Ecoboost Performance => Performance => Topic started by: fitnesstrainermd on March 06, 2019, 10:48:02 AM
Title: PPE DP Install shop
Post by: fitnesstrainermd on March 06, 2019, 10:48:02 AM
Can someone recommend a good shop to have the PPE DP's installed in the Alexandria VA area?
Title: Re: PPE DP Install shop
Post by: Sbouvia on March 06, 2019, 07:53:40 PM
Maybe Moore Automotive in Fairfax? I'm sure there are others.
Post by: SHOdded on March 06, 2019, 08:06:16 PM
Have BJSHO install them for you :D He's kinda local.
Post by: Sbouvia on March 06, 2019, 08:46:10 PM
Also the place BJSHO went to dyno his car down in Richmond, National Speed. The you can dyno it before and after on the linked rollers.
Post by: SM105K on March 07, 2019, 09:08:00 AM
Quote from: SHOdded on March 06, 2019, 08:06:16 PM
I miss BJSHO's old screen name.
Post by: StealBlueSho on March 07, 2019, 09:41:16 AM
Last time I had Downpipes installed, I used my go to shop, $200 installed which I was happy to fork over so I didn't have to do it.
Murphy's Motorsports, Warrenton, VA 20186
5403596581
Mike runs the front counter and Brian is the owner.
I'm actually in the shop right now getting a custom fuel line made lol.
Post by: SM105K on March 07, 2019, 10:13:27 AM
Quote from: sm105k on March 07, 2019, 09:08:00 AM
YES WELCOME BACK SBS!
Post by: 802SHO on March 07, 2019, 12:13:37 PM
Quote from: StealBlueSHO on March 07, 2019, 09:41:16 AM
5403596581
What are you scheming with your custom fuel line....that goes through your 🔥 wall....mid pump?
Post by: StealBlueSho on March 07, 2019, 12:23:17 PM
Quote from: 802SHO on March 07, 2019, 12:13:37 PM
5403596581
What are you scheming with your custom fuel line....that goes through your wall....mid pump?
Negative. LMS uses the stock fuel lines for their HPFP. In order to pop an ethanol analyzer on the line I need a female to female quick disconnect line. The stock on is female to male.
Post by: 802SHO on March 07, 2019, 12:29:08 PM
Quote from: StealBlueSHO on March 07, 2019, 12:23:17 PM
5403596581
That's sweet.  No more guessing what blend you've got!
Post by: ZSHO on March 07, 2019, 01:10:22 PM
I Would highly suggest to install new Gaskets for a leak free exhaust system. Z
Here are the part numbers needed and also optional Catalytic Converter Stud!
BTW can add the Gaskets to the list for a STICKY!!! Z
BOLT  $4.89
https://parts.levittownfordparts.com/oem-parts/ford-front-pipe-bolt-w714826s900
(https://i.imgur.com/oqcx5oYh.jpg)
NUT  $1.44
https://parts.levittownfordparts.com/oem-parts/ford-front-pipe-nut-w714265s441
(https://i.imgur.com/KPEhZU2h.jpg)
$3.16  STUD
https://parts.levittownfordparts.com/oem-parts/ford-catalytic-converter-stud-w712829s900
(https://i.imgur.com/de9ndyph.jpg)
Catalytic Converter Gasket - Ford (AA5Z-6L612-A)
(https://i.imgur.com/H8NrfGVh.jpg)
https://parts.levittownfordparts.com/oem-parts/ford-catalytic-converter-gasket-aa5z6l612a/?c=bT0x
Front Pipe Gasket - Ford (7T4Z-9450-AA)
(https://i.imgur.com/0gLgxlCh.jpg)
https://parts.levittownfordparts.com/oem-parts/ford-front-pipe-gasket-7t4z9450aa/?c=Zz1leGhhdXN0LXN5c3RlbSZzPWV4aGF1c3QtY29tcG9uZW50cyZpPUpOMTAyOTc1JnI9OCZhPWZvcmQmbz10YXVydXMmeT0yMDEzJnQ9c2hvJmU9My01bC12Ni1nYXM%3D
Post by: SHOdded on March 07, 2019, 03:44:09 PM
Hmmm, sounds like a Schrader valve there, SBS :D  Something that used to be common on fuel rails 10+ years ago.
Post by: StealBlueSho on March 07, 2019, 04:38:59 PM
Quote from: SHOdded on March 07, 2019, 03:44:09 PM
Yea, it's not a schrader valve :-/ that would have been easier and cheaper!
3/8 quick disconnect.
Post by: MKS Tom on May 05, 2019, 09:47:37 PM
Quote from: ZSHO on March 07, 2019, 01:10:22 PM
BOLT  $4.89
NUT  $1.44
$3.16  STUD
Really stupid question but...
4 bolts
6 studs
10 nuts
and 2 gasket for each?
I just want to make sure I have all of the parts in the correct amounts ready to had to my mechanic to get this installed as they will be showing up soon.  Thank you.
Post by: ZSHO on May 06, 2019, 05:28:32 PM
@- MKS Tom- The Gaskets are mandatory and while using Double-gaskets have proven to be ideal for a leak free system and for a peace of mind.
The Bolts-Studs and Nuts are optional and for back-up purposes because sometimes rust and corrosion buildup makes the removal process that more challenging while avoiding extra Trips to the Dealer..
BTW PB Blaster is a must in order to remove the Bolts! Best of luck on the install! Z
FYI- The accessories do come in a Package Quantity of 4.
PICS and Part numbers for reference below!
4-Bolts
https://www.fordpartsgiant.com/parts/ford-bolt_-w714826-s900.html?Vin=1FAHP2KT5DG183206&Filter=() (https://www.fordpartsgiant.com/parts/ford-bolt_-w714826-s900.html?Vin=1FAHP2KT5DG183206&Filter=())
10-M10-Nuts
https://www.fordpartsgiant.com/parts/ford-nut_-w714265-s441.html?Vin=1FAHP2KT5DG183206&Filter=() (https://www.fordpartsgiant.com/parts/ford-nut_-w714265-s441.html?Vin=1FAHP2KT5DG183206&Filter=())
6-Studs
https://www.fordpartsgiant.com/parts/ford-stud_-w712829-s900.html?Vin=1FAHP2KT5DG183206&Filter=() (https://www.fordpartsgiant.com/parts/ford-stud_-w712829-s900.html?Vin=1FAHP2KT5DG183206&Filter=())
TURBO MOUNTING STUD  FORD W712829S900  $3.47
FORD W714265S441 M-10 NUT $1.54
https://www.rockauto.com/en/parts/ford,W712829S900,stud,1000805 (https://www.rockauto.com/en/parts/ford,W712829S900,stud,1000805)
https://www.rockauto.com/en/parts/ford,W714265S441,nut,1000377 (https://www.rockauto.com/en/parts/ford,W714265S441,nut,1000377)
(https://i.imgur.com/uhRwxweh.jpg?1)
(https://i.imgur.com/ztbGDB2h.jpg?1)
FORD AA5Z6L612A  GASKET $11.04
https://www.rockauto.com/en/partsearch/?partnum=AA5Z6L612A (https://www.rockauto.com/en/partsearch/?partnum=AA5Z6L612A)
(https://i.imgur.com/hpR9CHqh.jpg)
FORD 7T4Z9450AA  Pipe Flange Gasket / Seal  $7.31
https://www.rockauto.com/en/partsearch/?partnum=7T4Z9450AA (https://www.rockauto.com/en/partsearch/?partnum=7T4Z9450AA)
(https://i.imgur.com/YKyj6Rih.jpg)
Post by: ridered74 on May 07, 2019, 12:27:52 AM
5403596581
Next time you are in there, tell them they did a great job on that fuel line. Pretty sure it knocked at least a tenth off my time.
Post by: StealBlueSho on May 07, 2019, 08:34:10 AM
Quote from: ridered74 on May 07, 2019, 12:27:52 AM
5403596581
Lmao...
