September 25, 2020, 10:14:22 PM
Author Topic:  Upgraded HPFP, LPFP and Stock Injectors  (Read 7265 times)
Offline 802SHO
  • RotM Winner
  • Elite Member
  • Essex Junction Vermont
  • Thank You
  • -Given: 2353
  • -Received: 1133
  • Boosted
  • Liked:
  • Likes Given: 0
« on: November 30, 2019, 07:19:49 PM »
Does anyone know the flow rate of the stock injectors?  And does anyone really know if the stock injectors are adequate in keeping up with the additional fuel pressure of the XDI35, XDI60 and DW LPFP?
2010 SHO non PP, Tuned by AJP Turbo, Ported GH upgraded turbos, Ported 13+ Exhaust Manifolds, GH upgraded IC, EPP Hot Pipes, EPP Dual CAI, XDI35 HPFP, Deatschwerks LPFP, Alky Control Methonal Injection, Alky dual nozzle upgrade, Zex Nitrous, Dicunzolo Gen2 torque mounts, MSD Coils, SP542 .026, 160 T, 3bar, Catless Downpipes, custom stainless 2.5" double xpipe w/muffler deletes 4" quad tips, UPR Dual Valve Catch Can, Derale 10000 series 16 row trans cooler, 13+ PP Trans Cooler, Econoaid throttle Body Booster, Mickey Thompson 20x9 SC-5 Wheels, Continental Extreme Contact DW tires F: 245/40/20 R: 275/35/20, H&R Springs all around w/rear cut 1/2", 1" hubcentric wheel spacers m14 1.5 stud/lug conversion, Aeroforce Interceptor Gauge.
Highest Trap Speed 123.22 mph
PB 11.368 @ 122.68 NED 10/20/19
Offline Gjkrisa
  • Elite Member
  • Fairbanks, AK
  • Thank You
  • -Given: 988
  • -Received: 220
  • Ecobooster
    • Photos
  • Liked:
  • Likes Given: 0
Re: Upgraded HPFP, LPFP and Stock Injectors
« Reply #1 on: November 30, 2019, 09:05:41 PM »
The stock fuel pumps are a bit under sized so upgrading them you will still see increases.  But to get the most out of the engine you will want to upgrade injectors as well
Sent from my Pixel 4 XL using Tapatalk
Offline 802SHO
  • RotM Winner
  • Elite Member
  • Thank You
  • -Given: 2353
  • -Received: 1133
  • Boosted
  • Liked:
  • Likes Given: 0
« Reply #2 on: December 01, 2019, 01:48:54 PM »
What is the current offerings of upgraded injectors?  Deatschwerks and?
Offline ZSHO
  • Forum Supporter
  • Forum Supporters
  • Elite Member
  • New York SHO
  • Thank You
  • -Given: 1939
  • -Received: 4077
  • Liked:
  • Likes Given: 0
« Last Edit: December 01, 2019, 03:12:25 PM by ZSHO »
Offline StealBlueSHO
  • Administrator
  • Elite Member
  • Thank You
  • -Given: 2838
  • -Received: 2808
  • I poke at BPD1151
  • Liked:
  • Likes Given: 42
« Reply #4 on: December 02, 2019, 08:30:30 AM »
XDI is releasing injectors as well soon... not sure what they are gonna look like..
Thus far the stock injectors are pretty stout little bastards.
2016 Taurus SHO Performance Pack, Gearhead Custom Tunes, Gearhead Gen3 Turbos, Gearhead Intercooler, Gearhead 170 Tstat, EPP Dual Feed Intake, EPP Hot Pipes, EPP Ceramic Coated Catted Downpipes, Corsa Exhaust, XDI-35 Fuel Pump, DW In-Tank Fuel Pump, Fuel-It Bluetooth Ethanol Analyzer, HR Lowering Springs, AD Lower Trans Mounts, 3Bar MAP, SP-542 Plugs, Custom SHO Puddle Lights, Custom Gearhead emblem overlays. Best time currently is 11.922 @ 115mph full weight, stock wheels, stock tires... just like it came off the show room floor.
Offline SM105K
  • IG @egocheckersho
  • Forum Supporters
  • Elite Member
  • Arizona
  • Thank You
  • -Given: 1036
  • -Received: 1198
  • Thee Forum Cowboy
  • Liked:
  • Likes Given: 13
« Reply #5 on: December 02, 2019, 08:31:31 AM »
IMHO,
I don't think the injectors are a problem.  From what I have seen they flow more then enough for our power demands.  Pretty sure the engine will give up before you max the injectors completely.  Matt says a drop in fuel pressure is what causes the injectors to stick open.
If you have the upgraded HPFP and in tank FP you should be fine.
Now if you are replacing injectors for peace of mind, that is a different matter.
« Last Edit: December 02, 2019, 08:37:16 AM by SM105K »
"M" 2013 SHO PP | AJPTurbo E30 Tune | FS HPFP | GH Intercooler w/ DIY Ice Water IC Sprayer | PPE Downpipes | Custom Magnaflow Resonator | 3rd Cat Delete | Derale Upgraded Trans Cooler | Dicunzolo Gen2 Trans Mounts| EPP Noisemaker Eliminator | MSD Coil Over Plugs | SP-542's | UPR Dual Valve Catch Can | K&N Drop In | Power Stop Slotted and Drilled Rotors with Stock PP Pads | H&R Springs  | AVS Flush Deflector | 802SHO Custom Splitter | Duraflex Chin Spoiler | Curva Concept C7's | Continental DWS06 Extreme Contact Rubber |
"The Fukus" 2013 Focus ST | AJPTurbo Flex Fuel Tune | Megan Racing Catless Downpipe | Boomba BOV | FSWerks Short Shifter | Power Stop Brakes | Continental DWS06 Extreme Contact Rubber |
Offline 802SHO
  • RotM Winner
  • Elite Member
  • Thank You
  • -Given: 2353
  • -Received: 1133
  • Boosted
  • Liked:
  • Likes Given: 0
« Reply #6 on: December 03, 2019, 10:21:30 AM »
Yeah I was just kicking around the idea of replacing them.  I then wondered if it was actually pushing the stock injectors harder with an upgraded HPFP.  No evidence to say it is but also not enough data/results/reviews of ppl using the upgraded DW injectors.  I think I'll keep my interest on pause until I see what XDI comes up with.
Offline ZSHO
  • Forum Supporter
  • Forum Supporters
  • Elite Member
  • New York SHO
  • Thank You
  • -Given: 1939
  • -Received: 4077
  • Liked:
  • Likes Given: 0
« Reply #7 on: December 03, 2019, 07:58:10 PM »
In the meantime would throw in some Chevron with techron fuel injection cleaner inside the tank @ every oil change for good measures.
BG-44K cleaner also works well for the GDI applications..
$6.99 with coupon applied..
https://www.amazon.com/Chevron-Techron-Concentrate-System-Cleaner/dp/B00092893E/ref=mp_s_a_1_1?keywords=chevron+techron+complete+fuel+system+cleaner+20oz&qid=1575416909&sprefix=chevron+te&sr=8-1
« Last Edit: December 03, 2019, 08:05:54 PM by ZSHO »
Offline Gjkrisa
  • Elite Member
  • Fairbanks, AK
  • Thank You
  • -Given: 988
  • -Received: 220
  • Ecobooster
    • Photos
  • Liked:
  • Likes Given: 0
« Reply #8 on: December 03, 2019, 09:03:28 PM »
You should be able to see injector duty cycle and see if your pushing at 80 or more this will tell if its worth changing or not
Offline FiveLeeter918
  • Ortiz Performance - Technical Sales
  • Vendor
  • Sr. Member
  • Tulsa, OK
  • Thank You
  • -Given: 19
  • -Received: 260
  • Bewsted SHO
    • Ortiz Tuning and Performance
  • Liked:
  • Likes Given: 2
« Reply #9 on: March 17, 2020, 11:14:02 AM »
To my knowledge no datalogging program has the ability to log FIDC on our cars.
- Lee
Ortiz Performance Vendor Forum | Find us on Facebook! | Shop Today!
Offline Gjkrisa
  • Elite Member
  • Fairbanks, AK
  • Thank You
  • -Given: 988
  • -Received: 220
  • Ecobooster
    • Photos
  • Liked:
  • Likes Given: 0
« Reply #10 on: March 17, 2020, 11:33:04 AM »
Oh lame
Official Forum Sponsor of Ecoboost Performance Forum
