Ecoboost Performance => General Discussion => Topic started by: Colorado-SHOBro on April 21, 2017, 11:29:10 AM
Title: transmission oil cooler hose pressure
Post by: Colorado-SHOBro on April 21, 2017, 11:29:10 AM
quick question for reference as i'm shopping for hose for install. local parts store has gates tranny cooler hose rates to 400psi. guessing that should be plenty?
Title: Re: transmission oil cooler hose pressure
Post by: AJP turbo on April 21, 2017, 11:36:31 AM
Get fuel rated hose also because of the fluid
Post by: Colorado-SHOBro on April 21, 2017, 11:50:36 AM
Quote from: AJP turbo on April 21, 2017, 11:36:31 AM
here's the specs on what's available locally.
http://designconnect.gates.com/catalog3/d/gates.fp/?c=products&cid=gthc6h_high_temp_1_fiber_braid_hose_sae_100r6&id=8GTH
why fuel rated hose? obviously heater hose and vacuum hose is a no go but i would think transmission oil cooler line should meet all the specs unless there's something specific to our trans system that would render it not compatible.
Post by: AJP turbo on April 21, 2017, 11:58:13 AM
Oh yeah you are good..i didnt see what hose you were looking at
Post by: Colorado-SHOBro on April 21, 2017, 07:04:01 PM
so got the hose and got it installed this afternoon. wasn't quite bolt up like others have been though. the existing bracket on the passenger side didn't quite line up. the brackets on my cooler were facing up toward the bumper support so i drilled a hole and mounted it that way. don't know if it was a different trans cooler or my car is a bit of an anomaly. cooler was from a junkyard pulled from a 14 pi.
(https://uploads.tapatalk-cdn.com/20170421/2088d55e2d8e7a8567ac1523946ff6fb.jpg)
(https://uploads.tapatalk-cdn.com/20170421/9bfce107c3e3f7a4e83ea010d252590e.jpg)
(https://uploads.tapatalk-cdn.com/20170421/befcb267bf454ffd9a8eb7b2ac2205ca.jpg)
