Ecoboost Performance => Troubleshooting, Maintenance, TSB Articles => PCV/Catch Cans => Topic started by: metroplex on November 27, 2016, 03:41:33 PM
Title: 2016 SHO - differences in PCV system
Post by: metroplex on November 27, 2016, 03:41:33 PM
I was at the dragstrip today and saw another racer with a SHO. His was a 100% stock 2016 SHO, and said he was running 13.5 stock. I've seen stock SHO's run high 13s/low 14s stock at the same track. We chatted and I took a gander at his engine. I noticed there were some differences in the 2016 that I did not see in the 2015 or my 2014. It had composite cam covers instead of aluminum/magnesium, did not have the PCV vapor separator, and used some kind of solenoid for the crankcase fresh air vent tube.
My guess is that the solenoid shuts off that vent tube so the PCV doesn't suck in oil vapors, or at least restricts that tube flow a bit. I wonder how that is controlled by the ECU, probably by the amount of manifold vacuum is present?
Title: Re: 2016 SHO - differences in PCV system
Post by: BlueSHO on November 27, 2016, 04:03:09 PM
Interesting. I'll have to check mine as I have the composite cam covers but will have to look at the pcv setup.
Post by: metroplex on November 27, 2016, 04:47:18 PM
Here's mine, with the alloy cam covers and the vapor separator on the PCV system. The tube that runs in the front of the engine is just a straight tube. Traditionally, the tube that goes from the cam cover/crank cover to the air intake tract is a fresh air tube (allows air to flow into the crankcase) while the tube that goes from the cam cover to the throttle body/intake manifold is the PCV line which allows for vapors to flow from the engine back into the intake stream.
Post by: BlueSHO on November 27, 2016, 05:00:43 PM
The wife has the SHO now or I would look. Here's cropped pictures of the 16 you showed and yours. Your saying there is a solenoid on the fresh air tube?(http://uploads.tapatalk-cdn.com/20161127/a6ea93d629879a658093aabe2eebd9f0.jpg)(http://uploads.tapatalk-cdn.com/20161127/29ef037d8eff56961ae0d0e6a697c827.jpg)
Post by: metroplex on November 27, 2016, 05:28:29 PM
The vapor separator (the black box sitting on my alloy cam cover) is not on the 2016. From what I recall looking at someone else's 2015 SHO earlier this year at the track, he had the alloy covers and the vapor separator.
Look at my 2nd attached pic in the first post, and trace the air tube from the cam cover to the right side of the pic. See the wiring harness with yellow wires? That is what I presume to be a solenoid or some type of valve that is electronically controlled. I'd imagine it is to restrict/block airflow for the crankcase so that the PCV system doesn't allow vapors to be ingested into the intake manifold/combustion chambers to reduce carbon buildup on the intake valves. I don't know how this affects piston ring sealing.
Post by: SHOdded on November 27, 2016, 06:03:17 PM
So that would mean the SHO AND the XSport have that solenoid on the fresh air tube.
Post by: ZSHO on November 27, 2016, 06:17:19 PM
Its an EGR pressure feedback sensor on the my2016 and more info can be found on  Page 120 and up. Z    http://www.fordservicecontent.com/ford_content/catalog/motorcraft/OBDSM1505.pdf (http://www.fordservicecontent.com/ford_content/catalog/motorcraft/OBDSM1505.pdf)    (http://i.imgur.com/rISqzI5h.jpg)(http://i.imgur.com/FugVFpwh.jpg)
Post by: metroplex on November 27, 2016, 06:32:15 PM
We don't have EGR systems anymore, and I know that sensor on my old Crown Vic's 4.6, I don't believe this is the same thing. Also, the cam covers you posted show 2 spool valves for the Ti-VCT. Does that mean the F-150s went to the composite covers? I didn't know if the transverse EB 3.5's went to Ti-VCT, my 2014 is still VCT for intake only.
Post by: SHOdded on November 27, 2016, 06:33:57 PM
Maybe the Crankcase Pressure Sensor (clean side) on pg 133
http://www.fordservicecontent.com/ford_content/catalog/motorcraft/OBDSM1604.pdf (http://www.fordservicecontent.com/ford_content/catalog/motorcraft/OBDSM1604.pdf)
QuotePCV System Monitor – Turbocharged Engine with MAP Sensor
The fresh air hose connects the Air Induction System (AIS) to the rocker cover to provide fresh, filtered clean air
into the crankcase as the crankcase vapors are evacuated. The PCV valve has a spring loaded, tapered pintle and
orifice that limits the amount of crankcase vapors that are inducted into the engine. The least amount of flow occurs
during  idle  when  manifold  vacuum  is  high.  As  engine  load  increases,  manifold  vacuum  decreases  which  al
low more flow. Under boosted conditions, there is no flow through the PCV valve. As crankcase pressure increases,
blow  by  vapors  get  pushed  through  the  fresh  air  tube  into  the  Air  Induction  System  (AIS)  where  they  will  be
Starting in the 2015 MY, Ford will be using a Crankcase Pressure Sensor (CKCP) to detect a disconnection of the
fresh  air  hose.  A  disconnection  of  the  fresh  air  hose  would  allow  the  discharge  of  crankcase  vapor  into  the
atmosphere while the engine was under boost. The diagram below shows a schematic of the PCV system. The
CKCP sensor is installed in the fresh air hose. The fresh air hose has two connection points. The connection at the
AIS system is called the "Clean side" connection while the connection at the rocker cover/engine is called the "dirty
side" connection.
Post by: SHOdded on November 27, 2016, 06:38:21 PM
All 2010+ SHOs are VCT engines, not Ti-VCT.  The 3.5/3.7 (?) NA engines in the (2012+ at least) Taurus are Ti-VCT.
Post by: BlueSHO on November 27, 2016, 06:42:56 PM
Here's what's on my early build (#141) 16 SHO..(http://uploads.tapatalk-cdn.com/20161127/3dc007fb77891cfc34da09f6b4f13bb5.jpg)(http://uploads.tapatalk-cdn.com/20161127/5c5118511b2c28d0ace2d76487a2aca2.jpg)(http://uploads.tapatalk-cdn.com/20161127/af8cb98cd71884751b179577a72db853.jpg)(http://uploads.tapatalk-cdn.com/20161127/2c756b0d14edf205a10f796495bb9a5a.jpg)
Post by: ZSHO on November 27, 2016, 07:07:25 PM
The 10+SHO has a VCT and more info can be had on page 3 including the PCV system.  Z       https://drive.google.com/file/d/0B8JUL90DXgdiMTZ3a0wyU0JCYkZJN1ZTT3VEd3Fic09JNTlv/view
Post by: metroplex on November 27, 2016, 07:17:37 PM
Did they remove the vapor separator for any specific reason?
Also, why the change to composite covers? Weight savings?
Post by: ZSHO on November 27, 2016, 07:39:54 PM
Quote from: metroplex on November 27, 2016, 07:17:37 PM
I can attest that the  composite covers are actually heavier than the aluminum. Z
Post by: BlueSHO on November 27, 2016, 07:47:43 PM
Is that solenoid or sensor I took a picture of not on the 15 and older SHO's?
I've got 10k miles on mine which I know isn't a lot but when I changed out my noisemaker I checked the CAC, throttebody and inlet tube and saw zero oil no film residue or anything..
Post by: SHOdded on November 27, 2016, 07:53:12 PM
Will have to check the OBD manuals, but it seems this was introduced in the 2015MY.  Now, it could be actually implemented before the first official 2015MY rolled off the line, that is hard to confirm.
Post by: BlueSHO on November 27, 2016, 08:04:59 PM
Like I said my 16 is early #141. We need to analyze that solenoid/sensor to see what it looks like inside. I'd pull mine apart but I don't want to damage it
Post by: JimC1 on November 27, 2016, 09:30:53 PM
Nice meeting you today Metroplex. Today is the second time I have had the SHO at the track since getting it last month. Couldn't get it better than 14.1 the first time - but getting used to the car and AWD now (still miss doing the smokey burnout and smell of burnt rubber from my Mustang!).
Much better 60's today and 13.54 was the best. It was running 13.5 to 13.6 all day.
Now to get it tuned for next year.
Post by: SHOdded on November 27, 2016, 09:41:55 PM
Quick progress, Jim!  And please do make an intro thread for yourself here:
http://www.ecoboostperformanceforum.com/index.php/board,14.0.html (http://www.ecoboostperformanceforum.com/index.php/board,14.0.html)
Post by: metroplex on November 27, 2016, 09:47:30 PM
Hi Jim! Glad to see you made it to the forums. You definitely have a sharp ride! Just out of curiosity, what was your best trap speed for the day?
Post by: derfdog15 on November 27, 2016, 09:56:38 PM
I have a 15, that was build date 12/1/15 so I will check mine and see which set up it has.
What track do you guys run at? Best I got was 14.1 stock, but could have probably gotten 13.99 if I had traction control all the way off and pulled the extra stuff out of my trunk.
13.5 stock is pretty stout.
Post by: BlueSHO on November 27, 2016, 10:02:29 PM
Quote from: derfdog15 on November 27, 2016, 09:56:38 PM
Curious what's the last 6 digits of your vin?
Post by: derfdog15 on November 27, 2016, 10:06:26 PM
Quote from: BlueSHO on November 27, 2016, 10:02:29 PM
PM'd ya.
Post by: JimC1 on November 27, 2016, 10:19:27 PM
Quote from: metroplex on November 27, 2016, 09:47:30 PM
Best trap was 103.73 mph
Post by: derfdog15 on November 29, 2016, 12:46:51 PM
Here is my '15. Seems like my car may be a hybrid of the pre '16 system and the '16 system. I have the composite covers, and a direct connection on the rear valve cover. However, there is no sensor/wiring in the front location.
Pics attached.
Post by: SHOdded on November 29, 2016, 12:53:59 PM
Build date, derfdog?
EDIT"  N/M 12/1/15, not so early in the cycle ...
Post by: derfdog15 on November 29, 2016, 01:02:57 PM
Quote from: SHOdded on November 29, 2016, 12:53:59 PM
That is correct, a few days later and it would have been built with the first run of 16s.
Still seems odd that is has some of the changes but not all of them.
Post by: SHOdded on November 29, 2016, 01:05:15 PM
It is.  Because this new tube incorporates a sensor, one would think it was not a random parts bin snatch, but there is a batch of cars whose as-built is like this.  Maybe AJP can look into the as-built to see if there is an on/off switch for this sensor, which would make the decision on the floor that much easier.
Post by: derfdog15 on November 29, 2016, 01:30:58 PM
Quote from: SHOdded on November 29, 2016, 01:05:15 PM
Ill point him towards this thread and see if he can shed any light!
Post by: BlueSHO on November 29, 2016, 02:11:14 PM
Quote from: derfdog15 on November 29, 2016, 01:02:57 PM
Yep my 16 was built a few days after your 15. It is odd you have some things on your engine that aren't on other 15's but they didn't put everything the 16's have. You don't have sync 3 like the 16's do you? Now that would be awesome
Post by: derfdog15 on November 29, 2016, 02:29:30 PM
Quote from: BlueSHO on November 29, 2016, 02:11:14 PM
Unfortunately not, SYNC2 V3.8
