Ecoboost Performance => General Discussion => Topic started by: tgambob on April 02, 2016, 01:49:18 PM
Title: Ptu temp gauge?
Post by: tgambob on April 02, 2016, 01:49:18 PM
I am preparing for my tune by changing all my fluids again and my 3 week old ptu fluid looks like it might have dissolved some of the sludge. So now for my question has anyone put a temperature probe into one of these cases? I found where someone did the drain plug so why not slip a sensor in there? Or am I missing something?
Title: Re: Ptu temp gauge?
Post by: BiGMaC on April 02, 2016, 01:57:33 PM
Quote from: tgambob on April 02, 2016, 01:49:18 PM
No reason not to do it as long as the sensor doesn't stick into the PTU gearing... Follow the diagrams for drilling the PTU that are posted here. Just FYI, the pics and measurements posted are the PTU from an Edge even if it's the same part number... and I am unaware of any long term F/U... So installing an auxiliary cooler might make more sense if you're going to drill the casing.
Post by: tgambob on April 02, 2016, 02:28:54 PM
The cooler is what I am thinking about long term. I'm starting to think about trying to find a 13 pp ptu and use the plug for a temp gauge and the factory cooler nipples to a auxiliary transmission cooler with a pump. I was really surprised how nasty my fluid was I kind of want to drop it and clean it out. Any writeups on this?
Post by: SHOdded on April 02, 2016, 02:51:35 PM
The only writeup, as BiGMaC has mentioned, has been for the Edge, where the_natrix has documented the "state of the PTU".
Post by: tgambob on April 02, 2016, 03:20:13 PM
So there are no rebuild kits for these? Or does my Google fu just fail me?
Post by: BiGMaC on April 02, 2016, 06:17:27 PM
Quote from: tgambob on April 02, 2016, 03:20:13 PM
Unaware of any consumer rebuild kits, and no beef up at all. Tranny has been the same way... Some valves can be bought, but no one wants to build a kit for either that improves strength that I have been able to find or solicit.
Post by: SHOdded on April 02, 2016, 07:03:15 PM
Ask Sonnax, see what they have to say.  All these folks need a batch of orders to ramp up production, and then you need to stay on their case to make it happen.  Just ask SHOsource, they have tales to tell.
Post by: setaonivek on April 12, 2016, 10:06:27 AM
there should be no reason to have to change PTU fluid unless a bearing breaks or the unit is damaged or defective causing extreme heat to burn off the fluids creating that  sludge then ultimately failure.
why are so many of you having to replace this fluid?
@tgambob there are are no consumer rebuild kits for these. once they go, they need to be replaced ..
Post by: ZSHO on April 12, 2016, 10:39:05 AM
I changed my PTU,RDU,Trans fluids,coolant at roughly 30k on her,next step will be the brake fluid and all this was done for a peace of mind especially it being my DD.  Z
Post by: polskifacet on April 12, 2016, 01:45:25 PM
(http://gompka.selfip.com:55698/uploader/uploads/Pictures/SHO/PTU/ptu_drain.jpg)
Post by: polskifacet on April 12, 2016, 02:36:11 PM
Quote from: setaonivek on April 12, 2016, 10:06:27 AM
You have no idea what your talking about, ptu fluid should be changed every 20k.
(http://gompka.selfip.com:55698/uploader/uploads/Pictures/25iyrd4.jpg)
Post by: ecoboostsho on April 12, 2016, 02:54:23 PM
My 2013 has the PP version with a temp gauge and even with the cooler I can hit temps of 200-220 in the PTU in the summer.  The cooler is supposed to drop the temp by 70 - 80 degrees if memory serves correctly.  So there are probably a whole bunch of PTU's that could hit close to 300 degrees when driven aggressively or even for longer periods at high speeds (80+).  That is going to do a number on the fluid over time.  They also have a habit of puking it out a vent on the earlier cars which can run it dry over time - also not good.  That is why you should play it safe and change your PTU fluid.
Post by: BiGMaC on April 12, 2016, 03:24:56 PM
Well... There's a lot of picture and stories showing either burned up PTUs or PTUs full of black semi-liquid that is the consistency of near frozen chocolate syrup at 20-30K miles.... Many don't have an extended warranty. Ford has a MTBF of 100K miles which will be past any warranty for most.... At 300 degrees in a non-PP how long can a couple of ounces of gear lube last? ...or in a PP that's driven in a spirited fashion.
I agree with replacing the unit entirely if it fails.... But why not PM it to prolong the life? My dealer won't do it because Ford won't warrant the part if they do...
Here's some pics of the PTU... First 2 are what a lot of folks find, third is where the PTU has been drilled for a drain or guage, last pic is what the first 2 should have looked like...
(http://i1331.photobucket.com/albums/w596/knot2bfound/Junk/image_zpsa74olwfi.jpeg) (http://s1331.photobucket.com/user/knot2bfound/media/Junk/image_zpsa74olwfi.jpeg.html)
(http://i1331.photobucket.com/albums/w596/knot2bfound/Junk/image_zpsmeaasreo.jpeg) (http://s1331.photobucket.com/user/knot2bfound/media/Junk/image_zpsmeaasreo.jpeg.html)
(http://i1331.photobucket.com/albums/w596/knot2bfound/Junk/image_zpsq2fqt50x.jpeg) (http://s1331.photobucket.com/user/knot2bfound/media/Junk/image_zpsq2fqt50x.jpeg.html)
(http://i1331.photobucket.com/albums/w596/knot2bfound/Junk/image_zpstshalkiq.jpeg) (http://s1331.photobucket.com/user/knot2bfound/media/Junk/image_zpstshalkiq.jpeg.html)
Post by: ZSHO on April 12, 2016, 05:08:54 PM
https://www.youtube.com/watch?v=Qoo0auuT6h8&nohtml5=False (https://www.youtube.com/watch?v=Qoo0auuT6h8&nohtml5=False)
Post by: setaonivek on April 12, 2016, 06:26:30 PM
Quote from: polskifacet on April 12, 2016, 02:36:11 PM
Who are you to tell me i don't know what i am talking about?  there is ZERO documentation that supports this .. if there is official documentation from Ford, then show me and i will take it to my dealer and have mine checked.  I don't drive my car like aggresively and i don't race so perhaps some of you are creating the problem on your own based on the load you induce ..
i understand fluids, in fact i understand more than i let on but this is MY educated opinion .. instead of telling people they don't know what they are talking about, how about do some actual thing research before hand ..
Post by: setaonivek on April 12, 2016, 06:41:16 PM
Quote from: BiGMaC on April 12, 2016, 03:24:56 PM
see, i understand .. but you are saying "well, there are pictures and stories..." this is what i don't get, nothing official from Ford .. i asked why, so thank you ..
Post by: ZSHO on April 12, 2016, 06:44:45 PM
Quote from: setaonivek on April 12, 2016, 06:26:30 PM
This is an open forum but please refrain yourself from using any such words as per Forum rules and thank you for your attention in this matter.  Z
Post by: setaonivek on April 12, 2016, 06:47:41 PM
Quote from: ZSHO on April 12, 2016, 06:44:45 PM
This is an open forum but please refrain yourself from using any such words as per rules on the forum.  Z
understood, but some members here need to think before speaking ..
Post by: ecoboostsho on April 12, 2016, 06:55:51 PM
Did you by chance design the PTU? Do you work for Ford? I'm not being sarcastic...if you have data that would indicate these aren't prone to failure from fluid loss (or cooking) then please by all means share it. I should have added that my 2011 puked fluid all the time and was failing when I sold it...
Sent from my XT1096 using Tapatalk
Post by: 66 Galaxie on April 12, 2016, 07:45:34 PM
PTUs are like playing the lottery and some seem to last while others don't.
For owners that are enthusiasts and demand more from the drivetrain fluid changes for the PTU and transmission make a lot of sense and can only help to increase the longevity of these units.
Is it required by Ford, no but it makes good sense plane and simple.  I have an '08 Taurus X awd with 243k miles and it still has the original PTU and trans.  Both units have had multiple fluid changes and I'm confident that fluid changes have been key to their long lifespan.
Local police fleet changes both PTU fluid and trans every 30k due to severe service.
So take it for what it is worth and make your own decision on what you think is coincidently vehicle.
Just my $.02
Post by: polskifacet on April 12, 2016, 08:04:19 PM
I work around 30 fleets of machines which consist of at least 100 per fleet. Each machine is 1.5 million dollars. They require constant maintenance even when not running. My previous job I worked with fleets of laser guided vehicles. My father has worked on heavy machinery at Caterpillar for 25 years. I know everything about lubrication, PMs etc. etc .etc etc. on a level so much greater than a simple PTU.
Regularly service the PTU...
http://www.fordedgeforum.com/topic/13533-13m01-middle-east-ptu-extended-warranty/ (http://www.fordedgeforum.com/topic/13533-13m01-middle-east-ptu-extended-warranty/)
hmm 30,000 km = 18,641 miles
Post by: AJP turbo on April 12, 2016, 08:32:22 PM
You guys are being put on....this guy is like my evil twin...he likes to get people worked up but he has diarrhea breath and talks s*** whereas i get people worked up and spit truth lol......id say some things but Z would just edit my post because it would be time to hurt feelings and anuses...is that the plural form of anus?
Post by: polskifacet on April 12, 2016, 09:36:46 PM
Sometimes the truth stinks, OP change the ptu gear oil.
Post by: FoMoCoSHO on April 12, 2016, 09:38:18 PM
Here is what I was told about PTU's an why some fail with sludge and some look perfect @ 60K
Basically when they come off the assembly line, if they are manufactured correctly and the tolerances are in line you will get a long life without a fluid change.
Apparently QC isn't all that hot and that isn't happening....tolerances are off, more friction and lack of movement cooks the fluid and ruins the PTU.
Most rational minded folks would agree you really can't over maintain something like a PTU. The problem is it has been alleged by certain unscrupulous service advisers that Ford will void your warranty over it which is absurd IMHO and puts folks under warranty in a bind. Don't maintain it under warranty for fear of cancelled warranty on that part or listen to Ford and risk a failure when it goes out of warranty. Quite the conundrum. I say allege because it's not something Mrs FoMoCoSHO has ever encountered and you guys would be surprised at some of the modded vehicles they are able to get covered with Ford fully knowing what has been done to the vehicles. Ford wants to sell cars and pi$$ing off your loyal customers isn't the way to make that happen. And she has surely NEVER had a warranty denied for over maintaining a vehicle.
The first thing to do is try to find a dealership that will service your car how you want it without threats. Bottom line IMHO is they are lazy and don't want to deal with it. I'd suspect the dealerships that are willing to do what you ask will get it covered if there happened to be a failure. They know these things fail for no good reason and a good dealership will always fight for their customer.
My suggestion is service your vehicle to the level you feel appropriate. If you have a failure under warranty they will not cover make them put it in writing WHY they wouldn't warranty it.
If the worst were to happen....
Call Ford first and hammer them on social media with pics and links to the PTU failures found all over the internet. Be persistent. Be that festering wart on their a$$ that they just want to go away.
If that tactic fails take it to 3rd party neutral warranty arbitration where their lawyers are moot. Give every member a copy of Magnusson Moss and present your case. Remember the burden of proof is on Ford to PROVE that over maintaining your vehicle caused the failure. And as long as you have the correct volume and type of fluid? Good luck with that. Most likely that will never happen and once you let your intentions be known, the PTU will be replaced.
Remember, there is plenty of evidence on the internet regarding fluid condition and premature failures. During arbitration you will get your chance present your evidence and to ask questions like, what specifically would cause newer fluid of the correct specification and filled to the proper level to be detrimental to the life of the PTU??? Seriously, GTFO, it just sounds ridiculous when you say it.
I seriously doubt this situation would ever get to that level. The first line of defense is finding a good dealership which I know is sometimes much easier said than done. Do you think Ford wants to risk your next $50k purchase over an $800 PTU that is marked up 40-60% to start with?
Post by: setaonivek on April 13, 2016, 07:34:24 AM
Thanks FoMoSho .. this is the kind of response i was hoping to receive and appreciate not the inconsiderate responses earlier, really, all i wanted to ask was why ...
the problem i have, is EVERY dealer (in my area) i have spoken to on this has literally told me, in spite of ALL the evidence on-line, that PTU under normal driving conditions should not need servicing ..
i don't know what to believe .. just seems ridiculous to me that this is not considered a serviceable part if there is SOOOO much evidence.  I want to my car to last, do you think i/or any one else for that matter would not ask about this?  WTF?
Post by: SHOdded on April 13, 2016, 08:04:06 AM
I think the point is that there is enough end-user evidence that you should at least check the PTU fluid regularly.  With any luck, you'll never have to change it, but if you want to get the best out of the PTU, it is best to set a periodic preventive maintenance schedule.  I would find a BG shop and have them check the fluid, if it's not practical to DIY.
The rest of the discussion as to why dealers do or don't, or why Ford does or doesn't is good to know or talk about, but the bottomline is still that the PTU is not set-and-forget.  Has not been since at least the Taurus X.
Post by: 66 Galaxie on April 13, 2016, 08:31:25 AM
Great summary!
Post by: setaonivek on April 13, 2016, 10:07:46 AM
Quote from: SHOdded on April 13, 2016, 08:04:06 AM
Thank you SHOdded ... appreciate this.
I do agree, now, that it should be checked and with all of this evidence of problems i really find it ridiculous that it is not considered a serviceable part, at least a check at irregular intervals.
I have contacted my dealer again and they have agreed to finally look at it.
Post by: ZSHO on April 13, 2016, 10:39:08 AM
Quote from: setaonivek on April 13, 2016, 10:07:46 AM
Setaonivek how many miles on your 15 PP SHO?  also was curious if Ford would somehow enact therev service provisions differently in Canada,just a thought.  Z
Post by: setaonivek on April 13, 2016, 11:26:08 AM
Quote from: ZSHO on April 13, 2016, 10:39:08 AM
that is a good question .. i have 27770kms (roughly 17255mi) .. i will ask my service guy when i speak to him later
Post by: Windstang on June 11, 2016, 07:30:33 PM
Whether or not Ford recommends an oil change is no reason not to change the oil. To me their service intervals are so the parts last for the warranty period plus a day/mile.
All oil is subject to thermal breakdown. Ford recommends and oil change for the diff - so why not for the PTU?  After trying to suck out old PTU oil from the fill hole and having difficulty getting all the oil out, I decided to drill and tap a drain hole (at 140,000 kms) and have done 6 drain & fills in the last 1000 kms and the oil is still coming out black - but it is getting more oil like and not so sludgy. When I sucked it out the first time the PTU oil looked awful and was very sludgy and there was a grease like substance on the fill plug so that was probably representative of the rest of the PTU as well as the pictures showed in previous posts. Not much lubrication with that crap and bound to fail.
I was wondering about the jiggly vent on the top so went to a Ford parts counter to ask if I could see a new PTU to see what the vent looked like. There is a Taurus TSB to replace the vent with an extension tube and since they both use the same PTU, the TSB could apply to my MKX. The Parts guy laughed and said they actually did stock the PTU's because they go through a lot of them. He also commented that it was their belief that their should have been a drain to regularly service the PTU.
I believe that it is cheaper to change oil than parts - so replacing the PTU oil can only make it last longer regardless of the recommendation by Ford that it is a lifetime fill  - especially after seeing what my PTU oil looked like. Pull your drain plug and see it there is sludge on it - it's not that hard to remove it.  Then try to dip something into the fill hole and see the condition its oil. Then decide for yourself. It sure is nice to have the drain hole in my PTU. It will now get an oil change each time I change the engine oil. Hopefully one day it will appear golden colour and not black as it does now because it is still dissolving the sludge.
Post by: sholxgt on June 12, 2016, 03:12:28 PM
My wife works for a Ford/Lincoln chain of dealers.  Here's the information that I gathered by asking service managers and drive line techs at two dealers.
1. These dealers service the Police department vehicles.  Every department has the dealer change the PTU fluid at 30,000 mile intervals.
2. Ford does not call for maintenance of the item, but the techs and managers said they would still change the fluid if it was their personal vehicle.
#2 comes with the asterisk that they will first tell you that "Ford" does not call for changing the fluid.
I think dealerships are in a bind on this subject much like they were with the non-serviceable transmissions.  Ford is telling them what to tell customers and they then have to decide if they want to spew the rhetoric or be honest with the customer.
Post by: SHOdded on June 12, 2016, 07:08:59 PM
The advantage the PI vehicles have is that the PTU is indeed "serviceable", as it comes with a drain plug.  So it's easier to get reimbursement from Ford and defend warranty claims.  And I doubt Ford is going to have an issue with the PTU being serviced in such a high-visibility application.
