August 05, 2021, 09:15:52 AM
Author Topic:  F150 Boost pressure feels limited  (Read 24173 times)
Offline SHOdded
  • Forum Supporters
  • Elite Member
  • Beltsville, MD
  • Thank You
  • -Given: 13054
  • -Received: 4248
  • Liked:
  • Likes Given: 25
Re: F150 Boost pressure feels limited
« Reply #105 on: April 09, 2020, 02:48:04 AM »
Both codes are pointing to the wawa pedal, not the throttle body, so that's what I would check first.  Highly unusual for it to be that, but if there has been water intrusion of any kind, then it is quite possible.
P2122 - Throttle/Pedal Position Sensor/Switch D Circuit Low
Description:  This DTC sets when the accelerator pedal position 1 (APP1) is out of self-test range low.
Possible Causes:  APP1 circuit open
APP1 circuit short to ground
Damaged APP sensor
Diagnostic Aids:  An APP1 or APP_D sensor PID reading may indicate a concern.
Application   Key On Engine Off  Key On Engine Running  Continuous Memory
All     GO to Pinpoint Test DK .
P2127 - Throttle/Pedal Position Sensor/Switch E Circuit Low
Description:  This DTC sets when the accelerator pedal position 2 (APP2) is out of self-test range low.
Possible Causes:  APP2 circuit open
APP2 circuit short to ground
Damaged APP sensor
Diagnostic Aids:  An APP2 or APP_E sensor PID reading may indicate a concern.
« Last Edit: April 09, 2020, 02:59:41 AM by SHOdded »
Offline Defhd10
  • Full Member
  • Thank You
  • -Given: 5
  • -Received: 1
  • Ecobooster
  • Liked:
  • Likes Given: 0
« Reply #106 on: April 09, 2020, 08:26:46 AM »
Damaged APP sensor
Damaged APP sensor
Thank you!  Im going to try the pedal out of my dads truck this weekend and see if thats it.
Offline SHOdded
  • Forum Supporters
  • Elite Member
  • Beltsville, MD
  • Thank You
  • -Given: 13054
  • -Received: 4248
  • Liked:
  • Likes Given: 25
« Reply #107 on: April 09, 2020, 09:20:00 AM »
Best of luck!
Offline SM105K
  • IG @egocheckersho
  • Forum Supporters
  • Elite Member
  • Arizona
  • Thank You
  • -Given: 1049
  • -Received: 1221
  • Thee Forum Cowboy
  • Liked:
  • Likes Given: 22
« Reply #108 on: April 09, 2020, 03:37:23 PM »
I really hope this works for you.
"M" 2013 SHO PP | AJPTurbo E30 Tune | FS HPFP | Stock IC with Ice Water DIY Sprayer | PPE Downpipes | Custom Magnaflow Resonator | 3rd Cat Delete | Derale Upgraded Trans Cooler | Dicunzolo Gen2 Trans Mounts| EPP Noisemaker Eliminator | MSD Coil Over Plugs | SP-542's | UPR Dual Valve Catch Can | K&N Drop In | Power Stop Slotted and Drilled Rotors with Stock PP Pads | H&R Springs  | AVS Flush Deflector | 802SHO Custom Splitter | Duraflex Chin Spoiler | Curva Concept C7's | Continental DWS06 Extreme Contact Rubber |
"The Fukus" 2013 Focus ST | AJPTurbo Flex Fuel Tune | Megan Racing Catless Downpipe | Boomba BOV | FSWerks Short Shifter | Power Stop Brakes | Continental DWS06 Extreme Contact Rubber |
Offline Defhd10
  • Full Member
  • Thank You
  • -Given: 5
  • -Received: 1
  • Ecobooster
  • Liked:
  • Likes Given: 0
« Reply #109 on: April 09, 2020, 07:22:30 PM »
Thanks man me too. Been doing alittle bit of reading. If its not the throttle pedal,  it could be a bad wiring harness or a bad pcm. Really hope its not either of those but i guess i will find out.
Offline TopherSho
  • Elite Member
  • Eugene Oregon
  • Thank You
  • -Given: 504
  • -Received: 413
  • 1st boosted rig!
  • Liked:
  • Likes Given: 5
« Reply #110 on: April 10, 2020, 04:26:39 PM »
With the whacky OAR reading,  I am leaning to a harness issue or at the lower end of possibility a ECU causing it to adjust itself.  Have you pulled the harness off the ECU?   Z/SHOdded have seen corroded plugs before..
Best 0-60 public road 4.35s
Offline Defhd10
  • Full Member
  • Thank You
  • -Given: 5
  • -Received: 1
  • Ecobooster
  • Liked:
  • Likes Given: 0
« Reply #111 on: April 10, 2020, 06:12:53 PM »
I have pulled the 2 main harnesses off the pcm and everything looks fine there. Nothings corroded
Offline ZSHO
  • Forum Supporter
  • Forum Supporters
  • Elite Member
  • New York SHO
  • Thank You
  • -Given: 1945
  • -Received: 4088
  • Liked:
  • Likes Given: 0
« Reply #112 on: April 11, 2020, 06:56:18 AM »
There should be 3 harnesses connectors!  For reference here is good link for ya. I think you Need to provide as-built-data. Z
https://circuitboardmedics.com/ford/
Offline Defhd10
  • Full Member
  • Thank You
  • -Given: 5
  • -Received: 1
  • Ecobooster
  • Liked:
  • Likes Given: 0
« Reply #113 on: April 11, 2020, 09:55:42 AM »
Only 2 on mine unless im missing something
Offline Defhd10
  • Full Member
  • Thank You
  • -Given: 5
  • -Received: 1
  • Ecobooster
  • Liked:
  • Likes Given: 0
« Reply #114 on: April 11, 2020, 11:53:40 AM »
Pedal is on and codes are cleared. It does feel alot better and seems to be holding 6th alot longer before a downshift,  but im still not 100% if its fixed. Boost still looks to be the same, but i havent put my tune on to see if it increases. I want to run stock for alittle to see if codes return and if it starts acting up again.
Offline SHOdded
  • Forum Supporters
  • Elite Member
  • Beltsville, MD
  • Thank You
  • -Given: 13054
  • -Received: 4248
  • Liked:
  • Likes Given: 25
« Reply #115 on: April 11, 2020, 07:24:31 PM »
Oh man!  Really hope the PCM is not bricked!  It should detect issues with the MAP sensors but ... are both identical on your F150?
Offline Defhd10
  • Full Member
  • Thank You
  • -Given: 5
  • -Received: 1
  • Ecobooster
  • Liked:
  • Likes Given: 0
« Reply #116 on: April 11, 2020, 07:57:28 PM »
Both MAP sensors identical or what are you asking?  So far no more codes after switching out the pedal and it does feel somewhat better, BUT i did put my pedal in my dads truck, and his still runs perfect. So is it just in my head that mine feels better maybe. I guess i need a few more days to see what it does.
Offline SHOdded
  • Forum Supporters
  • Elite Member
  • Beltsville, MD
  • Thank You
  • -Given: 13054
  • -Received: 4248
  • Liked:
  • Likes Given: 25
« Reply #117 on: April 12, 2020, 01:33:26 AM »
yeah it might be a placebo effect ...  I was wondering if both are 2.5 bar sensors or if one is 2 the other is 3 like on the SHO.  If they are identical, swap them and see if you see a change in behavior.  That kind of thing.
Offline ZSHO
  • Forum Supporter
  • Forum Supporters
  • Elite Member
  • New York SHO
  • Thank You
  • -Given: 1945
  • -Received: 4088
  • Liked:
  • Likes Given: 0
« Reply #118 on: April 12, 2020, 07:43:19 AM »
Is the wastegate hose intact based on the pic below!
I would not give up on this truck that easily IMHO! Z
« Last Edit: April 12, 2020, 07:49:09 AM by ZSHO »
Offline SHOdded
  • Forum Supporters
  • Elite Member
  • Beltsville, MD
  • Thank You
  • -Given: 13054
  • -Received: 4248
  • Liked:
  • Likes Given: 25
« Reply #119 on: April 12, 2020, 07:57:03 AM »
Yeah, I mean, you can always contact Ford Customer Service and tell them that your truck has been misbehaving since this flash update was applied.  If they have something (engineering team), they can help you right away, or call on the engineering team to look into it.  This is a big deal, and they want their F150 customer base, as far as I can tell LOL.
* Recent Topics
Re: Any advice on how to improve 1/4 mile times?
by Blackhawk | August 04, 2021, 11:46:49 PM
This car should be running at least high 11s with all those mods. ...
Re: Terrain Management System Fault - wrench light
by TopherSho | August 03, 2021, 05:45:56 PM
Good notes to keep under the hat,  thanks for the share and updat...
2010 Taurus SHO, PCM issues
by withku | August 03, 2021, 01:41:48 PM
Hey all, my 2010 has been acting up lately. A while ago, my a/c stoppe...
Re: PTU 2017 3.5 EcoBoost Explorer 20 minute Fluid change all from underneath car
by SPDboat driver | August 02, 2021, 06:28:36 PM
Good video. You think you may lose some fluid through the vent if it h...
ecoboost_xsport Consolidated Build/Maintenance Thread
by Ecoboost_xsport | July 30, 2021, 08:24:58 PM
Even though I haven't been posting as frequently lately (YouTube ...
Re: 15 Interceptor Sedan Ecoboost with GHT Tune - Engine Coolant Overtemp
by SHOdded | July 30, 2021, 02:58:41 PM
on the 2.7, ford says to replace the ECT sensor and/or the knock senso...
Re: Random Pull/Torque Steer after new moog lower control arms.
by SHOdded | July 30, 2021, 02:54:07 PM
have an independent service shop verify your work with the LCAs. ...
Boost / Vacuum Source
by Ecoboost_xsport | July 29, 2021, 12:36:21 PM
Those of you wondering where a decent place to tap into a boost/vacuum...
Re: New from Minnesota...
by PDSHO | July 27, 2021, 04:15:43 PM
Greetings from Nebraska.Greg...
Re: Ol' Guy in New England........
by PDSHO | July 27, 2021, 04:13:04 PM
