Ecoboost Performance => General Discussion => Topic started by: jbrown9999 on February 15, 2018, 06:04:30 PM
Title: 3rd Cat removal
Post by: jbrown9999 on February 15, 2018, 06:04:30 PM
I've seen a lot of people have removed this and have been told that I would still pass emissions with that taken out.  The question I have is, if I'll still pass emissions without it, why is it needed?  Is this just a CA thing just to get exhaust "extra" clean?
I'm really leaning towards PPE with cats and doing a custom 2.5" dual exhaust based somewhat on the M-Design custom exhaust using Magnaflows.
My concern is getting a shop to do the install because it requires removing the 3rd Cat.
Title: Re: 3rd Cat removal
Post by: AJP turbo on February 15, 2018, 06:08:17 PM
Passing the emissions and I/M monitors has nothing to do with it....It's always Federally illegal to remove any emissions control device....The car got the EPA certifications with everything you see intact so if you tamper with it then technically it should fail any state inspectors inspection because the emissions control device has been removed.
It should fail the visual.
Post by: ZSHO on February 21, 2018, 04:30:30 PM
X2 on ^^^  It's under CA Greenhouse Emissions regulations! Sorry for the late reply.
PDF -Below. Z
https://www.arb.ca.gov/msprog/onroad/cert/pcldtmdv/2013/ford_pc_a0101697r1_3d5_u2.pdf (https://www.arb.ca.gov/msprog/onroad/cert/pcldtmdv/2013/ford_pc_a0101697r1_3d5_u2.pdf)
(https://i.imgur.com/j8hkdNkh.png)
Post by: bamsho on February 21, 2018, 05:56:31 PM
Well some of the aftermarket exhaust systems don't have third cat.  Mine is off, but I still have it.
Post by: jbrown9999 on February 23, 2018, 09:35:42 PM
Magnaflow removes it, I think.  Can anyone confirm that?
Post by: SHOdded on February 23, 2018, 09:42:39 PM
Corsa maybe?  They have a builtin xpipe?
Post by: hawkeye93 on February 24, 2018, 09:54:02 AM
Quote from: jbrown9999 on February 23, 2018, 09:35:42 PM
The Magnaflow catback mounts behind the third cat.  It requires cutting the stock exhaust 4.75" behind the cat.
https://www.magnaflow.com/installsheets/15769.pdf (https://www.magnaflow.com/installsheets/15769.pdf)
That said, lots of people remove their third cat.  Whether or not it's illegal was not the OP's question; he wanted to know if he would pass an emissions test.  Lots of things are illegal, like speeding, yet I do it every day.  And CA regulations only apply in Californistan.
Post by: ZSHO on February 25, 2018, 03:58:57 PM
OBD CA. (ULEV) Ultra low emissions vehicle P.car!
The vehicle will pass emissions testing and best of luck. Z
https://www.arb.ca.gov/msprog/zevprog/factsheets/calemissions.pdf (https://www.arb.ca.gov/msprog/zevprog/factsheets/calemissions.pdf)
https://www.arb.ca.gov/msprog/levprog/cleandoc/cleancomplete_lev-ghg_regs_3-12.pdf (https://www.arb.ca.gov/msprog/levprog/cleandoc/cleancomplete_lev-ghg_regs_3-12.pdf)
(https://i.imgur.com/jsidd5Ch.jpg?1)
Post by: ChrisJ on March 23, 2018, 06:59:09 AM
Does anyone make test pipes by chance?
Post by: derfdog15 on March 23, 2018, 01:31:14 PM
Quote from: ChrisJ on March 23, 2018, 06:59:09 AM
I haven't seen anything. All you would need to do is use an X pipe as your replacement for non test purposes, and add some flanges to the X pipe and your stock 3rd cat, or just use slip connectors. It's in a pretty easy spot to get at, so you could swap it pretty quick in a driveway.
