From my understanding to alleviate any white smoke during morning startups only if they fail to let their turbo cool/spin down before shutdown the night before,try letting the engine idle a minute or two before shutoff,also condesation retains inside the mufflers and causes the white smoke effect,and you can also check your mufflers for any buildup through the little peep holes under the muffler bu using a small screwdriver to check to see if its clogged up.Z.
