Detailing, SYNC, AV, Security, Electrical, and Lighting => SYNC, A/V, Lighting, and Security Systems => SYNC => Topic started by: VibraSHO on March 22, 2022, 01:39:18 AM
Title: 2018 SHO weird sync problem.
Post by: VibraSHO on March 22, 2022, 01:39:18 AM
The sync system is acting up. Currently it will not turn on at all. The radio and backup camera both do not come on.
Below the screen, the CD player eject, passenger airbag, and hazard button all illuminate and are operational.
Continue down, the volume knob is illuminated yet provides no functionality. While the source and sound buttons are not illuminated and also proved no function.
Below, all climate functions work and illuminate properly.
The USB ports are both not functioning (inside the console that connect to sync).
When the system was operating about 25% of the time, sync would boot but give a navigation error. I took the opportunity to do a factory reset, with no improvement. I also did an overnight battery disconnect as well as a fuse inspection.
Additionally there
Title: Re: 2018 SHO weird sync problem.
Post by: Ta2dResqr on March 28, 2022, 01:23:17 PM
Have you tried to check for codes? Best option would be with ForScan or something like OBDLink that offers expanded coverage. Often there will be a code but no light as it is not a critical system.
Post by: Macgyver on March 29, 2022, 11:33:26 AM
Since it was very buggy before. It is not likely a fuse.
No warranty ?
After doing the above recommendations. Your best bet might be to get a whole new sync module (used). I doubt the screen is toast.
