Can anyone provide some insight to where the exact location is of the blower motor resistor?
Please do not link me to a video from a different vehicle.
Here's a video from a Chrysler 200 ... OOPS, sorry :D
(http://i1315.photobucket.com/albums/t597/PerfA_ZN0W/2010-up/How%20To/2012%20Taurus%20Blower%20Motor%20Speed%20Control_zpsygwqtqq3.jpg)
Item Part Number Description
1 W707628 RH lower instrument panel insulator front screw (2 required)
2 707281 RH lower instrument panel insulator rear screw
3 54046A24 RH lower instrument panel insulator
4 — Blower motor speed control/resistor electrical connector (part of 14401)
5 W701696 Blower motor speed control/resistor screw (2 required)
6 19E624 Blower motor speed control
Removal and Installation
- Remove the 3 RH lower instrument panel insulator screws and remove the insulator.
- Disconnect the blower motor speed control electrical connector.
- Remove the 2 blower motor speed control screws.
- Remove the blower motor speed control.
- To install, reverse the removal procedure.
Thank you sir, hopefully this will resolve my issue with my blower not turning on at all.
Good luck! Recently had to have the blower motor replaced in my Edge.
Is there any way to test either the motor or resistor to confirm which part is bad before I buy replacement parts?
Let me check the manual, be back in a couple of hours.
Pinpoint test most specific to blower motor/resistor ...
Thank you sir. I have no fan at all right now on any speed. File says to go to Pinpoint Test J but J is not included in file.
Pinpoint Tests K&J in attached file
So, I'm back to square one here.
I replaced the motor blower resistor and still nothing.
This all happened when I started my car the other day to cool it down while putting the kids in and when I got in I immediately hit the start button (force of habit) and turned the car off. I immediately hit the button again and restarted the car and that's when I noticed the fan not blowing. I'm 99% positive it was blowing before I accidentally turned it off.
Symptoms:
-Fan motor blower does not turn on at all
-A/C compressor does turn on and if I leave it on long enough I can feel a "coolness" drifting out from the vents, just no blower to push it out.
-I have also noticed that when I turn on my cooled seats that they do not come on either. The lights on the button will briefly light up and then just turn off. I'm sure the issues are related, but have no idea on what my issue is. The same issue happens when I turn on my heated seats, briefly light up and then turn off.
I checked all the fuses that I found relevant in the manual both in the cabin as well as under the hood and didn't see anything there but I may have overlooked somewhere. Some fuses they listed in the book didn't even exist under the hood, just blank spots
Any ideas?
Looking more and more like the HVAC module may be shot.
QuoteHeated Seats — Front
Vehicles equipped with front heated seats are equipped with a single-heated seat module to control both front heated seats. The heated seat module is mounted to the bottom of the front passenger seat. The heated seat module does not time out. The system will function with the ignition in RUN, whether the engine is running or not. The heated seat module supplies voltage to the heater mats and regulates seat temperature by monitoring a thermostat located in the cushion heater mat.
The heated seat buttons are part of the Front Controls Interface Module (FCIM). When a heated seat button is pressed, the FCIM sends a command message over Medium Speed Controller Area Network (MS-CAN) to the HVAC module. The HVAC module then momentarily grounds the request circuit to the heated seat module to turn the heated seat ON or OFF. Upon receiving a momentary ground, the heated seat module will decrease one setting (the sequence is high, low, off and high).
When the heated seat module is on it provides a signal back to the HVAC module. The HVAC module then communicates messages back to the FCIM to turn the indicators on. Both indicators illuminate in high, one indicator illuminates in low and neither will be illuminated when off.
The heated seat module does not report DTCs and does not communicate on the CAN . If a fault is detected, the module will disable the affected seat(s) and indicator(s).
After the fault is corrected, the heated seat module needs to be reset by cycling the ignition OFF and then ON. After the heated seat module has been reset, the module will return to an off state.
The heated seat module request circuits are monitored by the HVAC module and will set a DTC if a circuit fault is detected. Refer to the HVAC Module DTC Chart.
Normal heat cycle may require several minutes to initially warm the seat. The seat should be occupied to correctly test for normal operation. Temperature measuring devices do not provide an accurate method for testing heated seat operation as surface temperatures are subject to human and environmental characteristics. Correct testing requires heater mat resistance measurements which have tight tolerances affecting the length of time for the heater mats to reach maximum operating temperature.
The wiring diagrams point to a fault with the HVAC module also, if you check the PDF with Pinpoint Test J in it.
That would be the HVAC Heater Control Box correct --> http://www.fordparts.com/Commerce/PartDetail.aspx?n=Qj7VMwIdYlkMv5zDlti7fA%3d%3d&id=357984392&m=2&search=true&year=2010&make=Ford&model=Taurus (http://www.fordparts.com/Commerce/PartDetail.aspx?n=Qj7VMwIdYlkMv5zDlti7fA%3d%3d&id=357984392&m=2&search=true&year=2010&make=Ford&model=Taurus)
I believe so
Front Display Interface Module (FDIM)
NOTE: Without navigation shown, with navigation similar.
1 W707628-S Front Display Interface Module (FDIM) screws (4 required)
2 10D885/10E899 FDIM (without navigation/ with navigation)
3 — FDIM electrical connector (part of 14401)
NOTE: Vehicles without navigation require Programmable Module Installation (PMI) when a new module is being installed. For vehicles with navigation, the Front Display Interface Module (FDIM) is not a stand-alone module.
For vehicles without navigation, upload the FDIM configuration information to the scan tool. For additional information, refer to PMI in Section 418-01 .
Remove the center instrument panel finish panel. For additional information, refer to Section 501-12 .
NOTICE: For vehicles with navigation, make sure not to bend the video cable when removing the FDIM .
Remove the 4 screws and the FDIM .
Disconnect the electrical connectors.
For vehicles without navigation, download the configuration information to the FDIM . For additional information, refer to PMI in Section 418-01 .
Audio Control Module (ACM)
1 W713809-S Audio Front Control Module (ACM) screws (4 required)
2 18C869/18C815/ 18K931 ACM (single CD/ 6-CD/ navigation)
3 — ACM electrical connectors (part of 14401)
NOTE: It is not necessary to remove the Audio Front Control Module (ACM) to retrieve the part number. For additional information, refer to Audio Control Module (ACM) Self-Diagnostic Mode in this section.
NOTE: Module configuration is required when a new ACM is being installed.
Upload the ACM configuration information to the scan tool. For additional information, refer to Programmable Module Installation (PMI) in Section 418-01 .
Remove the Front Display Interface Module (FDIM). For additional information, refer to Front Display Interface Module (FDIM) in this section.
Remove the 4 screws and the ACM .
Download the ACM configuration information from the scan tool. For additional information, refer to PMI in Section 418-01 .
Heating Ventilation Air Conditioning (HVAC) Module
1 — HVAC module electrical connector (2 required)
2 19980 HVAC module
1. Remove the Audio Front Control Module (ACM). For additional information, refer to Section 415-00 .
2. Disconnect the 2 HVAC module electrical connectors.
3. Release the retaining tabs and remove the HVAC module.
4. To install, reverse the removal procedure.
Blower motors are pretty easy to test with a fused test lead. In my skimming of the above it seems like you've skipped the obvious and headed for the expensive. Maybe I missed something.
Have you tried powering the blower motor to see if it runs when hard wired? If you don't have a fused test lead, do you have a test light that you can use to check for power getting to the blower motor?
-Rod
It was not the blower.
I have one issue solved. A relay under the hood was bad.
My heated/cooled seats are still not working though.
When you push the button, all 3 lights illuminate and then turn off within a second. This happens for both passenger or driver side and for both heated and cooling functions. No clicking noise is heard that you typically hear from the passenger seat when the system is activated.
Since the blower issue turned out to be a bad relay (yay!), makes sense to verify the Smart Junction Box (SJB) fuse 35 (10A) and Battery Junction Box (BJB) fuse 22 (30A) are OK for climate controlled seats.
Quote from: blaine109 on July 08, 2016, 03:32:21 PM
Can you show us that for the blower motor?
Quote from: JeffsSport on July 08, 2016, 06:53:05 PM
They are the black plastic blocks in the Battery Junction Box under the hood. They say HI PWR or something like that.
Quote from: SHOdded on July 08, 2016, 04:44:25 PM
BJB fuse 22 is non-existant (just not there at all).
I will have to check the SBJ again when I get a chance, going out of town this weekend but I will report back.
Quote from: blaine109 on July 08, 2016, 10:16:26 PM
Blaine due setup your signature with your current vehicle and any mods you may have,thanks. Z
Strange! Even the owner's manual shows a cartridge fuse #22 (30A, pink?) for front heated seats. Do you mean that slot is EMPTY?
Yep, empty. Owners manual also has an asterix by it as well. Not sure of the reason.
I don't see any * there. The ** implies the type of fuse, which is a cartridge rather than mini fuse. But it should be there. Can you post a pic when you get a chance? These seats were working before, so it would be good to know what configuration the BJB/PDB has on your SHO. The passenger compartment fuse panel also, if you can wedge yourself in there :)
What was the production date for your SHO? You have had the car since new?
Did you ever change your seat filters? if not try changing the filter using your wifes or girlfriends stockings or Thigh High's which makes a great media filter and adds a touch of appeal to it,lol. here's a good article for ya. Z https://www.facebook.com/notes/fordpartscom/fordpartscom-parts-tip-stay-cool-know-about-climate-controlled-seats/223295744373477/ (https://www.facebook.com/notes/fordpartscom/fordpartscom-parts-tip-stay-cool-know-about-climate-controlled-seats/223295744373477/) How to change the filters on a 2010+ http://www.fortau.com/heated_and_ventilated_seats-91.html (http://www.fortau.com/heated_and_ventilated_seats-91.html)
I just confirmed on my 2010 production date 12/09 that the fuse is there. (http://uploads.tapatalk-cdn.com/20160709/b41eee2b42e0bba21374ee1c9d7ce438.jpg)
So, for those who are idiots (me) and you take the fuse out to look at it you have to remember exactly which slot it goes back into. I must have put it back in the wrong spot when I first looked over all the fuses.
All issues have been resolved.
:thumb:
