SilvererSHO | July 06, 2020, 09:41:25 PM
And to confuse things even more, here's the listing for a 2013 SH...
Re: Edge ST .......Here she is
by Macgyver | July 06, 2020, 07:19:10 PM
I really like it.  How is the room?  Maybe one of those will...
Re: New SHO owner with problems
by My15SHO | July 06, 2020, 04:10:09 PM
Good luck but I don't like the sound of them being so quick to ju...
Back to top
