Ecoboost Performance => Troubleshooting, Maintenance, TSB Articles => Troubleshooting => Topic started by: pmezo33 on February 04, 2017, 09:02:39 PM
Title: Inner tie rod socket size?
Post by: pmezo33 on February 04, 2017, 09:02:39 PM
Anyone know the correct socket size to remove the inner tie rod on a 2010 mks?  The set i rented from advanced auto came with three socket sizes and, of course, none of them fit.  All are too small.
Anyone know?
Title: Re: Inner tie rod socket size?
Post by: SHOdded on February 05, 2017, 12:32:15 AM
The helpful manual only states "appropriate size".  Do you have a new part for reference?
Post by: pmezo33 on February 05, 2017, 12:58:14 AM
Quote from: SHOdded on February 05, 2017, 12:32:15 AM
Trust me.. already checked it over.  So frustrating because I already removed everything including the outer tie rod end,  so my alignment is out of whack, just to find out I can't even remove the inner one because I don't have the correct socket. My fault for not checking first, but that's what I get for trusting a universal kit.
Not sure about the part number that's currently on the car, but I'd assume it's the same as the oem part I'm putting on to replace it.
https://www.rockauto.com/en/moreinfo.php?pk=4021980&cc=1444584&jnid=384&jpid=6 (https://www.rockauto.com/en/moreinfo.php?pk=4021980&cc=1444584&jnid=384&jpid=6)
Post by: pmezo33 on February 05, 2017, 09:43:02 AM
Anyone?  No one's had to do this before?
Post by: ZSHO on February 05, 2017, 09:51:53 AM
What sizes did you try for the jam-nut? There's an 8 piece kit that Harbor freight sells for 39.99.and maybe worth a try.IDK. Z
http://www.harborfreight.com/inner-tie-rod-removal-set-69619.html (http://www.harborfreight.com/inner-tie-rod-removal-set-69619.html)
http://manuals.harborfreight.com/manuals/69000-69999/69619.pdf (http://manuals.harborfreight.com/manuals/69000-69999/69619.pdf)
Post by: pmezo33 on February 05, 2017, 10:19:59 AM
Tie rod sizes that came with this kit were 1-5/16", 1-3/16" and 1-7/16".
I saw that kit from harbor freight, but wanted to make sure it worked before i went out and bought it.  The closest HF is like 30 minutes from here.  And i thought I read somewhere that this kit didn't have the correct size for their Lincoln too when i was searching around last night.  It wasn't on here though.
Post by: ZSHO on February 05, 2017, 10:25:21 AM
Quote from: pmezo33 on February 05, 2017, 10:19:59 AM
Did try Autozone? It could me a 18mm!!.just trying to help you out & best of luck. Z
Post by: pmezo33 on February 05, 2017, 10:32:59 AM
Quote from: ZSHO on February 05, 2017, 10:25:21 AM
Did try Autozone? It could me a 18mm!!.  Z
I did.  Their set only has two pieces and both sizes came with the set you get from autozone.
Post by: ZSHO on February 05, 2017, 11:43:43 AM
Dam! It sux!! If you turn rack all the way out to side that's coming off can you grab it with large adjustable.? Or large pliers ? Pipe wrench?
It is recommend to hold the rack so when loosening you don't force it against other gear inside. LMK thanks .Z
Post by: pmezo33 on February 05, 2017, 11:52:27 AM
I was thinking about just using a big pipe wrench.  I really prefer not to because of the steering rack and possibly putting extra stress on it when removing.  Also wanted to torque it down to the correct spec when putting the new piece in.  I guess it's just kind of my only option at this point.
Post by: ZSHO on February 05, 2017, 11:56:37 AM
Quote from: pmezo33 on February 05, 2017, 11:52:27 AM
Exactly that's why I recommended  the above mentioned procedure knowing that you're options are very limited at the moment.
Also when removing an inner tie rod you need to hold the rack so it does not bind when removing and tightening and outer tire rod.
Best of luck and keep us updated on any progress. Z
Post by: ZSHO on February 06, 2017, 11:54:24 AM
Here is a pic of mine and would say its probably the same size.  Z
(http://i.imgur.com/N9oOieUh.jpg)
Post by: pmezo33 on February 06, 2017, 12:29:28 PM
Quote from: ZSHO on February 06, 2017, 11:54:24 AM
Inner tie rod is under that plastic boot on left side of that picture.  I had it all apart and ready to be removed, but had nothing to remove the thing with.
That picture looks just like my setup and i'm sure it's the same size.  Problem is, no clue what size socket to put on it.
Post by: pmezo33 on February 06, 2017, 12:45:43 PM
Ok 99% sure just figured it out.  It's the 1-1/2 tie rod socket.  At least the new part is.   Got to assume the current part that's on the car is too since i'm replacing with OEM.
That size socket wasn't included in the set i rented from advanced auto and it's not included in the set from harbor freight either.  Looks like Lisle sells a master tie rod tool set that included the 1-1/2 socket size.  I'll probably just pick that up.
https://www.summitracing.com/parts/lil-46800 (https://www.summitracing.com/parts/lil-46800)
Post by: ZSHO on February 06, 2017, 02:26:03 PM
I was able to finally measure it for ya.
It measure's approximately 38.5mm.  Z
I hope it helps any of our prestige members out. :)
(https://i.imgur.com/GaB4ucgh.jpg)
Post by: pmezo33 on February 06, 2017, 02:47:33 PM
Quote from: ZSHO on February 06, 2017, 02:26:03 PM
Thanks for confirming that.  Appreciate it.
I hope you didn't pull that tie rod just for this thread though.
Post by: ZSHO on February 06, 2017, 03:01:28 PM
Quote from: pmezo33 on February 06, 2017, 02:47:33 PM
No worries actually was curious myself but IMHO its my pleasure to help out the ecoboost community in any way i can.
I'm hoping the tool you ordered is deep enough to go over the end of the tie rod and hope everything goes smooth without a hitch.  Z
Post by: pmezo33 on February 06, 2017, 03:08:38 PM
Quote from: ZSHO on February 06, 2017, 03:01:28 PM
That's some dedication right there, and i definitely do appreciate it, but your car is going to need an alignment now if that was pulled from your car.  I didn't want to put you through all that trouble.  I hope that was just a spare part you got a hold of.
If it was from your car... out of curiousity, what did you use to pull yours?
And I haven't ordered the tool yet.  Probably will a little later today.  They're all deep enough to get over the tie rod, even the smaller sizes, it's just getting them correctly on the thread.  I think I should be good with that master set.  Really would have preferred to rent the tools, but it is what it is.
Post by: ZSHO on February 06, 2017, 03:16:24 PM
Quote from: pmezo33 on February 06, 2017, 03:08:38 PM
I pulled it from the shelf,LOL.  Z
Post by: SHOdded on February 06, 2017, 03:54:02 PM
Quote from: ZSHO on February 06, 2017, 03:16:24 PM
Right, right, AFTER you pulled it from the car :P LOL  There's a ripple in the time-space continuum somewhere in NY ...
Post by: ZSHO on February 06, 2017, 04:47:11 PM
Quote from: SHOdded on February 06, 2017, 03:54:02 PM
Oh to funny,was busy trying to get the grease off my hands.LOL. Z
Post by: pmezo33 on February 06, 2017, 06:02:28 PM
Ok, good.  You had me feeling bad here for a minute.  Appreciate you looking and getting me a measurement though.
Post by: glock-coma on September 06, 2017, 08:29:07 PM
Quote from: pmezo33 on February 06, 2017, 06:02:28 PM
Did you ever find out the correct size socket? Probably doing both inner and outer in the next week or so.
Post by: ZSHO on September 06, 2017, 09:21:49 PM
I can try to find out tomorrow.  Z
! No longer available (http://www.youtube.com/watch?v=rif0UpVa-Gg#) .
Post by: pmezo33 on September 06, 2017, 11:16:33 PM
Quote from: glock-coma on September 06, 2017, 08:29:07 PM
1-1/2 inch sized adapter worked.  I used this set.  None of the part stores rented a tool with an adapter in that size, so i just bought one.
http://www.lislecorp.com/divisions/products/?product=566 (http://www.lislecorp.com/divisions/products/?product=566)
Looking back, an adjustable wrench would have been a cheaper option.  Would have worked fine as long as it opened to at least 1-1/2 inches.
Post by: ZSHO on September 07, 2017, 06:46:12 AM
I quess all the quote on quotes missed my own answer. lol. Z
BTW Funny Topic though.  :)
38.5 mm = 1.5 inchs
