Ecoboost Performance => Performance => Topic started by: Cole.C on July 21, 2018, 07:57:54 AM
Title: New turbo option for the 3.5l ecoboosts?
Post by: Cole.C on July 21, 2018, 07:57:54 AM
Haven't seen this ad before wondering if anyone else has heard of agency power and their reputability? https://www.agency-power.com/shop/agency-power-stage-1-billet-wheel-cartridge-upgrade-twin-turbo-ford-3-5l-transverse-ecoboost/
Finally got both of my core turbos, I burnt a rear turbo seal which keeps pouring out smoke after heated up and after a good pull or 2.. been trying to make mind up over EPP's stock upgrade or whether I should just for for ATPs because they are only 600$ more or so pending on where are boughten.. Then I see this new companies claim that they perform just slightly less when compared to ATP at quite a lower price point. So now I'm really up in the air on what to go with..
Appreciate any inputs on what you'd recommend and why! Thanks.
Title: Re: New turbo option for the 3.5l ecoboosts?
Post by: Cole.C on July 21, 2018, 07:59:39 AM
... accidentally posted in wrong section sorry guys!.
Post by: ZSHO on July 21, 2018, 08:08:07 AM
Quote from: Cole.C on July 21, 2018, 07:59:39 AM
No worries.  Z  :)
Post by: SHOdded on July 21, 2018, 08:53:13 AM
Personally I would stick with tried and true.  ATP or EPP.  Without reliability data cannot recommend others.
Post by: ToMang07 on July 21, 2018, 09:51:50 AM
$1,600 for 2 compressor wheels sounds steep to me...
Post by: SHOdded on July 21, 2018, 10:28:45 AM
True, but you get what u pay for.
Post by: Cole.C on July 21, 2018, 10:40:11 AM
I emailed them to see if it indeed is only a compressor wheel upgrade or if they do any sort of machining to accommodate a larger wheel and if so what the sizes are and if they replace the chra's but I too agree it's a bit much for 2 small wheels although after googling a bit about agency power they seem to have only good reviews. Don't see much for their upgraded turbos though mainly exhaust parts. Hope to get more info from them otherwise it looks like it will back between ATP or EPP.
Post by: ToMang07 on July 21, 2018, 10:46:54 AM
Quote from: SHOdded on July 21, 2018, 10:28:45 AM
No argument, but I like to know what I'm buying. I hate the performance market because it's FLOODED with BS "performance" parts. I want to see data. I want specifics. I know it's not just me, lol
Post by: SHOdded on July 21, 2018, 10:51:20 AM
ATPs the data is out there.  Fewer have done CHRA type upgrades, and i dont think there is dyno data yet.  Seat of the pants reports are encouraging, possibly enough to require a tune update.
Post by: ZSHO on July 22, 2018, 07:50:26 AM
Here are some technical Specs on the Turbos which can be found below.  Z
Stock Turbine
-Wheel Inducer: 40mm
-Wheel Exducer: 34.5mm
Stock Compressor
-Wheel Inducer: 36.3mm
-Wheel Exducer: 49mm
Upgraded +2 Turbine
-Wheel Inducer: 50mm
-Wheel Exducer: 43.5mm
-Range: New Series Garrett GT Journal Bearing
Upgraded +2 Compressor
-Wheel Inducer: 43.4mm
-Wheel Exducer: 56mm
Twin turbo upgrade, direct bolt-on stock location. +2 size Garrett flows 200-250HP more than stock turbos. Remachined stock end housings. All new Garrett CHRA (Center Housing Rotating Assembly). Core exchange required.
https://www.atpturbo.com/mm5/merchant.mvc?Screen=PROD&Store_Code=tp&Product_Code=ATP-SHO-001&Category_Code=NEW (https://www.atpturbo.com/mm5/merchant.mvc?Screen=PROD&Store_Code=tp&Product_Code=ATP-SHO-001&Category_Code=NEW)
https://www.atpturbo.com/mm5/graphics/00000001/Catalog%20Images/Vehicle%20Specific/ATP-SHO-001_Coolant_Port_Diagram.jpg (https://www.atpturbo.com/mm5/graphics/00000001/Catalog%20Images/Vehicle%20Specific/ATP-SHO-001_Coolant_Port_Diagram.jpg)
(http://i66.tinypic.com/mv0v2p.jpg)
Post by: Macgyver on July 22, 2018, 10:44:38 PM
The Turbo Housing is still the same size ?
Post by: ZSHO on July 23, 2018, 07:10:40 AM
Quote from: Macgyver on July 22, 2018, 10:44:38 PM
That should be the same size which incorporates the existing studs AFAIK.  Z
Post by: irondoor19 on July 23, 2018, 02:34:22 PM
Install requires a Minor Mod to the front Turbo Oil Line
No Big Deal., They Spool Up Faster, Less Stress, That's for Sure.
Pricing HAS been about the SAME for a minute, and
After what happened to my Stock One's, it is the Way to go from my standpoint
Post by: EcoPowerParts on July 23, 2018, 05:25:38 PM
Quote from: Cole.C on July 21, 2018, 07:57:54 AM
Haven't seen this ad before wondering if anyone else has heard of agency power and their reputability? https://www.agency-power.com/shop/agency-power-stage-1-billet-wheel-cartridge-upgrade-twin-turbo-ford-3-5l-transverse-ecoboost/ (https://www.agency-power.com/shop/agency-power-stage-1-billet-wheel-cartridge-upgrade-twin-turbo-ford-3-5l-transverse-ecoboost/)
That's Vivid racing, google the address.
They're selling the same CHRA that I am, sourcing from the same guy most likely as we're all local.
Post by: Macgyver on July 23, 2018, 06:54:02 PM
Too bad you cant get slightly bigger housings for the upgraded turbos and get back some top end breathing room.
Post by: SHOdded on July 23, 2018, 07:00:37 PM
The limitation is the drivetrain, not the turbos, at this point, esp if you put in the ATPs.  You can blow the roof off the stock motor if you wanted with these things.
Post by: EcoPowerParts on July 23, 2018, 07:01:51 PM
Quote from: Macgyver on July 23, 2018, 06:54:02 PM
I think GHG is working on that, says he has turbos coming soon. :)
Post by: Cole.C on July 23, 2018, 07:22:21 PM
Quote from: EcoPowerParts on July 23, 2018, 07:01:51 PM
That's exciting!  Might have to wait on purchasing that ATP upgrade.
Would love to have a matching turbo/intercooler setup from GHG. love these forums. Wonder how long it will be until  more info is available on that upgrade 0_0!
Post by: Macgyver on July 23, 2018, 11:32:01 PM
Quote from: SHOdded on July 23, 2018, 07:00:37 PM
The weakness in my book is the top end. Now that my SHO is tuned. It is still slowish 80mph plus. She hauls butt from a DIG. Its the 80mph on that it just doesnt move because of the limited flow of the turbos. Tune it correctly and the motor and trans are safe but she will haul butt throughout the upper rev range.
Unless I am missing something.
Post by: SHOdded on July 24, 2018, 05:44:10 AM
Yes, you are definitely on the money about that.  Watching that needle climb can be agonizing the longer you are at WOT.  But my point was that you need HP and more of it.  A built block like Livernois makes comes to mind, but the transmission and AWD is still going to suck without an upgrade.  An electric assist might be handy here, like many exotics are putting in nowadays.  Or steal the setup that Ford races :D :D :D
http://www.torquestats.com/modified/index.php?pid=calculator&action=calculate_times&drive=4WD&bhp=700&weight=2000&submit=Calculate (http://www.torquestats.com/modified/index.php?pid=calculator&action=calculate_times&drive=4WD&bhp=700&weight=2000&submit=Calculate)
Based on a 23% drivetrain loss, not too far off from bpd's times.
Post by: Macgyver on July 24, 2018, 03:25:22 PM
My point is, hopefully you got it, is that slightly bigger housings with ATP like power can be tuned safely for the stress areas, trans, ptu, block, rods, etc, but let loose for the Upper power band rev range.
Post by: EcoPowerParts on July 24, 2018, 04:07:26 PM
IMHO the heads are the limitation, not the turbos. ATP is a stock housing with new CHRA and housings machined to accept the larger wheels. No inlet/outlet differences.
Post by: StealBlueSho on July 25, 2018, 07:29:45 AM
Gearhead is working on several things... upgraded FMIC, upgraded turbos, upgraded motor mounts... plus other things they haven't told us about... they are really digging into the SHO market. Matt Robinson's tunes ARE VERY GOOD, I ran them on the 2010 I had for a bit..
Only thing... they have been talking about these upgrades for awhile but nothing yet... Matt did PM me to say the IC upgrade was going to be available really soon.
Post by: Livernois Motorsports on July 25, 2018, 10:46:16 AM
The biggest thing is who your tuner is as well, certain companies will only stick with ATP, Like us we will only tune for atp turbos that have the matching setup we use because the stock engine can only take so much and we will not push it to the breaking point. Our tunes are known to be reliable and long lasting while still making great power so we only use the best parts out there that we know and have done major research on because we want our customers to leave with a huge smile on their face and no regrets even after ALOT of road use and track use!
Post by: EcoPowerParts on July 25, 2018, 09:38:28 PM
Just remember that before ATP LMS sold upgraded compressor wheel turbos :)
Post by: EcoPowerParts on July 26, 2018, 01:23:18 PM
FYI reached out to my supplier, that company is Vivid Racing and those are not the GTX billet wheels I use on my turbos and no turbosmart WGA on those turbos that I can see so much more expensive with less quality parts. :)
