SHO vs a 90's firebird
Started by ridered74, July 26, 2020, 10:45:24 PM
ridered74
After running 93 octane yesterday I had to stop on the way home and put some e85 in it for today's event. Was much more enjoyable even tho I won a round yesterday and lost every race that mattered today. Even managed to launch on the 2nd to last yellow bulb instead of the last yellow bulb in the actual points event.
This was just a qualifying run. I ran 12.213 @ 113.10 mph and the bird ran 12.692 @108.00. He killed me on reaction time .013 to .088 and that's really all that matters in these races. I got pretty consistent last year but with the new wheels and tires this year I just can't find any consistency at the light.
https://www.youtube.com/watch?v=iDpxwPmZBZE
Gearhead E30 tune, Gearhead intercooler, LMS firestorm hpfp, catted downpipes, corsa catback, 160 degree thermostat, 3 bar map, upgraded AD trans mounts, MSD coils, Nitto 555R drag tires on front, AR924 wheels and BFG sport comp 2 summer tires on rear, and an EPP intake.
12.2479 @ 118.05 fastest trap
11.591 @ 114.89   fastest ET
802SHO
Quote from: ridered74 on July 26, 2020, 10:45:24 PM
Looked like you reacted faster in the video
ridered74
Quote from: 802SHO on July 27, 2020, 07:14:53 AM
Just watched it a little closer and I agree with you, it does look like my car started moving first. Had to double check the time slip. Maybe he staged a little deeper than me, that's all I can think of unless the movement is some kind of optical illusion.
802SHO
Quote from: ridered74 on July 28, 2020, 12:27:16 AM
Must be I guess
