Ecoboost Performance => How To Articles => Topic started by: ZSHO on January 07, 2019, 06:43:35 PM
Title: Radar rear view mirror Tap!
Post by: ZSHO on January 07, 2019, 06:43:35 PM
Here's a very Brief "How to" as promised a while ago!
I purchased the Radar Mount RJ11 Mirror Wire Radar Detector Hardwire Power Cord from www.amazon.com (http://www.amazon.com) .
Remove the black plastic piece gently against the windshield using a small flat head screw driver..
The RJ11- Tab adapters unfortunately were to big and did NOT use them and simply spliced into the according wires as shown and pictured below...
I then spliced into the TOP BLACK WIRE which is your GROUND To BLACK on RG11 CORD
The 2nd YELLOW/BROWN WIRE will be your POWER TO RED ON RJ11 CORD as shown on the below Pic.
If you have any questions please feel free to ask.  Z  :)
Here's my previous "How TO" Hard-wire your Radar detector.
https://www.ecoboostperformanceforum.com/index.php/topic,6964.0.html (https://www.ecoboostperformanceforum.com/index.php/topic,6964.0.html)
(https://i.imgur.com/yen29Gth.jpg?1)
(https://i.imgur.com/wksSW4Nh.jpg?1)
(https://i.imgur.com/gIwS6yGh.jpg)
(https://i.imgur.com/X29NZmzh.jpg)
(https://i.imgur.com/LMUlPNah.jpg)
(https://i.imgur.com/v1AqSGph.jpg)
(https://i.imgur.com/7Ix0F15h.jpg)
https://www.amazon.com/Radar-Mount-Detector-Hardwire-3005201U/dp/B078939GZ2/ref=pd_ybh_a_1?_encoding=UTF8&psc=1&refRID=01GCW2DW9F03QN6M9PK8 (https://www.amazon.com/Radar-Mount-Detector-Hardwire-3005201U/dp/B078939GZ2/ref=pd_ybh_a_1?_encoding=UTF8&psc=1&refRID=01GCW2DW9F03QN6M9PK8)
Title: Re: Radar rear view mirror Tap!
Post by: SHOdded on January 07, 2019, 08:07:11 PM
That was a LONG writeup, 7000+ words in fact!  :D
Post by: ZSHO on January 07, 2019, 08:57:57 PM
Quote from: SHOdded on January 07, 2019, 08:07:11 PM
The lack of patience @ my age leave a lot to be desired.  Z
Post by: Brewineer on February 15, 2019, 09:22:12 PM
Thanks for the guide, I just wired up my dashcam to the rearview mirror power leads. Mine had different colors, but the same positions on the header were the correct wires.
Very satisfying quick little DIY, and now I've got the stealthiest dashcam possible unless I were able to fit one into the shroud itself.
I used this to convert from battery voltage to 5V for the mini-USB daschcam cable:
https://www.amazon.com/gp/product/B071FJVRCT/ref=ppx_od_dt_b_asin_title_s00?ie=UTF8&psc=1 (https://www.amazon.com/gp/product/B071FJVRCT/ref=ppx_od_dt_b_asin_title_s00?ie=UTF8&psc=1)
Post by: ZSHO on February 16, 2019, 07:01:17 AM
Glad this thread was of some assistance and straight to the point. Lol.  Z   :D
Post by: ZSHO on March 18, 2019, 05:43:16 PM
Sorry for the delayed update just been busy with lifes daily obstacles and all!
Here are a few PICS for reference and everything is working as designed.  :)
I ended up using some T-Tap's and added a Fuse protector for Good measures. Z
FYI- The Yellow/Brown wire with the Fuse is your POWER wire and the BLACK is your GROUND
(https://i.imgur.com/WRu8Q97h.jpg)
(https://i.imgur.com/0mpf9yPh.jpg)
(https://i.imgur.com/0KbrJOUh.jpg)
Post by: Macgyver on March 18, 2019, 07:22:13 PM
Obviously this would work for a Dash Cam too ?
12volt switched on with the ignition.
Post by: FoMoCoSHO on March 18, 2019, 07:48:28 PM
Quote from: Macgyver on March 18, 2019, 07:22:13 PM
If you do switched than you lose auto on while parked if its hit.
This becomes tricky in the SHO as all 3 SHOs in our family had/have defective battery management so running the battery down is a distinct possibility.
One way around this would be to run a USB brick somewhere charging to USB 24/7 (when car is on) then run the cam off that. This scheme might require an overnight charge of the brick once in a while. My cam in the CMAX is currently running directly off the OEM USB. Not sure if other brands will work like that.
Edited for further thoughts
Post by: ZSHO on March 18, 2019, 08:07:38 PM
FWIW AUCEE Dash Cam Hardwire kit, Mini USB Port,DC 12V - 36V to 5V/2A Max Car Charger Cable kit with Fuse,Low Voltage Protection for Dash Cameras. Z
https://www.amazon.com/AUCEE-Dash-Cam-Hardwire-kit/dp/B077C1HTPK/ref=sr_1_fkmrnull_1?keywords=AUCEE+Dash+Cam+Hardwire+kit%2C+Mini+USB+Port%2CDC+12V+-+36V+to+5V%2F2A+Max+Car+Charger+Cable+kit&qid=1552953937&s=gateway&sr=8-1-fkmrnull (https://www.amazon.com/AUCEE-Dash-Cam-Hardwire-kit/dp/B077C1HTPK/ref=sr_1_fkmrnull_1?keywords=AUCEE+Dash+Cam+Hardwire+kit%2C+Mini+USB+Port%2CDC+12V+-+36V+to+5V%2F2A+Max+Car+Charger+Cable+kit&qid=1552953937&s=gateway&sr=8-1-fkmrnull)
Post by: FoMoCoSHO on March 18, 2019, 08:19:10 PM
Quote from: ZSHO on March 18, 2019, 08:07:38 PM
Lol, is it me or does the first pic show an AC plug?
Post by: SHOdded on March 19, 2019, 01:42:59 AM
mini usb port LOL
Post by: Macgyver on March 19, 2019, 02:51:14 AM
Yeah I have one of those kits already. I was just thinking if you could wire it up there it might be easier.
Post by: FoMoCoSHO on March 19, 2019, 08:38:05 AM
Quote from: SHOdded on March 19, 2019, 01:42:59 AM
mini usb port LOL
Ugh, upon closer inspection I need better eyes or a new screen...
Post by: SHOdded on March 19, 2019, 11:27:08 AM
nah, it was just very deceiving ...
