July 03, 2020, 01:30:09 PM
Author Topic: DannyMack 13 MKS "Old Man" Build and Maintenance Thread  (Read 10747 times)
Offline 802SHO
  • Elite Member
  • Essex Junction Vermont
  • Thank You
  • -Given: 2177
  • -Received: 1047
  • Boosted
Re: DannyMack 13 MKS "Old Man" Build and Maintenance Thread
« Reply #30 on: December 31, 2019, 01:06:49 PM »
How much boost was Revision 1?  Nice improvement from your first tune and you guys are just getting started.
2010 SHO non PP, Tuned by AJP Turbo, Ported GH upgraded turbos, Ported 13+ Exhaust Manifolds, GH upgraded IC, EPP Hot Pipes, EPP Dual CAI, XDI35 HPFP, Deatschwerks LPFP, Alky Control Methonal Injection, Alky dual nozzle upgrade, Zex Nitrous, Dicunzolo Gen2 torque mounts, MSD Coils, SP542 .026, 160 T, 3bar, Catless Downpipes, custom stainless 2.5" double xpipe w/muffler deletes 4" quad tips, UPR Dual Valve Catch Can, Derale 10000 series 16 row trans cooler, 13+ PP Trans Cooler, Econoaid throttle Body Booster, Mickey Thompson 20x9 SC-5 Wheels, Continental Extreme Contact DW tires F: 245/40/20 R: 275/35/20, H&R Springs all around w/rear cut 1/2", 1" hubcentric wheel spacers m14 1.5 stud/lug conversion, Aeroforce Interceptor Gauge.
Highest Trap Speed 123.22 mph
PB 11.368 @ 122.68 NED 10/20/19
Offline Dannymack
  • Full Member
  • Longmont, CO
  • Thank You
  • -Given: 26
  • -Received: 77
  • Mile High Club
« Reply #31 on: December 31, 2019, 04:11:42 PM »
Looks like it goes from around 179-180 kPa (11.3 psi) and tapers down to 172 kPa (10.3 psi). This was during the 3rd gear pull.
In the pulls from 0 it looks like my peaks averaged around 200 kPa (14.3 psi) and then would taper down to around 172 kPa.
2013 MKS EcoBoost Fully Loaded
AJP E25 Tuned
EBC Yellow Brake Pads
Offline SHOdded
  • Forum Supporters
  • Elite Member
  • Beltsville, MD
  • Thank You
  • -Given: 13013
  • -Received: 4215
« Reply #32 on: December 31, 2019, 07:10:17 PM »
Not much different from stock.
Offline Dannymack
  • Full Member
  • Longmont, CO
  • Thank You
  • -Given: 26
  • -Received: 77
  • Mile High Club
« Reply #33 on: December 31, 2019, 07:50:51 PM »
About 4-5 psi higher than what the car was running pre-tune.
AJP E25 Tuned
Offline SHOdded
  • Forum Supporters
  • Elite Member
  • Beltsville, MD
  • Thank You
  • -Given: 13013
  • -Received: 4215
« Reply #34 on: December 31, 2019, 08:16:52 PM »
Ah. I take it back then!
Offline Dannymack
  • Full Member
  • Longmont, CO
  • Thank You
  • -Given: 26
  • -Received: 77
  • Mile High Club
« Reply #35 on: January 04, 2020, 05:51:45 PM »
Gave it a quick wash today and debadged the trunk. I contemplated just removing the ecoboost, but it's just much better without any. If I had the final trunk version I would have left the "lincoln", but like the uniformity of this.
AJP E25 Tuned
Offline SHOdded
  • Forum Supporters
  • Elite Member
  • Beltsville, MD
  • Thank You
  • -Given: 13013
  • -Received: 4215
« Reply #36 on: January 05, 2020, 05:32:19 AM »
 :alkashi: :alkashi:
Offline Dannymack
  • Full Member
  • Longmont, CO
  • Thank You
  • -Given: 26
  • -Received: 77
  • Mile High Club
« Reply #37 on: January 06, 2020, 12:01:25 AM »
Gave myself an hour under the car today to get more familiar and also attempt to determine the suspension thud. All pics are posted below.
Tried getting movement out of the lower control arm bushings, but they were solid. Admittedly they do look pretty neat though. Thoughts?
Ball joints moved fine and didn't have any leaks.
Sway bar looks fine. Took pics of the bushings to see if anyone has thoughts on those as well.
Now for a couple discoveries. In one of the pics you'll see what looks like a female plug coming out of the firewall right above the back of the ptu and just below where the rear bov recirc hits the intake pipe. Is that a plug or something else?
I also found out where all the gear oil from the ptu had gone... hence why not much was extracted. The rear seal is going and it has been leaking out and spreading all over the firewall and tunnel. Add that to an upcoming project list.
Finally I just found this odd. Every 1-5ish minutes there would be an electrical noise coming from the timing cover area around mid engine. Sounds like a solenoid or relay activating or something along those lines. I recorded it to see if it's familiar to anyone. This is with the car completely off and locked.
AJP E25 Tuned
Offline SHOdded
  • Forum Supporters
  • Elite Member
  • Beltsville, MD
  • Thank You
  • -Given: 13013
  • -Received: 4215
« Reply #38 on: January 06, 2020, 12:09:34 AM »
Fuel pump or purge valve is what comes to mind.  How is the battery in your MKS holdng up?  CCAs, not just Vs.
Offline Dannymack
  • Full Member
  • Longmont, CO
  • Thank You
  • -Given: 26
  • -Received: 77
  • Mile High Club
« Reply #39 on: January 15, 2020, 11:39:51 PM »
Took on a little more involved project today. Adding permanent mount roof racks. Now I use the word "permanent" here with some caveats. While the mounts are riveted to the car they are also fairly easy to remove in an hour if I ever want to sell the car. They attach in the roof ditch so the holes don't show with the ditch trim.
I originally ordered the clip style mounts that clip to the door frame, but the one I wanted was out of stock. This caused me to rethink and I decided to get a little more involved.
Here are the parts if anyone ever wants to do something similar.
Yakima 60" Jetstream Bars
Yakima Skyline Towers
Yakima Landing Pad 21
I'll have more pics tomorrow in the light with bike racks installed.
AJP E25 Tuned
Offline Dannymack
  • Full Member
  • Longmont, CO
  • Thank You
  • -Given: 26
  • -Received: 77
  • Mile High Club
« Reply #40 on: January 17, 2020, 04:22:58 PM »
Finished up the rack today and added the bike racks. Wouldn't be surprised if I'm the only MKS in existence with permanent bike racks. Happy with how it all turned out. Nice and clean.
Because I'm going sleeper style with this one I was planning a license plate like "old man", but I think the rack ruined that potential joke. Now I'm considering the following.
1. ABRAHAM
2. HRSPRS
3. LNDYCHT
4. LOGS
5. A boy scout license plate that says "COOKIES"
AJP E25 Tuned
Offline Dannymack
  • Full Member
  • Longmont, CO
  • Thank You
  • -Given: 26
  • -Received: 77
  • Mile High Club
« Reply #41 on: March 04, 2020, 03:27:22 PM »
Current status:
Working on the e30 tune with brad. Since our E85 is closer to 70% the tune is more of a E25ish tune.
Decided while I'm building up my cash for some of the bigger parts I would do a cheaper job that should dramatically change the look of the car. It's a pretty universal opinion that Lincoln did a less than desirable job on the front grill of the 13+ MKS. I pulled mine out today to start figuring out a way to update it while not looking too aftermarket.
AJP E25 Tuned
Offline Dannymack
  • Full Member
  • Longmont, CO
  • Thank You
  • -Given: 26
  • -Received: 77
  • Mile High Club
« Reply #42 on: March 05, 2020, 04:32:54 PM »
Progress with the grille. Decided to paint it for now and see how I like it. If it comes around to it I'll cut it up in a few months and try something new. Figured I would put a little bit of accent to it.
Still deciding if the chrome trim around the lights and grille should be body matched or gloss black like the grille. They're primed and ready for whichever I decide.
AJP E25 Tuned
Offline Macgyver
  • Super Moderator
  • Elite Member
  • Reading, Pa.......
  • Thank You
  • -Given: 94
  • -Received: 314
  • Ecobooster
« Reply #43 on: March 05, 2020, 06:24:55 PM »
To get where you want you will prolly need to run an ethanol blend. Brad knows the E30 tunes very well. On my SHO. The His E30 pulls so much harder all over. Draggy will be a great tool to test this.
I run the OEM plugs per Brad. Just gapped closer. He will walk you through.
Intake, Thermostat etc is not needed unless you are doing All bolt ons per say. Hot Pipes, Downpipes etc.
The tune will really wake up your car. Just be patient and give Brad the Data.
Offline Ramairetransam
  • Full Member
  • Thank You
  • -Given: 0
  • -Received: 4
  • Ecobooster
« Reply #44 on: March 06, 2020, 11:27:02 AM »
how bad was it taking the grills out , ive wanted to paint mine all black for a bit now and taking them out to do it would be better.
13 Mks Ecoboost
* Recent Topics
Re: New member Omaha, Nebraska
by BigGrey150 | July 02, 2020, 08:15:35 PM
I actually live in bellevue on the north east side of the base. I just...
Forum Stickers
by StealBlueSho | July 02, 2020, 01:47:07 PM
EBPF Family..Anyone have any recommendations on who to go through for ...
Re: Ride of The Month - July 2020!!
by WinPlaceSHO | July 02, 2020, 01:34:42 PM
I'll bite... it's a good ole fashioned SHO down, mine is the...
Re: B1086- Air Distribution Damper Motor - Panel/floor/defrost not working
by Gjkrisa | July 02, 2020, 01:19:45 PM
New panel worked think I cracked part of the new facia trying to take ...
by Dannymack | July 02, 2020, 01:17:24 PM
Quick update. Been enjoying the car in its current form for a couple m...
Re: Help! Removal of Rear Turbo
by 802SHO | July 02, 2020, 12:18:51 PM
Thanks to you guys for all the tips. I wasn't sure about the knuc...
Re: 2015 Ford Explorer Sport - AC Compressor Not Starting
by lotusnotes | July 02, 2020, 12:07:40 PM
So I figured this out - whoever mounted the light bar on this truck be...
Re: TASCA=Fail....
by nickstewartroc | July 02, 2020, 12:01:03 PM
I usually use tasca to look up part numbers.  And then go to my l...
Re: So Lets start some banter
by nickstewartroc | July 02, 2020, 11:59:05 AM
+1 on the FiST. Love mine, going on 5 years now with it, upgraded turb...
Re: 2020 June RoTM Winner!!!
by StealBlueSho | July 02, 2020, 10:34:19 AM
Sweet!! I'll PM you my address so you can send me the trophy and ...
Back to top
