Ecoboost Performance => General Discussion => Topic started by: AJP turbo on March 01, 2019, 11:02:46 PM
Title: Boost solenoid vac lines
Post by: AJP turbo on March 01, 2019, 11:02:46 PM
Quick question been a while since I've looked. I'm trying to help someone trouble shoot.
The reference from the charge pipe goes into the boost solenoid. There are 2 lines coming out of the solenoid.
Does each one go to the canisters on the turbos? OR does one go back to the intake piping somewhere and the other splits and then goes to each canister?
Thanks!
Title: Re: Boost solenoid vac lines
Post by: BoostfoSHO on March 01, 2019, 11:15:45 PM
Quote from: AJP turbo on March 01, 2019, 11:02:46 PM
Thanks!
IIRC one goes back to the intake and the other goes and later splits for each of the wastegates.
Sent from my SM-N960U using Tapatalk
Post by: BoostfoSHO on March 01, 2019, 11:19:04 PM
If you zoom in enough you can sort of see where the hoses go.(https://uploads.tapatalk-cdn.com/20190302/9dbf579de8811f8ac2bd6cd20c06de19.jpg)
Post by: AJP turbo on March 01, 2019, 11:22:55 PM
Thanks Boostfo!
So the vac line that exits the solenoid and is closest to the radiator goes to the intake pipe and the line that exits the solenoid facing the driver fender is the one that eventually splits and goes to the canisters?
I can't tell which one goes where since it's under the charge pipe
Post by: ZSHO on March 02, 2019, 12:01:20 AM
Pic's & all mid page! Z
https://www.ecoboostperformanceforum.com/index.php/topic,463.3495.html (https://www.ecoboostperformanceforum.com/index.php/topic,463.3495.html)
Post by: BoostfoSHO on March 02, 2019, 12:02:22 AM
Quote from: AJP turbo on March 01, 2019, 11:22:55 PM
Thanks Boostfo!
That's correct.
Post by: AJP turbo on March 02, 2019, 12:55:26 AM
Now I'm more confused....So does the guy in this pic have it wrong?
It looks like the vac line that EXITS the solenoid facing the driver fender goes to the pre-turbo intake pipe
This isn't the person I'm troubleshooting for but just a random pic I found.
Post by: ZSHO on March 02, 2019, 08:21:27 AM
Quote from: AJP turbo on March 02, 2019, 12:55:26 AM
I believe that PIC it wrong and the very reason the wastegate hose should be under the charge pipe and NOT on TOP! The other reference hose (line) goes to the rear and has a Tee which splits to rear and front of canisters IIRC! Z
(http://i64.tinypic.com/r1mrzm.jpg)
(http://i66.tinypic.com/2zromye.jpg)
Post by: SHOdded on March 02, 2019, 09:00:23 AM
Dont know if this will help but here is info from BiGMaC's hotpipes install
http://www.ecoboostperformanceforum.com/index.php/topic,2248 (http://www.ecoboostperformanceforum.com/index.php/topic,2248)
Post by: AJP turbo on March 02, 2019, 12:04:40 PM
Quote from: SHOdded on March 02, 2019, 09:00:23 AM
YES! that has a great pic, here is the money shot!
Post by: ZSHO on March 02, 2019, 06:05:06 PM
That's funny cause did Re touch the Pics recently in that thread to Ocd specs! Z  :)
Post by: SHOdded on March 02, 2019, 08:30:03 PM
Cool!
