January 21, 2020, 02:05:50 AM
Author Topic: Voxx Leggero, 20x9.5, +35 offset  (Read 1012 times)
Offline CaptainInsane-O
  • Jr. Member
  • : TX
  • Thank You
  • -Given: 18
  • -Received: 22
  • Professional breaker of things. No, seriously!
« on: November 13, 2019, 09:43:33 AM »
Anyone running the 9.5" wide Voxx Leggero on their SHO?  I like the look and weight savings, but unfortunately(?) the 8.5 is back-ordered until January.
Thanks in Advance,
El Kapitan de Loco
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • Elite Member
  • : New York SHO
  • Thank You
  • -Given: 1809
  • -Received: 3830
Re: Voxx Leggero, 20x9.5, +35 offset
« Reply #1 on: November 13, 2019, 01:56:37 PM »
I think Debonair had 20x9 Vossen Cvt wheels with Nitto invo 265-30 tires on his SHO IIRC! I hope this helps any.  Z
https://www.ecoboostperformanceforum.com/index.php/topic,4611.msg72210.html#msg72210
« Last Edit: November 13, 2019, 02:01:54 PM by ZSHO »
  • Jr. Member
  • : TX
  • Thank You
  • -Given: 18
  • -Received: 22
« Reply #2 on: November 14, 2019, 03:17:36 PM »
The great and powerful wheel in the sky had other plans... the 9.5's are not available either (4 that showed in stock were ghosts) AND a screw took out my front passenger tire on the way home from work yesterday.  Limped the SHO into Discount and thankfully, the Continental's I requested on Tuesday had been delivered. I also decided to forego any thoughts of weight savings and ordered a set of black, 8.5" wide Mustang Performance replicas because they look mahhhvelous. New soles are on, and I am digging them but the Buford is still rocking stock shoes for around another week.
Yours Forever,
Das OF-2 of Whacked in da Melon
Offline lamrith
  • Elite Member
  • : PNW
  • Thank You
  • -Given: 106
  • -Received: 378
  • Ecobooster
« Reply #3 on: November 18, 2019, 12:02:47 PM »
Thanks in Advance,
El Kapitan de Loco
I am running the VOXX Lago 20*9.5 35 offset on my SHO with General G-MAX AS-05 275/40ZR20 tires, LOVE IT!  Traction for days, nice amount of poke from the fender, no rubbing.
You can fit 245's on them but it looks odd imho and not something I would think is good to run long term.  I did for a little bit since I had so much tread left on my 245's, but replaced the tires as soon as I found a good deal on the AS-05's.
You will need to get some hubcentric spacers/adapters to get a proper fit as the bore on the wheels is larger than the hub on the car.  Least that was the case for my Lago's, but worth checking.
'13 Sho PP, SCT x4, AJP 92-Octane rev6 (14psi&20spark) NGK 6510, 3Bar, K&N CAI, PPE Catted DP, Dynomax Axleback, 20*9.5 Voxx Lago.
  • Jr. Member
  • : TX
  • Thank You
  • -Given: 18
  • -Received: 22
« Reply #4 on: November 30, 2019, 05:38:13 PM »
New shoes are here and going on... will get installed pics tomorrow, after I wash some of the grime off of the beater.
* Featured Topics
* Recent Topics
Re: Quality time with my Son washing the Lincoln
by SHOdded | Today at 12:52:33 AM
Very cool.  Hang in there....
Re: Blower motor removal?
by SHOdded | January 20, 2020, 07:55:57 PM
If it is anything  like the Edge, you drop the glovebox to get at...
Summit Point, WV AutoX
by StealBlueSho | January 20, 2020, 08:43:34 AM
So I was looking into having some fun at Summit Point, WV autocross ju...
Re: Wrapping intake pipe, numbers are out<<<
by 802SHO | January 20, 2020, 05:04:52 AM
Interesting. I think more tests need to be performed to give the wrap ...
by SHOdded | January 20, 2020, 03:34:05 AM
Looks great, Z!  Sorry to hear, Bronco :(...
MOVED: 2010 Taurus SHO Rack and Pinion noise
by ZSHO | January 19, 2020, 01:56:42 PM
This topic has been moved to Admin-Moderator only discussion.https://w...
Re: 2010 SHO EPAS / Rack & Pinion Noise
by 6500rpm | January 19, 2020, 11:57:28 AM
Yup, one of the boots. On a lift the suspension geometry might change ...
Re: New Bro
by PDSHO | January 18, 2020, 05:11:25 PM
Greetings from Nebraska, I think your car is the same color as mine, t...
Re: SuperPete SHO Build record
by SuperPete | January 18, 2020, 03:56:57 PM
Can you check your plugs and confirm? just a few front plugs, should b...
Re: 2013 SHO Suspension Work
by ZSHO | January 18, 2020, 12:29:41 PM
I would order new bolts and Pad rubber (anti-sqeak) for a peace of min...
wiring schematic for the sony amp in 2015 edge or flex
by Hardwired | January 18, 2020, 11:24:24 AM
I'm looking for the wiring schematic for the 3 connectors that pl...
2016 Taurus 3.5L needing timing chain & water pump replacement ... help!
by SHOdded | January 18, 2020, 09:18:45 AM
Infamous water pump leak ...Located in Racine, WI.Can anyone help perf...
Re: MKS Suspension
by TopherSho | January 17, 2020, 09:18:17 PM
Mine rides like a rock until i drop the tires to less than 32psi, ...
Re: DannyMack 13 MKS "Old Man" Build and Maintenance Thread
by Dannymack | January 17, 2020, 02:22:58 PM
Finished up the rack today and added the bike racks. Wouldn't be ...
Re: 2014 Lincoln MKS EcoBoost with all the goodies
by Agentlongwood | January 17, 2020, 10:58:54 AM
Everybody I've interacted with on this forum has always been supe...
Back to top
