August 10, 2020, 12:35:32 PM
Author Topic: PPE Downpipes install question  (Read 4091 times)
Offline SuperPete
  • Full Member
  • Pennsylvania
  • Thank You
  • -Given: 12
  • -Received: 105
  • SHO Kind of guy
« on: December 04, 2019, 09:49:18 AM »
Got my downpipes today, WOW do they look sexy or what, perfection...
No words to describe, excellence at it's beset.
Planing on install this weekend, now the question is:
I only got two gaskets with them, for the connection to the exhaust, what about gaskets for the connection to turbo side? no gaskets?
Also longer pipe comes in two sections and I got no clamp for that, did they missed the clamp and gaskets or it's something I am responsible for.
thank you all
2014 SHO, GearHead TUNNED /Powered by Matt Robinson
PPE Downpipes, GearHead Intercooler, AirAid Intake
XDI-35 HPFP @ E40,   MSD Coilpacks
MUSTANG DYNO: 426/446
Continental Extreme Contact 06 & Powerstop Z23 all 4 corners
Offline SHOdded
  • Forum Supporters
  • Elite Member
  • Beltsville, MD
  • Thank You
  • -Given: 13013
  • -Received: 4215
Re: PPE Downpipes install question
« Reply #1 on: December 04, 2019, 09:58:41 AM »
Some gaskets are reusable, but they may have missed something anyway.
Can you post pics of what you have received?
Offline Jordan
  • Elite Member
  • Columbia, Mo
  • Thank You
  • -Given: 224
  • -Received: 643
  • I'm the captain of this SHIP
« Reply #2 on: December 04, 2019, 12:43:46 PM »
They don't give the turbo to downpipe gaskets on purchase. Some say they are reusable however I would recommend buying new motorcraft gaskets.
Online SM105K
  • IG @egocheckersho
  • Forum Supporters
  • Elite Member
  • Arizona
  • Thank You
  • -Given: 996
  • -Received: 1136
  • Thee Forum Cowboy
« Reply #3 on: December 04, 2019, 12:46:59 PM »
100 percent.  I used all new gaskets.  They are dirt cheap so yeah.
M" 2013 SHO PP | AJPTurbo E30 Tune | FS HPFP | GH Intercooler | PPE Downpipes | Custom Magnaflow Resonator | 3rd Cat Delete | Derale Trans Cooler | Dicunzolo Gen2 Trans Mounts| EPP Noisemaker Eliminator | MSD Coil Over Plugs | SP-542's | UPR Dual Valve Catch Can | K&N Drop In | Power Stop Slotted and Drilled Rotors with Stock PP Pads | H&R Springs  | AVS Flush Deflector | Curva Concept C7's | Continental DWS06 Extreme Contact Rubber |
"The Fukus" 2013 Focus ST | AJPTurbo Flex Fuel Tune | Megan Racing Catless Downpipe | Boomba BOV | FSWerks Short Shifter | Power Stop Brakes | Continental DWS06 Extreme Contact Rubber |
Offline StinkinLinkin13
  • Sr. Member
  • San Antonio, Texas
  • Thank You
  • -Given: 62
  • -Received: 173
  • Ecoboosted
« Reply #4 on: December 04, 2019, 04:41:36 PM »
Sound's like you are missing a clamp however. They are pretty cheap and easy to find though. NAPA or other auto parts stores/exhaust shop.
Livernois Catless downpipes with Magnaflow mufflers - Livernois E85 tune - Firestorm HPFP - 3 Bar Map - Alky Controls Meth Injection - 160 Thermostat - EPP Hot Pipes - AEM Dryflow Filter - BOV VTA - SSM Polyurethane Torque Struts - H&R Sport Springs - 20"x10" Niche Veronas on 275/40-20 DWS06 -
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • Elite Member
  • New York SHO
  • Thank You
  • -Given: 1936
  • -Received: 4071
« Reply #5 on: December 04, 2019, 05:23:44 PM »
Hmm interesting! Where did you purchase the DP from! Non catted version!
 NO Gaskets with mine. Bolts & nuts for Flange to exhaust only...
The Motorcraft Gaskets are for one-time use only IIRC! Z
Converter Gasket - Ford (AA5Z-6L612-A)
https://parts.levittownfordparts.com/oem-parts/ford-converter-gasket-aa5z6l612a?c=bT0xJmw9MSZuPVJlY29tbWVuZGVkIFByb2R1Y3RzJms9MQ%3D%3D
Front Pipe Bolt - Ford (-W714826-S900)
https://parts.levittownfordparts.com/oem-parts/ford-front-pipe-bolt-w714826s900
« Last Edit: December 04, 2019, 05:49:35 PM by ZSHO »
Offline SuperPete
  • Full Member
  • Pennsylvania
  • Thank You
  • -Given: 12
  • -Received: 105
  • SHO Kind of guy
« Reply #6 on: December 04, 2019, 06:46:12 PM »
Picture attached of what I got with the pipes.
Got them from jmautoracing.com, they whereon sale for $830 for catted version, I jumped on it like it was hot, that was 6 weeks ago, thats how much it took for PPE to make and ship, got pipes directly from PPE
Offline 76fomoco
  • Full Member
  • Nampa, ID
  • Thank You
  • -Given: 74
  • -Received: 141
  • Rabbit Hole master
« Reply #7 on: December 09, 2019, 10:17:22 AM »
always 4-6 weeks out to get pipes from them. I would spray the turbo side studs with liquid wrench about 30 min before taking off the stockers. then I would put anti seize on the 6 studs at the turbo and the 4 bolts at the flanges at the rear.
They are soooooo beautiful for sure!
2013 PP AJP 93 +meth 160 TS, sp542 plugs, 3 bar, PPE catted DP's, GH IC, GH turbos, XDI-35
Best 5-16-2020  12.40 with 3850 DA trap best 116.79
E30 = 415 whp & 470 before GH turbos and xdi-35
current tunes: AJP 93, 93+meth, E30 :) GH E30
* Recent Topics
Re: DannyMack 13 MKS "Old Man" Build and Maintenance Thread
by ChrisxHowe | Today at 12:14:51 PM
Intercooler pipes arrived today and I also started reforming the lower...
Re: door delaminated
by jims2015 | Today at 11:04:31 AM
finally after 6.5 yrs my passenger door lining delaminated. I understa...
Re: can we add an aviator forum?
by sm105k | Today at 10:55:55 AM
posted this in New member area as well. Just found this forum.Let me g...
Re: Wheel pulls bad one way then snaps back
by sm105k | Today at 10:54:16 AM
Got it fixed for free, got to breaks plus where they had replaced the ...
by xkrexplorer | August 09, 2020, 06:14:06 PM
spent 6.5 hours putting car back to stock to sell it. Aviator gt on or...
How about adding an aviator forum
by xkrexplorer | August 09, 2020, 06:06:06 PM
got one on order, so just checking....
by bpd1151 | August 09, 2020, 04:24:21 PM
I've been hopeful for quite some time now.LOL. Pics are always po...
Re: And the award for most frequently broken car goes to...
by Macgyver | August 09, 2020, 03:38:41 PM
Lets hope their "Guy" is good....
Re: HOW-TO: Improve a bit on the X35 Phenolic Spacer
by Macgyver | August 09, 2020, 03:37:36 PM
Nice !!!Good thing its not a V12..........
Re: Info on WPC
by Macgyver | August 09, 2020, 03:34:05 PM
Very Interesting.Wonder what the Friction loss is in total if you did ...
Back to top
