Hey. Noticed this today, my car makes a short rattle on a cold start and when revving the engine when at normal operating temp. Comes from te front of car. Catalytic converter maybe? Here's a video.
https://vimeo.com/106136170 (https://vimeo.com/106136170)
Could be that you may need new gaskets that connect to converters to exhaust and make sure also the bolts are tight,loose connection can cause the rattle or a heat shield?
No clue. The exhaust is all stock still and the car only has 45k on it. Hoping the warranty will cover it if I take it in
Brand of oil/filter? Doesn't sound like that type of rattle tho.
Motorcraft full synthetic at the dealer since new.
If you can remove the belly cover,bottom and inspect to see if anything fell inside?
Quote from: ZSHO on September 15, 2014, 06:54:15 AM
Good idea! Sometimes the bellypan does not get reinstalled correctly or a push pin falls out.
