Detailing, SYNC, AV, Security, Electrical, and Lighting => Exterior Modifications => Topic started by: polskifacet on January 29, 2019, 12:31:20 PM
Title: Splash Cover Repair
Post by: polskifacet on January 29, 2019, 12:31:20 PM
Hey Guys,
Some pictures of the fiberglass patches I made for the undercover. Unfortunately I just broke the repaired cover again last night. Try to avoid backing up over snow as the cover then acts like a big shovel and buckles.
(http://polskifacet.dynu.com:55698/uploader/uploads/Pictures/SHO/SplashCover/ucover1.jpg)
(http://polskifacet.dynu.com:55698/uploader/uploads/Pictures/SHO/SplashCover/ucover2.jpg)
(http://polskifacet.dynu.com:55698/uploader/uploads/Pictures/SHO/SplashCover/ucover3.jpg)
Title: Re: Splash Cover Repair
Post by: ZSHO on January 29, 2019, 01:19:24 PM
Need to be careful it doesn't fly off! Z
Here's the Under cover for reference. - Ford (DA8Z-9910494-A)
$100.33
(http://i66.tinypic.com/2mcdc89.jpg)
https://www.tascaparts.com/oem-parts/ford-under-cover-da8z9910494a/?c=Zz1ib2R5JnM9cmFkaWF0b3Itc3VwcG9ydCZpPUtEMDkwMjU1JnI9MTEmYT1mb3JkJm89dGF1cnVzJnk9MjAxMyZ0PXNobyZlPTMtNWwtdjYtZ2Fz (https://www.tascaparts.com/oem-parts/ford-under-cover-da8z9910494a/?c=Zz1ib2R5JnM9cmFkaWF0b3Itc3VwcG9ydCZpPUtEMDkwMjU1JnI9MTEmYT1mb3JkJm89dGF1cnVzJnk9MjAxMyZ0PXNobyZlPTMtNWwtdjYtZ2Fz)
https://www.tascaparts.com/auto-parts/2013/ford/taurus/sho-trim/3-5l-v6-gas-engine/body-cat/radiator-support-scat/?part_number=da8z9910494a (https://www.tascaparts.com/auto-parts/2013/ford/taurus/sho-trim/3-5l-v6-gas-engine/body-cat/radiator-support-scat/?part_number=da8z9910494a)
Post by: donky4444 on January 29, 2019, 08:32:19 PM
I just had to fix mine tonight due to snow. The back two connectors let go and it was dragging. I got it to a friends heated shop and up on ramps. I lost the passenger side rear connector so that got a big zip tie and the drivers side was jacked up but I got it fixed and reattached. Fingers crossed it holds now.
Post by: 802SHO on January 30, 2019, 01:34:49 PM
I didn't know there was an undercover shield.  All I have is a splash guard.
Post by: ZSHO on January 30, 2019, 01:59:14 PM
Quote from: 802SHO on January 30, 2019, 01:34:49 PM
There is a lower Deflector and an undercover as mentioned ^^^. Z
https://www.tascaparts.com/oem-parts/ford-lower-deflector-ag1z8327a/?c=Zz1ib2R5JnM9cmFkaWF0b3Itc3VwcG9ydCZpPUpOMTAwMzE1JnI9NyZhPWZvcmQmbz10YXVydXMmeT0yMDEzJnQ9c2hvJmU9My01bC12Ni1nYXM%3D (https://www.tascaparts.com/oem-parts/ford-lower-deflector-ag1z8327a/?c=Zz1ib2R5JnM9cmFkaWF0b3Itc3VwcG9ydCZpPUpOMTAwMzE1JnI9NyZhPWZvcmQmbz10YXVydXMmeT0yMDEzJnQ9c2hvJmU9My01bC12Ni1nYXM%3D)
Post by: 802SHO on January 30, 2019, 02:06:45 PM
Oh its in the rear
Post by: ZSHO on January 30, 2019, 02:28:53 PM
Quote from: 802SHO on January 30, 2019, 02:06:45 PM
Oh its in the rear
The under cover is the larger of the two shields located under the oil filter,so technically you will need to remove that in order to gain access to oil filter & plug, 02 sensor..
The lower Deflector is in the front lower bumber area pictured below. Z
(http://i63.tinypic.com/25z353n.jpg)
Post by: 802SHO on January 30, 2019, 07:24:10 PM
Quote from: ZSHO on January 30, 2019, 02:28:53 PM
Oh its in the rear
Is this on all years?  I bought my car used and its never had that cover hiding the oil filter,plug + O2 sensor.  Explains why this was puzzling to me lol
Post by: SHOdded on January 30, 2019, 07:37:48 PM
Yes all years.
Post by: Sbouvia on January 30, 2019, 08:28:18 PM
Whoa I am supposed to remove something to change the oil filter/drain the oil? We bought our 2013 brand new in November of 2012 and I do not think I have that cover. I can just grab my oil filter and take it off.
Post by: ZSHO on January 30, 2019, 08:50:48 PM
Thats a bit odd because Both my 13 SHO' S Had the cover underneath!
Sometimes the dealer forgets to install it after having it serviced and has happened too me on a couple occasions..
The XSPORT on the other hand Does NOT have a cover IIRC. Z
Post by: SHOdded on January 31, 2019, 06:31:35 AM
2010 SHO
(https://dz310nzuyimx0.cloudfront.net/strapr1/2da245fe6dc9cc4d17200fc5566496b5/e16c5821f3bb92ef4ea38b9ed58d5232.png)
#6, 10
Post by: ZSHO on January 31, 2019, 06:47:46 AM
The best method is to open your hood and take a peep between the front engine and Fans,looking straight down to see if there is a cover or bear floor.
I would also avoid Auto car washes as they can pull it off to non existence.  Z
Post by: 802SHO on January 31, 2019, 06:52:59 AM
Quote from: ZSHO on January 31, 2019, 06:47:46 AM
I would also avoid Auto car washes as they can pull it to non existence.  Z
Yes I have the splash guard that attaches that covers that area (aux cooler, Alky pump and fog lights) but the bigger cover...never had.
If it wasn't for this post I never would have known I was supposed to have one.  Still learning about my SHO😏
Post by: ZSHO on January 31, 2019, 07:01:47 AM
Quote from: 802SHO on January 31, 2019, 06:52:59 AM
That cover is made for aerodynamics and acts as a protective barrier against the elements while ultimately slowing you down @ the track. Z   ;D
Post by: 802SHO on January 31, 2019, 07:21:27 AM
I just had to look between the fans and front of the engine.  I thought the splash guard covered that area but you are correct I don't have the undercover shield and I can see the ground.  Ok ok I have reached full understanding now....hope that wasnt a timed event 😬
Post by: SHOdded on January 31, 2019, 09:46:57 AM
When you buy these cars used, it is frequent for splash shields, engine appearance covers, even hpfp covers and tb motor covers to go missing.  Most of the time not a big deal operationally, unless you are into the triple digit speeds often.
Post by: jman on January 31, 2019, 10:02:17 AM
Me too...
Post by: ZSHO on January 31, 2019, 10:49:43 AM
Good INFO pertaining to the 2010MY! Z  :)
https://www.ecoboostperformanceforum.com/index.php/topic,5848.msg92158/topicseen.html#msg92158 (https://www.ecoboostperformanceforum.com/index.php/topic,5848.msg92158/topicseen.html#msg92158)
Post by: Sbouvia on February 02, 2019, 01:38:35 PM
Ours was brand new. I'm going to blame Ted Britt in Chantilly. The one time I had my oil changed there they didn't put the dipstick back in all the way and I didn't check until we drove almost 500 miles North and I was wondering why the car smelled like oil. Opened hood and oil was everywhere. I'm assuming they forgot to put bottom cover back on at this time as well. Is it worth it to order one, seeing as I've drive like 96k without it?
Post by: ZSHO on February 02, 2019, 02:07:54 PM
If you plan on keeping it for long-term such as myself then why not IMO!
As mentioned earlier it also acts as a protective barrier from the oil pan plus elements,while keeping your engine bay cleaner.
I recall a while back while driving home from the dealer visit noticed the hood vibrating @ highway speeds due to the fact they forgot to install the under cover shield back on and luckily they replaced it with a new one. Z
Post by: Sbouvia on February 02, 2019, 02:20:34 PM
Is there a part number for the fasteners if they are not there? I'll look tomorrow when it's supposed to be 50 or so out as opposed to today where it's only 40
Post by: ZSHO on February 02, 2019, 02:26:46 PM
Quote from: Sbouvia on February 02, 2019, 02:20:34 PM
I hope this helps any. Z
https://www.ecoboostperformanceforum.com/index.php/topic,6434.msg99948.html#msg99948 (https://www.ecoboostperformanceforum.com/index.php/topic,6434.msg99948.html#msg99948)
https://www.ecoboostperformanceforum.com/index.php/topic,9363.msg140714.html#msg140714 (https://www.ecoboostperformanceforum.com/index.php/topic,9363.msg140714.html#msg140714)
Post by: ZSHO on February 02, 2019, 04:09:27 PM
Here are the accessories needed for the (Under Cover Shield)
I will set this Topic sticky!  Z
Under Cover Screw - Ford (AG1Z-00817-A) $9.74
https://www.tascaparts.com/oem-parts/ford-under-cover-screw-ag1z00817a (https://www.tascaparts.com/oem-parts/ford-under-cover-screw-ag1z00817a)
(https://i.imgur.com/u1nttWY.jpg)
Under Cover Retainer Nut - Ford (-W716006-S439) $1.56
https://www.tascaparts.com/oem-parts/ford-under-cover-retainer-nut-w716006s439/?c=bT0x&recommended=1 (https://www.tascaparts.com/oem-parts/ford-under-cover-retainer-nut-w716006s439/?c=bT0x&recommended=1)
(https://i.imgur.com/ceFovNUm.jpg)
Bracket - Engine Support - Ford (AG1Z-6096-A)  $1.06
https://www.tascaparts.com/oem-parts/ford-bracket-engine-support-ag1z6096a (https://www.tascaparts.com/oem-parts/ford-bracket-engine-support-ag1z6096a)
(https://i.imgur.com/xtfeI1Rh.jpg)
Post by: Sbouvia on February 02, 2019, 05:55:05 PM
Just to be clear, unless you have some of those pieces on your car you need 4 of each for under cover screw, under cover retainer nut and bracket-engine support correct? The cover itself doesn't come loaded with anything right?
Post by: Sbouvia on February 02, 2019, 06:02:22 PM
Also kind of weird that Tasca says the screw does not fit the 2013 SHO. The parts diagram for the 2013 doesn't show any screw.
Post by: ZSHO on February 02, 2019, 06:25:41 PM
I like to use www.fordpartgiant.com (http://www.fordpartgiant.com) which is a bit more decriptive and accurate based on part numbers.
I would suggest to contact them to confirm exactly what comes with the Under cover shield PRIOR to ordering IMO!
The parts below are based from my Vin number. Z   :)
https://www.fordpartsgiant.com/parts/ford-fastener_ag1z-00817-a.html?Vin=1FAHP2KT5DG183206&Filter=() (https://www.fordpartsgiant.com/parts/ford-fastener_ag1z-00817-a.html?Vin=1FAHP2KT5DG183206&Filter=())
https://www.fordpartsgiant.com/Page_Product/PartDetail.aspx?Vin=1FAHP2KT5DG183206&Filter=()&SubCategoryUrl=air-deflectors&Diagram=&PartNumbers=-W716006-S439 (https://www.fordpartsgiant.com/Page_Product/PartDetail.aspx?Vin=1FAHP2KT5DG183206&Filter=()&SubCategoryUrl=air-deflectors&Diagram=&PartNumbers=-W716006-S439)
SHIELD
https://www.fordpartsgiant.com/parts/ford-cover_da8z-9910494-a.html?Vin=1FAHP2KT5DG183206&Filter=()&Location=air-deflectors,,%3C10494 (https://www.fordpartsgiant.com/parts/ford-cover_da8z-9910494-a.html?Vin=1FAHP2KT5DG183206&Filter=()&Location=air-deflectors,,%3C10494)
Post by: ZSHO on February 03, 2019, 07:44:58 AM
Great to see many benefiting from this thread.  Z   :)
Post by: Sbouvia on February 11, 2019, 07:44:11 PM
So just got the lower cover in from Tasca. It comes loaded with screws and bushings. Need to check on the car to see if the retainers are still on for the screws to go into. I also bought a under cover retainer (AA8Z-16K262-A) in case that's gone. Need to return the screws and the bushings. Maybe this weekend if it's not too bad out.
Post by: SHOdded on February 12, 2019, 06:42:53 AM
2010-12 SHOs use this part number:      DE9Z-9910494-C
https://www.fordpartsgiant.com/parts/ford-cover_de9z-9910494-c.html?Make=Ford&Model=Taurus&Year=2012&Submodel=&Filter=(38591;30734) (https://www.fordpartsgiant.com/parts/ford-cover_de9z-9910494-c.html?Make=Ford&Model=Taurus&Year=2012&Submodel=&Filter=(38591;30734))
(https://www.fordpartsgiant.com/resource?t=pp&s=l&r=578F303602A18E0CB0C5A6B595DEE8B3BC1DBF8082D54BCA67392CC530F8D82F3816A7580C949D5D2D02872D5641FAB684EC5BC8649F508DAD5B126F52786F56DA73330946B8F094)
