Ecoboost Performance => Troubleshooting, Maintenance, TSB Articles => Troubleshooting => Topic started by: jtoddk98 on June 19, 2015, 05:18:14 PM
Title: Is this normal?
Post by: jtoddk98 on June 19, 2015, 05:18:14 PM
I was under the dash today to pull the sync fuse to reset it (Bluetooth wasn't working) while down there. I saw that where the break pedal goes through the firewall into the break booster/master cylinder, it is wet, I took some pictures, is it normal? The booster was replaced 15000 miles ago with a new one because of a spongy pedal.(http://images.tapatalk-cdn.com/15/06/19/7cdaa6dc970b9e8c1c8487660f5c1282.jpg)(http://images.tapatalk-cdn.com/15/06/19/e6c9b5e9d4df0527dca3d54889cb1374.jpg)
Title: Re: Is this normal?
Post by: SHOdded on June 19, 2015, 06:27:56 PM
Is it really wet?  Did you touch/smell it?  If that seal is two piece it could be a glossy sealant that was applied to it?
Post by: jtoddk98 on June 19, 2015, 06:34:59 PM
Yea it's not soaking, but it's damp. I didn't smell it, but I'm expecting break fluid
Post by: ZSHO on June 19, 2015, 07:21:05 PM
Quote from: jtoddk98 on June 19, 2015, 06:34:59 PM
Did you check your brake fluid level.
Post by: jtoddk98 on June 19, 2015, 09:10:20 PM
Level still up by MAX on the reservoir.
Post by: ZSHO on June 19, 2015, 10:51:19 PM
Quote from: jtoddk98 on June 19, 2015, 09:10:20 PM
I was curious on how your brakes feel and stop,any brake lights out?  Z
Post by: glock-coma on June 19, 2015, 11:26:15 PM
I'm guessing it's some kind of lubricant to prevent the bar that goes through the grommet in the fire wall from rubbing/squeaking.
Post by: jtoddk98 on June 20, 2015, 12:07:28 AM
Quote from: glock-coma on June 19, 2015, 11:26:15 PM
I'll get back under there in the morning to get some on my finger and feel it. I'm hoping it's just a lubricant.
Post by: BiGMaC on September 05, 2015, 12:30:27 PM
Any follow up info?
