Have a 2010 SHO and dropped in a new batteryfrom AZ...Duralast Platinum.
Now I have radio static...any thoughts?
When I disconnect the battery cable, my radio defaults back to AM and the pre-sets are messed up. Are you sure your radio is precisely tuned to the station you want?
Bad ground connection maybe.
All my presets are still set. Maybe I should let it sot disconnected longer.
Everything seems tight too.
You check for any corrosion or discoloration on the cable ends that connect to battery?
Quote from: SHOnUup on August 28, 2014, 06:29:33 PM
X2
