Ecoboost Performance
Performance
Boost a Pump to upgrade LPFP
Started by Gray Brick, September 04, 2019, 06:42:14 PM
Gray Brick
Sr. Member
Gray Brick
Has anyone experimented with the Kenne Bell Boost-a-Pump?
I have an upgraded HPFP and it seems my bottleneck is the LPFP at this point.
http://kennebell.net/accessories/boost-a-pump/
2013 Ecoboost Ford Flex
Forum Supporters
Re: Boost a Pump to upgrade LPFP
September 04, 2019, 07:00:22 PM
Years ago ... if you search on Ecobrick Bob's posts (he also had a Flex), you will find his opinion on this upgrade.
EcoPowerParts.com used to have a drop in LPFP upgrade, don't know if it is still offered, and if the OEM PCM can accommodate it.
Gray Brick
Sr. Member
Gray Brick
September 04, 2019, 07:23:39 PM
Would there be any reason that a boost a pump would not work for our platform?
Macgyver
Forum Supporters
2020 Red ST
September 05, 2019, 02:02:50 AM
Even in my Nissan Juke. We have LPFP upgrades.
Why not the Fords of this platform.
Performance
