Ecoboost Performance => Ecoboost Tuning! => Tuning and Devices => Topic started by: shweetpickens on September 16, 2016, 11:57:35 PM
Title: Resetting pcm after tune?
Post by: shweetpickens on September 16, 2016, 11:57:35 PM
I heard on another board that i should do a kam reset and transmission relearn after a tune and that it would make a noteworthy improvement.  I was also told i need an app called forscan and a high quality mx bluetooth adapter for this because a battery unplug wont cut it.  Anyone heard of this?
I've search for an over an hour so far and can't find much info on:
FORScan
Kam reset
Transmission relearn
Ive already got torque and a cheap bluetooth adapter
Title: Re: Resetting pcm after tune?
Post by: ZSHO on September 17, 2016, 08:16:50 AM
There are a couple of members which have had good results simply by just by flashing the tune prior....it sounds like you want to take her to the track correct? if so you will need to flash the tune a couple of days prior and drive it like you stole it theory relearn procedure.  Z    BTW use at your own risk may apply here.
Post by: shweetpickens on September 17, 2016, 10:02:12 AM
Quote from: ZSHO on September 17, 2016, 08:16:50 AM
Thanks for the reply.  No not doing any track work, just want the most from my tune.  I thought i was missing out on some more performance by not doing this.  If not then its no biggie.  Im about to replace the plugs and install the 3 bar map.  After i hope to learn and do a datalog for the first time to get some more performance outta the sho.
Post by: ZSHO on September 17, 2016, 10:53:00 AM
I would just follow the Battery relearn feature for optimum feel and performance and then load your new tune.  Z       Battery relearn
Because your vehicle's engine is electronically controlled by a computer,
some control conditions are maintained by power from the battery. When
the battery is disconnected or a new battery is installed, the engine must
relearn its idle and fuel trim strategy for optimum driveability and
performance. To begin this process:
1. With the vehicle at a complete stop, set the parking brake.
2. Put the gearshift lever in P (Park), turn off all accessories and start
the engine.
3. Run the engine until it reaches normal operating temperature.
4. Allow the engine to idle for at least one minute.
5. Turn the A/C on and allow the engine to idle for at least one minute.
6. Drive the vehicle to complete the relearning process.
• The vehicle may need to be driven to relearn the idle and fuel trim
strategy.
• Note: If you do not allow the engine to relearn its idle trim, the idle
quality of your vehicle may be adversely affected until the idle trim is
eventually relearned.
When the battery is disconnected or a new battery installed, the
transmission must relearn its adaptive strategy. As a result of this, the
transmission may shift firmly. This operation is considered normal and
will not affect function or durability of the transmission. Over time the
adaptive learning process will fully update transmission operation to its
optimum shift feel
Post by: AnotherGreenFusion on September 17, 2016, 10:55:12 AM
I have been shocked how much a KAM reset and trans relearn has affected the car. I have flashed tuned many many times over the last 6 months and still had some odd issues and sluggish shifts. I finally did a KAM reset about 3 weeks ago and that was ok, it helped some esp with how quickly a tune adjusted to my driving however I still had odd, sluggish shifts in spots. Did a KAM reset and trans learn last sunday and its like a new car.
I don't think you need to do it with every flash but with significant mods or if you are seeing some odd transmissions issues I highly suggest it. SCT can do a KAM reset, Cobb can do both, Forscan with the correct connector can do both. I am not sure what the battery reset does exactly, likely KAM, maybe both? The menu option or Forscan is much quicker.
If you are hitting the track make sure you have a week or so before you go it will take at least a couple hundred miles before your OAR returns to normal after the KAM reset. You will be running richer than usual for a little while too.
For a lot of troubleshooting transmission issues, issuing a re-learn is step 1.
Post by: FoMoCoSHO on September 17, 2016, 12:45:53 PM
So do you do it before or after the flash?
Post by: AnotherGreenFusion on September 17, 2016, 12:52:18 PM
I did mine after, likely the best way from a learning perspective. You should only need to do it after major changes (stock to custom tune, or major mod) or if you want to reset things for some reason. A simple datalog based revision if you already reset last revision should not really need it.
Post by: SHOdded on September 17, 2016, 12:58:35 PM
Enjoy 4 videos from FTM
https://www.youtube.com/user/FordTechMakuloco/search?query=kam+reset (https://www.youtube.com/user/FordTechMakuloco/search?query=kam+reset)
Post by: shweetpickens on September 17, 2016, 07:10:00 PM
Quote from: SHOdded on September 17, 2016, 12:58:35 PM
Nice.this is exactly what I was looking for without buying more stuff .  I'm such a cheapskate lol
Post by: Ramairetransam on November 09, 2016, 11:09:24 AM
what is a kam reset ?
Post by: glock-coma on November 09, 2016, 11:38:51 AM
Quote from: Ramairetransam on November 09, 2016, 11:09:24 AM
Keep alive memory (KAM)
Resets all the adaptive parameters  in the car
Stuff that normally gets saved when the battery is removed.
https://m.youtube.com/watch?v=hZAsoqmqhdM
Post by: StealBlueSho on November 09, 2016, 12:04:13 PM
So I was under the impression that when you flash your ECU it clears out the KAM during the flash... This is why your fuel trims, OAR, and adaptives get reset after a flash. That's why after a flash your transmission shifts harder because everything gets reset...
Think about the reverse if your KAM didn't get reset then you flash... Then your fuel trims could potentially be VERY off causing all kinds of issues... Your OAR could be off causing too much spark advance which leads to knocking... Your transmission wouldn't have baseline starting point to adjust the adaptives...
Guessing at this, but based on my logging, after a flash, most learned values get reset..
Post by: derfdog15 on November 09, 2016, 12:16:43 PM
Quote from: StealBlueSho on November 09, 2016, 12:04:13 PM
Most adaptive parameters do get reset after a flash, however, items like OAR do not reset due to a flash. While not necessary a major concern, this could be an issue if you go from an E blend tune to a straight 93 octane tune, just before changing fuels, or something similar.
My Recommendation is to do a KAM reset upon major modifications, like stated, or upon fuel type changes, especially if going to worse fuel. It takes only a few seconds to do one with an SCT (if that is how you're tuned) and doesn't take super long for the car to relearn. Better safe than sorry IMO
Post by: StealBlueSho on November 09, 2016, 12:24:17 PM
Quote from: derfdog15 on November 09, 2016, 12:16:43 PM
You OAR DOES get reset after a flash. That is a fact...
Post by: derfdog15 on November 09, 2016, 12:36:40 PM
Quote from: StealBlueSho on November 09, 2016, 12:24:17 PM
Maybe my SCT X4 is just buggy then...
I have never seen OAR change after a flash, either from stock or from custom tune to custom tune. However, when I did a manual KAM reset, it went to 0, and learned again.
Post by: StealBlueSho on November 09, 2016, 12:40:38 PM
Quote from: derfdog15 on November 09, 2016, 12:36:40 PM
Hmm I wonder then if it's strategy specific then? My OAR always got reset to 0 after I flashed.. and that was with Unleashed, AJPTurbo, And LMS tunes.. and all three mentioned to let my OAR even out before logging..
Post by: FoMoCoSHO on November 09, 2016, 12:45:41 PM
My OAR does not change when I flash unless I go back to stock because my tuned setting for OAR is different.
Post by: AJP turbo on November 09, 2016, 12:46:42 PM
My OAR never reset on my car, but ive noticed logs from people where it is resetting...cant explain
Post by: glock-coma on November 09, 2016, 01:01:51 PM
Yep, mine resets after every reflash.
Post by: SHOdded on November 09, 2016, 01:28:07 PM
Ok so maybe a diff with the 2013+?
Post by: derfdog15 on November 09, 2016, 01:35:12 PM
Quote from: SHOdded on November 09, 2016, 01:28:07 PM
That is a reasonable possibility, but it is definitely an odd difference. I wonder why that is?
Post by: StealBlueSho on November 09, 2016, 01:36:12 PM
I'm jealous if it doesn't!! I always have to drive around and get my OAR to level out before I can data log...otherwise I don't get full spark..
Post by: SHOdded on November 09, 2016, 01:42:31 PM
No clue why it does not reset, could be a Ford or an SCT issue.
Post by: ZSHO on November 09, 2016, 01:58:39 PM
The encoding programming is different on the 13+SHO. Z
Post by: ecoboostsho on November 10, 2016, 06:53:51 AM
It always reset on my 11...never on my 13 after a flash. Most likely due to the PCM being different
Sent from my XT1096 using Tapatalk
Post by: SHOdded on November 10, 2016, 08:06:18 AM
There ya go
