Ecoboost Performance => Ecoboost Tuning! => Tuning and Devices => Topic started by: jbeez on November 22, 2017, 09:45:59 AM
Title: Quick knock reading question
Post by: jbeez on November 22, 2017, 09:45:59 AM
So if my sct x4 says min -3.5 and max +1.5 for knock, does that mean it pulled 3.5 degrees of timing, or added 3.5? Or something else?
Title: Re: Quick knock reading question
Post by: FoMoCoSHO on November 22, 2017, 11:48:19 AM
negative is adding, positive is subtracting...
Post by: AJP turbo on November 22, 2017, 12:50:12 PM
Yes, Fomo is correct. So with the knock settings and logic on the SHO positive values are pulling spark.
But remember those stored min and max values can happen anywhere during that drive cycle or log session. It's not uncommon to have high KR during times of transients or throttle tip ins and tip outs which usually isn't reason to be overly concerned....ALso if you get a glitch in the datastream it will be stored on those min and max values.
If you are suspecting a problem or chasing a problem then I would look to see what values are popping up DURING the pull.
A lot of people will ask me about KR and tell me they are from the displayed min/max values on the X4 and it was from a 45 minute driving session...So the values could've happened anywhere and not necessarily during a pull
Post by: jbeez on November 22, 2017, 01:25:06 PM
Totally not concerned, those don't seem like outrageous numbers? Should I be concerned? LOL
I was just curious how to read that value, in case I did want to see what was going on.
Thanks!
Post by: AJP turbo on November 22, 2017, 02:01:41 PM
Quote from: jbeez on November 22, 2017, 01:25:06 PM
Thanks!
I would say NO....How long were you driving to capture that data?
Post by: jbeez on November 22, 2017, 02:09:29 PM
maybe 30 minutes?  It was just on the display, but I was just curious how to read it so I knew in the future :)
