- Forum Supporters
- Elite Member
- Logged
https://saemobilus.sae.org/content/2016-01-2252QuoteFormation of Intake Valve Deposits in Gasoline Direct Injection Engines
Gregory Guinther - Afton Chemical Corp. , Scott Smith - Afton Chemical Corp.
Journal Article2016-01-2252
ISSN: 1946-3952, e-ISSN: 1946-3960
DOI: https://doi.org/10.4271/2016-01-2252
Published October 17, 2016 by SAE International in United States
Sector:
Automotive
Topic:
Engine lubricants, Combustion and combustion processes, Gasoline, Engine cylinders, Lubricants, Valves, Wear
Event:SAE 2016 International Powertrains, Fuels & Lubricants Meeting
Citation:
Guinther, G. and Smith, S., "Formation of Intake Valve Deposits in Gasoline Direct Injection Engines," SAE Int. J. Fuels Lubr. 9(3):558-566, 2016, https://doi.org/10.4271/2016-01-2252.
Language:English
Abstract:
Gasoline direct-injection (GDI) engines have a well-known propensity to form intake valve deposits (IVD), regardless of operator service, engine architecture, or cylinder configuration. Due to the lack of a fuel-washing process that is typical of Port Fuel Injected (PFI) engines, the deposits steadily accumulate over time and can lead to deterioration in combustion, unstable operation, valve-sticking, or engine failure. Vehicles using these engines are often forced to undergo expensive maintenance to mechanically remove the deposits, which eventually re-form. The deposit formation process has not been well-characterized and there is no standardized engine test to study the impact of fuel or lubricant formulation variables. To meet this need, a proprietary vehicle-based GDI-IVD test that is both repeatable and responsive to chemistry has been developed. Using a vehicle equipped with a 2.0L turbo GDI engine, the mechanisms leading to deposit formation have been studied and analyzed, and found to be a combination of engine oil, engine-wear elements, unburned fuel, and exhaust gas contaminants. The rate of accumulation was also found to be affected by engine lubricant formulation variables.
