Ecoboost Vendor Section => Ecoboost Vendors => Eco Power Parts => Topic started by: EcoPowerParts on September 02, 2015, 05:49:54 PM
Title: Snow Methanol Injection Kits available at EPP
Post by: EcoPowerParts on September 02, 2015, 05:49:54 PM
(http://www.f150ecoboost.net/forum/attachments/40485d1439849719-snow-methanol-injection-kits-available-epp-39888d1439849719-afe-intakes-exhaust-charge-pipes-intercooler-kits-best-prices-epp-epppng_zpso02.png) (http://www.f150ecoboost.net/forum/attachments/40485d1439849719-snow-methanol-injection-kits-available-epp-39888d1439849719-afe-intakes-exhaust-charge-pipes-intercooler-kits-best-prices-epp-epppng_zpso02.png)
Eco Power Parts wants to be your leading supplier for your Ecoboost performance needs. In continuing that trend, we present to you Snow Water-Methanol Injection kits!
(http://www.f150ecoboost.net/forum/attachments/40486d1441228600-snow-methanol-injection-kits-available-epp-snow1_zpsnnsu2emj.jpg) (http://www.f150ecoboost.net/forum/attachments/40486d1441228600-snow-methanol-injection-kits-available-epp-snow1_zpsnnsu2emj.jpg)
(http://www.f150ecoboost.net/forum/attachments/40487d1441228619-snow-methanol-injection-kits-available-epp-snow2_zpscaxdnayq.jpg) (http://www.f150ecoboost.net/forum/attachments/40487d1441228619-snow-methanol-injection-kits-available-epp-snow2_zpscaxdnayq.jpg)
Why is Snow Performance "The Water-Methanol Injection Experts"?
Snow Performance was the first company to bring water-methanol injection to the market place in 2000. The only thing we do is live, breathe, and eat (just kidding) water-methanol injection. Our systems are the most tested, accurate, popular, powerful and come with all the experience and insight of the oldest and largest water-methanol injection company.
Industry Leading Pump
Have you seen a similar looking pump elsewhere? There is a reason. Snow Performance 300 PSI UHO pumps are the industry leader in water-methanol technology. However, Snow Performance remains the only manufacture to have the proprietary features that make this pump so powerful, reliable, and safe that our competitors simply don't have. Including:
1. 300 PSI to deliver the best atomization on the market
2. Dual EPDM outlet seals to run 300 PSI safely
3. Built in thermal breaker
4. Propriatary design that gives constant pressure with out pulsating
5. Proprietary internal design to run cooler longer
6. Built in O-rings/gaskets/podding
Best Atomizing Nozzles
A large part of how much power and heat a water-meth system takes away is how atomized the droplets are. Snow Performance Hyper-Sonic Nozzles force the fluid through two venturi shaped oripheses at 300 PSI to deliver the most superior atomization on the market (80 Micron). Tie this in with methanol resistant stainless steel construction and a built in 100 micron screen and the Snow Performance Hyper-Sonic nozzle is the last nozzle you will ever have to buy!
Safety
U.S. Snow Performance engineers have done extensive R&D to manufacture and ensure the safest water-methanol injection system for our customers. Because of this we hold more SEMA awards than any other water-methanol injection manufacture.
1. Most Advanced Failsafe (Safe Injection)
2. Highest Pressure Solenoids
3. Check Valve Built in With Every Nozzle Holder
4. Real Time Flow Gauge
5. Thermal Breakers with every system
6. 100% tested components
Snow Performance built a stage 3 kit specifically for the Direct Injection and Ecoboost vehicles on the market today shown below:
(http://www.f150ecoboost.net/forum/attachments/40489d1441229210-snow-methanol-injection-kits-available-epp-ecoboosty_zpsimtbima2.jpg) (http://www.f150ecoboost.net/forum/attachments/40489d1441229210-snow-methanol-injection-kits-available-epp-ecoboosty_zpsimtbima2.jpg)
These kits start off at just $849.00 with free shipping and include the following:
  • 300 PSI UHO (Ultra High Output) Pump
  • 3 Qt Reservoir
  • All Tubing Necessary for Installation
    • 10' ¼ Inch High Temp Nylon Tubing
    • 18" High pressure Boost Line
  • Terminated Digital Variable Mapping Controller
  • Terminated Plug&Play Wire Harness
  • Power Solenoid Upgrade
  • Level Switch Upgrade
  • 2 Nozzle Holder/Check Valve Combo
  • 3 Hyper-Sonic™ Nozzles
  • Snow Performance Running S Decal
  • Required Hardware Needed For Installation
  • Comprehensive Instructions to Install on Direct Injected/EcoBoost Vehicle
  • Snow Performance 1-Year Warranty
We have plenty in stock and ready to ship! This is an excellent alternative to running E85 or for those of you who may not have that available near you!
Title: Re: Snow Methanol Injection Kits available at EPP
Post by: EcoPowerParts on September 02, 2015, 05:50:01 PM
QuoteThe Snow Performance Stage 3 Boost Cooler  is the most advanced water-methanol injection system for your DI (direct  injected) and forced induction (turbocharged/supercharged) vehicle. The  Stage 3 creates a 2D injection map based off boost and fuel pressure sensor  voltage to deliver the most accurate and tunable water-meth delivery on the market. Taking  it one step further the Stage 3 will control 2 Hyper-Sonic Nozzles independently of one another to solidly the exact amount of water-methanol is provided at  all rpm ranges of the engine. This 2D map injection and dual stage  technology translate into the most accurate injection curve and tuneability of any water-methanol system giving 50-110 HP gains and up to 150 degree  reduction in air temps! Tie this in with the industry leading Snow Performance 300  PSI UHO pump, Hypersonic Nozzles™, and terminated weather tight OEM  harnessed wiring connections and the Stage 3 promises to be the easiest and most effective water-methanol system on the market for your DI / Boosted vehicle. [/q]
