Ecoboost Performance => Troubleshooting, Maintenance, TSB Articles => Troubleshooting => Topic started by: StealBlueSho on August 29, 2018, 03:14:10 PM
Title: rhythmic vibration at 67mph+
Post by: StealBlueSho on August 29, 2018, 03:14:10 PM
Car is back at the dealership... I am getting this rhythmic vibration from the front driverside of the car at higher speeds... this is the second stint at the dealership for this... first time they just did a road force balance of the tires and sent me on my way... that did not resolve the issue... it also sometimes makes a grinding noise when making a U-turn going left..
Not sure if its a wheel bearing issue as it presents like that as the vibration gets louder when you load up the left side..
oh.. and they quoted me $900 to install my new HR lowering springs...
Title: Re: rhythmic vibration at 67mph+
Post by: lamrith on August 29, 2018, 03:29:05 PM
Quote from: StealBlueSho on August 29, 2018, 03:14:10 PM
OUCH, seems a bit high for springs, but again, this is dealer labor $/hr..
Post by: StealBlueSho on August 29, 2018, 03:32:22 PM
Quote from: lamrith on August 29, 2018, 03:29:05 PM
Yea... the service advisor was a bit shocked.. he pulled the labor times from the Ford recommended times.. and even tried pulling the Alldata hours... which he said they can quote as well... 1.8hrs for the rear and 4.0hours for the front... plus an extra hour (just to be safe he said) to get the rear camber back in alignment... then an alignment...
My local speed shop quoted me $250..
Post by: geophb on August 29, 2018, 03:51:04 PM
Sounds like wheel bearing to me. Jack it up and see if you can move the wheel.
Post by: lamrith on August 29, 2018, 04:12:30 PM
Quote from: StealBlueSho on August 29, 2018, 03:32:22 PM
4hrs for the front seems kind of slow.  Now that I have done it, it is actually pretty darn quick to do, 2-3hrs would be my estimated realistic timeframe.  Especially with a trained mechanic in a shop with all the right tools and air tools.  Including alignment that $900 is not quite as bad though, but still high.  The $250 at speed shop though seems too far to the low side, I am guessing that does not include alignment?
Do you have a Firestone in the area?  Not sure what they charge for a swap like that, but the reason I bring it up is that they have  lifetime alignment package.  Usually $200, but sometimes it goes on sale for $150.  I opted for that when I did my springs and glad I did as now that I pulled them and returned to stock I need alignment done again.  Comes in handy if you forsee changing suspension down the road.
Post by: StealBlueSho on August 29, 2018, 04:33:45 PM
I might just pull the front myself, take them to a shop to have the springs switched...I can do the rest of it..
Post by: ZSHO on August 29, 2018, 04:52:15 PM
It sounds like your Hubs aka (wheel bearings) IMO!I
I recently had mine changed and found more than 1/4 of play coming from the left driver's side.
I find it strange that its always the left (driver's side) thats mostly affected! Dunno!
Here's my most recent post below.
There is also an updated TSB IIRC!
Z
https://www.ecoboostperformanceforum.com/index.php/topic,299.5085.html (https://www.ecoboostperformanceforum.com/index.php/topic,299.5085.html)
(https://i.imgur.com/8jO6L1uh.jpg?1)
Post by: SHOdded on August 29, 2018, 05:37:28 PM
would have the wheel checked over by a pro for crack/out of round/overtightened lugs etc. if other suggestions do not help.
Post by: 4sfed on August 29, 2018, 05:53:13 PM
I'll see your wheel bearing and raise you "a bad tire".  I'm thinking a bad spot on the sidewall. At speed I think it heats up and bulges out.
Post by: StealBlueSho on August 29, 2018, 08:00:01 PM
Ok... well this f*cking dealer was supposed to call me before they closed to let me know what was going on... no phone call....
I'm calling first thing in the morning....or going over there... if they haven't figured it out I'm taking the car.... this is the second time I have had warranty work done there... the first time took over a week for them to replace a motor mount, road force balance the tires, drive my car for 60 miles, and scratch my car....
Unfortunately they are the only dealership within 45 minutes of my house... hoping for a better line of communication this time.... apparently I am asking too much...
Post by: SHOdded on August 30, 2018, 12:04:41 AM
Need to stop living in a nuclear bunker, buddy!  I do feel your pain, though.  I have unlimited choices within 5 miles of me LOL.
Post by: StealBlueSho on August 30, 2018, 10:21:30 AM
Just got a call back... no noises.. everything checks out on the lift... they cannot find the problem... another waste of time... this is the LAST time I am taking my car to this dealership... I am done.
Post by: SHOdded on August 30, 2018, 10:36:07 AM
Then they will be toasting success!  Prob dont want customers who are tuned into their cars.
Post by: ZSHO on August 30, 2018, 10:41:02 AM
Is the noise consistent or intermittent,depending on weather! FWIW might want to research a Lincoln Dealer in the vicinity!!! some food for thought! Z
Post by: Gray Brick on August 30, 2018, 11:43:42 AM
Do your wheels have need/have concentric spacers? If they are aftermarket they might need them.
Post by: StealBlueSho on August 30, 2018, 12:15:33 PM
Quote from: ZSHO on August 30, 2018, 10:41:02 AM
No, they said they tried to duplicate the noise after I brought it in while everything was still at operational temps and then again this morning after letting it sit... I might need to look for lincoln dealer... the closest one I know is 30+ miles away...
Quote from: Gray Brick on August 30, 2018, 11:43:42 AM
Nah, stock flowers or as I like to call them "Ninja Stars of Death"
Post by: lamrith on August 30, 2018, 12:26:54 PM
Betting it is a bearing a well.
Only thing I can thing to narrow it down more is to rotate tires around and make sure the issue does not move to another location.
Then call the lincoln dealer, let them know issue, and setup a day/time to go and that you want to take the service writer and/or mechanic out for a drive to show them the issue before you leave the car with them..?
Post by: StealBlueSho on August 30, 2018, 09:33:23 PM
Quote from: lamrith on August 30, 2018, 12:26:54 PM
Already rotated the tires and had the wheels rebalanced.... the vibration did not move.. same place... front drivers... good idea though!
Yea, that's my next step but I need to find the time. Luckily the SHO is not my DD so it's not pressing... just annoying.
Post by: 4sfed on August 30, 2018, 11:21:34 PM
Quote from: StealBlueSho on August 30, 2018, 09:33:23 PM
Oh!  I withdraw my wager...  :)
Post by: StealBlueSho on August 31, 2018, 12:59:46 PM
Quote from: 4sfed on August 30, 2018, 11:21:34 PM
Too late!! (Although not sure what the wager was!? A ???)
Post by: StealBlueSho on September 04, 2018, 03:25:33 PM
Soooo interesting... I had the HR springs installed today and took it for a bit of a test drive to make sure it tracked straight etc... The rythmic vibration is gone... I am confused? They did obviously re-align the car afterwards HOWEVER, it had just HAD an alignment so I am not sure what the deal is... but.. its gone... who knows.
Post by: SHOdded on September 04, 2018, 03:41:42 PM
sure, sure.  You won't admit to having removed the trunk monkey, will ya?
Post by: StealBlueSho on September 04, 2018, 04:31:58 PM
Quote from: SHOdded on September 04, 2018, 03:41:42 PM
https://www.youtube.com/watch?v=PsmLza7kcRg (https://www.youtube.com/watch?v=PsmLza7kcRg)
Post by: ToMang07 on September 04, 2018, 04:54:59 PM
Quote from: StealBlueSho on September 04, 2018, 03:25:33 PM
Good news!
Post by: jman on September 05, 2018, 04:22:48 PM
I suspect your issue is on the CV axle. Now that your car is lowered, the axle is now working on a different angle. It is possible that there is a minor imperfection in the CV joint.
I battled Nissan for 18 months with my Pathfinder for a similar vibration that only occurred at 110 km/hr (68 miles/hr). After multiple visits, they replaced the drive shaft which finally fixed the problem.
Post by: StealBlueSho on September 05, 2018, 05:00:42 PM
Quote from: jman on September 05, 2018, 04:22:48 PM
Good thought! They claimed to have checked them the first time I took it in.. but at this point I don't trust that dealer.
Post by: shoNoff on September 05, 2018, 09:48:30 PM
Have you ever tried slipping the car into neutral when the vibration is happening? That way you would be able to tell if it's engine related or speed related. If the vibration continues usually it's speed related meaning driveshaft, axle, wheel etc. if it subsides usually it's engine related meaning possible motor mount. Now this isn't always true but I've seen it true more often then not.
Post by: StealBlueSho on September 05, 2018, 09:49:43 PM
Quote from: shoNoff on September 05, 2018, 09:48:30 PM
Yup! I did this when I first noticed it. No change...
Post by: shoNoff on September 05, 2018, 09:58:39 PM
Quote from: StealBlueSho on September 05, 2018, 09:49:43 PM
I have a similar one in my car I've always suspected was the tires. I've had the dealer balance them twice under cpo. Mine is around 73ish though. I'm still chasing it.
Post by: ticoscen on December 21, 2021, 10:06:37 AM
carrier bearing on the propeller shaft is dry and causing vibration on the shaft.
