"How-To" Replace Brake Light Bulb(s) on 2010-2012 SHO's.....
Started by bpd1151, July 05, 2013, 03:05:18 PM
****The below posted "How-To" Tutorial was originally written by a member of another community, of which I am also a staff member.
The creator, and all proper thanks and kudos goes out to the user name (at this other community) known as: "Unknown_Driver".****
Moving along...... here it is, as appeared elsewhere:
Things you will need:
One 7/16 wrench
3057 replacement bulb
So step one, go to your nearest auto parts place and select your appropriate model year:
Locate the part in the billions upon billions of other replacement bulbs:
Head home or somewhere well lit i chose my driveway, now walk to the trunk and press the trunk release button on the remote (you could also get your fingers dirty by touching the button above the license plate):
On the side where the burnt bulb is you will find 2 plastic screws in the trunk, unscrew these:
Now gently pull on the carpeted trunk liner and fold it over to reveal the back of the tail light trunk area.
There are 4 x 7/16 bolts you will need to remove (you can just losen them with the wrench and spin them off with your fingers:
After all 4 bolts are removed you will need to pull off a bit of the rubber trunk weather stripping gasket (just a little to help take out the tail light):
Now attempt to pull out the tail light partly, you can push on the bolts form the rear while holding the light:
Now that you have the light out you can now twist out the socket from the tail light housing, and unplug the or pull out the bulb from its connector (just replace the bulb):
Now put everything back and in the reverse order and it should be good to go, you can also have someone push on the brake pedal or put an object on the brake pedal to illuminate the light to confirm it is working properly:
EcoBrick Bob
I tried this on my Flex... and now I have 2  broken taillights... Funny thing.. there was nothing wrong... The bulbs still work, but now I had to paint them red!
Naples, FL & Clear Lake, IA
 :sun: Let the PIC Restoration keep on shining.  Z  :sun:
