Ecoboost Performance => Troubleshooting, Maintenance, TSB Articles => Troubleshooting => Topic started by: Gray Brick on April 13, 2018, 01:10:31 AM
Title: Help finding part number
Post by: Gray Brick on April 13, 2018, 01:10:31 AM
Might need to replace this part... anyone know what the part number or name is?
Title: Re: Help finding part number
Post by: bpd1151 on April 13, 2018, 01:30:28 AM
Not sure what model year you own, as the sigs never show on Tap-A-Talk.....
However, I believe what you're referencing is part of the vacuum line for the brake system.
Check the pic located within the link below.....
https://www.tascaparts.com/oem-parts/ford-vacuum-hose-dg1z9c490b/?c=Zz1icmFrZXMmcz1oeWRyYXVsaWMtc3lzdGVtJmk9S0QwOTI5MTUmcj0xMyZhPWZvcmQmbz10YXVydXMmeT0yMDEzJnQ9c2hvJmU9My01bC12Ni1nYXM%3D
LMK if I was close and/or right. I searched up a 2013 for 'ya.
Post by: Gray Brick on April 13, 2018, 02:08:05 AM
Do you know if the valve is available on its own?
I think mine is leaking boost.... isn't this a one way valve from the intake manifold back to the inlet of the front turbo?
Post by: bpd1151 on April 13, 2018, 03:34:30 AM
Doesn't appear to be a separate part.
But I could be wrong. SHOdded is usually pretty good with this kind of stuff.
Maybe he'll chime in
Post by: SHOdded on April 13, 2018, 11:26:20 AM
Still looking.  Dang the 2013+ manuals are stingy with words and part numbers!
Post by: Gray Brick on April 13, 2018, 02:17:47 PM
Any idea on how this valve works?
Is it just a one way valve?
I am concerned that I am losing boost through it.
When I pressurize the intake to look for boost leaks it is going trough the valve back into the inlet of the front turbo.
