Detailing, SYNC, AV, Security, Electrical, and Lighting => SYNC, A/V, Lighting, and Security Systems => Lighting => Topic started by: jtoddk98 on March 23, 2015, 05:56:11 PM
Title: Light replacement
Post by: jtoddk98 on March 23, 2015, 05:56:11 PM
I just tried to replace my reverse lamps with LEDs. I took it out and noticed that the bulb and socket are one piece looks ford proprietary. So should I return the bulbs I have or what?
Title: Re: Light replacement
Post by: SHOdded on March 23, 2015, 06:26:19 PM
So you have these infamous bulbs?
http://www.ebay.com/itm/PHILIPS-7010-HPC16W-PU20D-1-12184-X-2-BULBS-16W-BACK-UP-LIGHT-CHEVROLET-SATURN-/160835305649 (http://www.ebay.com/itm/PHILIPS-7010-HPC16W-PU20D-1-12184-X-2-BULBS-16W-BACK-UP-LIGHT-CHEVROLET-SATURN-/160835305649)
(http://www.ecoboostperformanceforum.com/gallery/60_23_03_15_3_31_29.jpeg)
Yeah, you are in a tight spot.  Best return the LEDs.  There is a place on the web that shows how to wire the socket for a standard base LED and make it work that way, but def not plug&play.
Post by: jtoddk98 on March 23, 2015, 07:29:08 PM
Yup those are it. Is there a led plug and play option?
Post by: SHOdded on March 23, 2015, 07:37:52 PM
Not to my knowledge.
Post by: BiGMaC on March 23, 2015, 07:40:11 PM
Quote from: jtoddk98 on March 23, 2015, 07:29:08 PM
vLED Tritons is about as close as it gets... They make a back-up bulb option, but it is actually a system.
Post by: jtoddk98 on March 23, 2015, 11:01:23 PM
That's unfortunate. I replaced the brake lights and the little red running light back there with red LEDs, nice improvement, no more white light showing through the red lens. Looks good
Post by: jtoddk98 on March 23, 2015, 11:04:16 PM
Another question. How do I get the center bulb out of the dome light?
Post by: SHOdded on March 23, 2015, 11:05:56 PM
See if this is in your skillset:
www.camaro5.com/forums/showthread.php?t=229051 (http://www.camaro5.com/forums/showthread.php?t=229051)
Not sure if this of help with the dome light:
http://www.ecoboostperformanceforum.com/index.php/topic,528.0.html (http://www.ecoboostperformanceforum.com/index.php/topic,528.0.html)
Post by: jtoddk98 on March 24, 2015, 12:53:40 AM
Got it done along with my DIY led puddle lights. Bake em at 200 in the toaster for a few minutes, and pry them open, not bad.
