January 18, 2021, 11:00:55 AM
Author Topic:  3rd cat & resonator delete feedback  (Read 6009 times)
Offline Mossdahaus
  • Jr. Member
  • Cincinnati
  • Thank You
  • -Given: 9
  • -Received: 6
  • Ecobooster
  • Liked:
  • Likes Given: 0
« on: September 01, 2019, 07:10:07 PM »
So I had a bright idea to order a replacement Xpipe from one of the major catback manufacturers to bolt in a resonator & 3rd cat delete.
Looking for feedback on tone, volume and rasp to go along with my current SW catted downpipes and stock mufflers on deleting these 2?
« Last Edit: September 01, 2019, 07:30:38 PM by Mossdahaus »
2015 Taurus SHO - Performance Pkg & Nav
SW catted DPs, Ford Racing exhaust, MSD Coils, SP542 Plugs, 170 tstat, 3bar MAP sensor, XDI-35 HPFP, modified Airaid intake, GH Intercooler, 18+ trans mount, JLT catch can & AJPTurbo E30 tune
Offline 802SHO
  • Currently World’s Fastest Ecoboost SHO
  • RotM Winner
  • Elite Member
  • Essex Junction Vermont
  • Thank You
  • -Given: 2431
  • -Received: 1154
  • Boosted
  • Liked:
  • Likes Given: 0
Re: 3rd cat & resonator delete feedback
« Reply #1 on: September 01, 2019, 07:19:14 PM »
The Xpipe will make it louder and it will probably get a little rasp but I think it will sound less raspy with your mufflers than if it were straight piped. Overall I think you'll find a little bit of rasp easy to live with.
Offline Chaplain
  • Newbie
  • Thank You
  • -Given: 6
  • -Received: 1
  • Ecobooster
  • Liked:
  • Likes Given: 0
« Reply #2 on: November 29, 2019, 12:23:11 AM »
I believe I have mostly done what your asking about to my '17 Explorer Sport.
From stock down pipes, exhaust goes into a 2.5" magnaflow X-pipe, then out into two straight 2.5" pipes back into twin Magnaflow hiflow mufflers (this section is Magnaflow's 2.5 explorer's setup.)
Sounds ok but dont expect a v8 sound. It's not loud but people will recognize you have an exhaust immediately.  You can hear the turbo's spooling out the exhaust which is cool.
Sent from my SM-G960U using Tapatalk
« Last Edit: December 24, 2019, 01:58:05 PM by Chaplain »
