Ecoboost Performance => Troubleshooting, Maintenance, TSB Articles => Troubleshooting => Topic started by: Fast SHO on December 06, 2013, 05:48:03 PM
Title: TPMS relearn for 2013
Post by: Fast SHO on December 06, 2013, 05:48:03 PM
I'm going to punch a wall.  can't for the life of me figure it out.
Swapped to snow tires and tried to figure out how to do it with the push button start.
You are supposed to push the brake.  Cycle to on, off, on, off, on - push brake - on off on off on and then the car is supposed to beep at you so you can do the relearn.
Title: Re: TPMS relearn for 2013
Post by: DJE624 on December 06, 2013, 05:51:51 PM
It is a pain.  I watched a tech do it once.  Good luck!
Post by: SRT82ECOBOOST on December 06, 2013, 05:59:52 PM
I had to bring it to a dealership to get it to work correctly.
Post by: Fast SHO on December 06, 2013, 06:00:13 PM
The problem is the stupid push button.  It doesn't respond fast enough so you are basically doing trial and error to get it to 'on' instead of 'accessory.'
True on is when the engine text illuminates but engine doesn't start.
I finally got it to work but it was pretty random as far as me pushing the buttons.  I basically did the following:
push brake
push button until engine text illuminates
turn off
push again until it illuminates
turn off
push again until illuminates
push brake
off
push to illuminate
off
push to illuminate
then car beeped at me and I did the learn process
when I say push to illuminate that does not represent the number of times I actually pressed the button lol
Post by: BiGMaC on December 06, 2013, 06:05:38 PM
Here's a post from another forum from May 2013... bpd approved on that forum It is for linking new TPMS sensors to the Taurus:
To help others in the future, I figured I would document what I learned about linking new TMPS sensors to the Taurus.
This process can be divided into 3 parts:
1. Waking up the sensors
2. Getting the Taurus into re-learn mode
3. Linking the sensors to the Taurus
Note: The sensors I bought with my new wheels were Orange-Electronic Brand OEM replacement model sensors.
1. The sensors can be in 2 states; hibernation or sleeping.
Hibernation: From what I understand, the sensors will only go into hibernation if they are not linked to a vehicle and have been stationary for a number of weeks. To wake sensors up from hibernation, the tire pressure must be reduced to 0 psig for 30 minutes, then increased to at least 44 psig. (I read elsewhere that the tire does not have to be completely depressurized, but I tried that and it did not work for me). Also, other aftermarket sensors may have a different wakeup technique - such as using a strong magnet near the valve stem.
Sleeping: Every time your wheels stop moving for more than (about) 30 minutes, your sensors will go into a sleep state to save the battery. To wake the sensors from the sleep state, rotate the wheel at least 1/4 turn.
2. The Taurus will enter TPMS relearn mode 2 ways; ignition cycling process and hazard button process. Before you start, make sure your tires are awake and have the proper amount of air (44 psig from the hibernation wake up will work..and don't worry, the tire pressure at time of re-learn will not set or calibrate the car's pressure alarm limit-this cannot be changed by us).
Ignition cycling process:
Note: For push button ignition, the "on" is hold the start button down without brake pedal.
i. Start with the key in off position and press and release brake pedal.
ii. Turn the key to on position (not start) and after the first chime turn it to the off position.
iii. Turn the key to on position (not start) and after the first chime turn it to the off position.
iv. Turn the key to on position (not start) and press and release brake pedal and turn key to off position.
v. Turn the key to on position (not start) and after the first chime turn to off position.
vi. Turn the key to on position (not start) and after the first chime turn to off position.
vii. Turn the key to on position (not start) and leave in on position. Horn will chirp once and the message center will indicate to train Left Front Tire.
Hazard button process:
Note: This may not work for new sensor learning, but can be used when rotating tires.
i. Turn the key to on position (not start).
ii. Turn on then off the hazard button 3 times. Horn will chirp once and the message center will indicate to train Left Front Tire.
3. You will need the ford TPMS tool as seen below (about $40CAN at dealer). http://www.ebay.com/itm/OE-FORD-8C2Z1A203A-TPMS-Tire-Pressure-Sensor-Reset-Calibration-Tool-/350632285723 (http://www.ebay.com/itm/OE-FORD-8C2Z1A203A-TPMS-Tire-Pressure-Sensor-Reset-Calibration-Tool-/350632285723)
Following the prompts on the message centre, point the tool at each of the appropriate tires just above the valve stem and press/hold the button until the horn chirps. If the process is not successful, the horn will chirp twice and you must repeat the training process.
Post by: Fast SHO on December 06, 2013, 06:11:01 PM
I tried that s*** and "holding down" can be left to interpretation.  Trying that is what led me to want to punch a baby.
Post by: BiGMaC on December 06, 2013, 06:16:59 PM
If it's available to you SRT gave the hassle free method... just get them to let you watch.
